11-28-2016, 12:58 PM
Engine: T444e
Solar Power Configuration/Install
Hey folks, it's finally time to install our power center. Unfortunately, I have procrastinated quite a bit on this because of the, self perceived, intimidating nature of the project. I started moving the components into the bus and have drawn up a crude sketch of the flow plan. This layout includes all components currently in my possession, except for two 150vdc din switches (60A and 15A, respectively) which are supposed to go in the disconnect box. I'd love if y'all could take a look and see whether there are any blatant errors...
I know there need to be fuses, but not sure where and what type. Also, I'm wondering if the battery charger needs to feed into the controller or just straight to the bank.
I will be connecting my batteries in series AND parallel. If I'm not mistaken, it should look something like this...
...and a final thought, for now: when I bought my solar power package I was given 2/0 cables for the battery connections and a few others which I assume go into the inverter. There are two red cables and one black, of varying lengths. What type of cable do I need for these other components? (I did also receive a 50', 10awg MC4 cable and I assume that runs from the panels to controller.)
Thanks for your time, gang! Any advice will be greatly appreciated!
11-28-2016, 01:12 PM
you have a mistake on your battery connection drawing..not enough wires/connections. as drawn it won't do anything as you only have one terminal of each battery connected.
I assume you're after 440a 12v as the end result?
11-28-2016, 01:50 PM
Year: 2005
Engine: Detroit MBE906
Prof.fate is correct, it needs to be connected like this:
Also the battery charger will feed straight into the bank.
Some inverters have a built-in charger, you might look at one of those as well.
11-28-2016, 02:35 PM
Engine: T444e
That's right. 440Ah at 12v...
11-28-2016, 02:41 PM
Engine: T444e
Thank you! I am a visual learner, so the drawing is very helpful.
11-28-2016, 02:43 PM
Year: 2005
Glad I could help..... M$ Visio works well for making diagrams like that. Not a cheap program by any means but quite useful.
11-28-2016, 03:32 PM
Engine: T444e
Another question just came to me... If I am running my AC loads via extension cords throughout the bus, do I need to have cords with a particular rating?
P.S. I also want to connect with shore power via extension cord.
11-28-2016, 04:06 PM
Year: 2005
Unless your AC needs are very small I would not recommend that. But then again your design did only have a 1000 watt inverter.....
That being said, a standard orange extension cord is not rated for more than 15 amps. I believe you can get cords rated for 20 amps but they're gonna cost more, plus they will only connect to a 20 amp outlet. Anything bigger than that and you're getting into 240 volt or RV cord size.
My AC design is for a full 50 amp RV service, the cord for which was well over $100 by itself because it's 25 feet long with 6/3 hot/neutral and 8/1 ground conductors.
You might want to rethink the inverter size, that 1000 watts is only gonna give you a little over 8 amps. You're not gonna be able to run a microwave or heater off of that. I'd at least double that to 2000. I ran a 2500 watt inverter in my truck when I was an OTR driver (fridge, microwave, laptop and printer), and size your battery bank and solar array accordingly.
As with anything, YMMV.
11-28-2016, 06:53 PM
Year: 1987
Engine: 6.9L Diesel
I like your pictures, they are clean simple and good. I look forward to you following up with progress pictures!
I am not an expert(probably not even close to a novice yet) so you should heed to other sources over myself, but here's my limited understanding towards fuses.
I don't know either where and what kind of fuse you need. But I believe you'll want a 10-15 amp(because 10a*120v=1200watt) fuse between your 1000w inverter and your ac loads (usually in the form of a breaker box I believe) to prevent your inverter from getting fried from a large load. And you'll want another fuse between your battery charger and it's power source to protect your battery charger from getting overloaded with current. I would guess your inverters instruction manual provides better detail than myself.
I too plan to use a 1000w Inverter for most of my basic needs. I also plan to have a seperate 2000w inverter to use for special occasions like when the wife needs to use a hairdryer, or when we need to use our convection oven. However I hope to keep most of our needs limited to the 1000w inverter. There is no Air conditioner in my floorplans or electrical budget, I may regret this later.
11-28-2016, 07:15 PM
Year: 2005
Taolik I'll tell you the same thing..... 1000 watts will not run a lot of things. You'll find that the wattage on a lot of appliances is more than you realize.
Of course nothing says you can't run multiple inverters off one battery bank.... just make sure you size the bank appropriately for the loads you'll be running.
There are worksheets online that will allow you to enter the power draw of all your loads and it will tell you how much inverter and how big a battery bank you will need.
This particular worksheet will tell you everything you need to know.... but you will need to select the type of battery you want to use and enter in the parameters, and also select the type of solar panel you want to use and enter its parameters.... then after entering your loads it will tell you how many batteries and how many solar panels you will need for your setup. Of course if you don't plan to use solar you can still use the battery bank calculator.
Off Grid System Solar Sizing Calculator
11-28-2016, 07:25 PM
my 28' camping trailer uses 12v for fridge (when on propane), the radio and lighting, and thermostat/elec ignition for the furnace (propane also).
To use a microwave or any of the 120v outlets i need to be plugged into shore power (30 amp, which runs everything including 220v 13,000btu a/c unit).
I have a 30amp/220v plug to normal 110v plug adapter (and a 30 to 50 as well) and that runs all but the a/c (since it needs 220).
Haven't torn the camper apart, but the charger/converter takes care of charging the house battery when plugged into shore power.
the panel look ssomething like this - with 110v breakers and 12v fuses.
when i turn on a lot of 12v lights a fan in the inverter kicks on to keep it cool.
As for converter - turning 12v into 110v..other than a microwave or charging a laptop you probably don't need 110v from a battery source.
The few i've used seem to kill a battery pretty darned quickly.
11-28-2016, 07:27 PM
Chassis: B3800 Short bus
I'll add a very minor improvement to AlleyCat67s diagram:
If you pull off of opposite corners of the bank the batteries are more likely to stay equalized. Pulling off of one end of the bank will tend to tax the first set of batteries more than the next set due to that bit of resistance in the longer leads.
Actually, the bottom diagram in this next picture might better explain what I'm talking about :
11-28-2016, 08:53 PM
Not quite 214Ah ☺️
1500w at 12v is 125a (1500 / 12 = 125).
Running that dryer for an hour would consume 125 amp hours (amps per hour).
12 minutes divided by 60 minutes is 0.2 hours.
125Ah multiplied by 0.2 is 25Ah.
So running for 12 minutes should consume 25amp hours from the battery bank plus a bit more due to wire resistance and inverter inefficiencies..
11-29-2016, 02:11 AM
Year: 1994
who's got the best price on panels right now. I heard a mention of California company green something maybe? they make there own. 100 or 139?
11-29-2016, 02:35 AM
Year: 2005
Maybe it was these guys?
Buy Solar Panels, Solar Power Kits, DIY Solar Panel Kits for Sale
When I get ready to get my panels I don't necessarily care if they're made in USA, just so they're not made in China.
11-29-2016, 07:06 AM
Chassis: thomas
Engine: 8.3 cummins
Rated Cap: 11 window
11-29-2016, 07:32 AM
Engine: T444e
We got all our components, including panels, from Solar Panels from Wholesale Solar. They were very helpful and the prices seemed comparable to, if not better than, most. Probably not as cheap as building your own system, though.
11-29-2016, 08:37 AM
A hair dryer is 1500 w at 120v, not 12.
the site also talked about a 15-20% loss during the conversion process from 12v to 120v.
Originally Posted by jazty
Not quite 214Ah ☺️
11-29-2016, 09:31 AM
True! It runs at 120v, but it's 1500w. That 1500 watts is static and can be used to calculate the amps for other voltages as well.
1500w at 120v converts to 12.5 amps (1500 / 120). That's why it can run on a 15a household breaker, but may trip if other appliances are also run.
1500w at 12v converts to 125 amps (1500 / 12). That's the relationship between watts, amps and volts.. Since you're trying to figure out the draw on the batteries you need to use the bank voltage which is 12 volts. Add the inefficiencies later.
20% is way on the high end for losses. If you size you're wiring appropriately you'll probably be closer to 10%. Resistive devices (in this case the heating element of the hair dryer) don't lose as much efficiency as motorized devices (e.g. circular saw) when used with a modified sine wave inverter.
Now looking at my last post if you tack on 20% to 25Ah you're up to 30Ah. Not a significant difference, but it's sad to see those electrons wasting away...
