Old 03-28-2008, 09:12 PM   #1
Coachwork: international
Engine: 7.3 diesel
Rated Cap: 54
Soundproofing - quieting the cabin
Anyone else have a 7.3l diesel motor in their skoolie?? well i do, and it is LOUD. the firewall is paper-thin and it just doesnt cut the engine noise like a skoolie should. i want to put speakers and a stereo in it, but until i cut down the road noise their is no point.
other than expensive dynamat, what can i do to soundproof the inside of the bus? i was thinking using old egg cartons. just kidding. but could i use some cheap foam spray? carpeting? any ever done this before?
california dreamin is offline   Reply With Quote
Old 04-02-2008, 02:56 PM   #2
Xtevan's Avatar
Coachwork: BLUEBIRD
Re: soundproofing/quieting the cabin
I have been wondering the same thing. About half of the factory insulation on the inside of my engine cover(TC2000) is missing and I think I want to redo it better than the factory did. Would really like to see how they did the engine cover insulation on the FE Wanderlodges. I have a section of dynamat that is stapled to the inside of a closet door in the garage, I need to peel it off and look at it closer. I'm wondering if there is comparable flame retardant material available by the the yard at MacMaster Carr.
Xtevan
Xtevan
Bus Project Pictures
http://picasaweb.google.com/XtevanofthePlaya
Xtevan is offline   Reply With Quote
Old 04-07-2008, 10:32 PM   #3
Engine: 7.3 diesel
On mine I pushed carpet and padding up on the firewall. It seems to help but when I decide to open the right side window or jackknife door it does make it harder to hear the radio unless it is at full level. My speakers are in the front panel above my head.
I'd say the more you stuff at the firewall the better results you will get. I did get my padding for free and the throw away carpet on top. I think it was removed from a house cause someone didn't like the color. This stuff use to look new.
Don't the Wanderlodges also carpet most of the inside too to help deaden the sound. Carpet really does help kill the sound and gives a little insulating too.
Old 04-08-2008, 08:05 PM   #4
I have the 7.3 , yes it is loud ,I found this stuff called Rattle Trap..Its better than dyna mat and a whole lot cheaper..
colliervilledave is offline   Reply With Quote
Old 04-08-2008, 08:11 PM   #5
SD26's Avatar
Coachwork: Goshen
Chassis: E350 Ford
Engine: 7.3 Power Stroke
Rated Cap: 10
Some cover the down pipe with an exhaust wrap. Have never done mine, but some say it really helps on other boards.
SD26 is offline   Reply With Quote
Old 04-27-2008, 02:30 PM   #6
Engine: 7.3 diesel
Rated Cap: 54
i recently came across a large amount of free carpet padding. i will soon take apart the front of the bus and secure the padding everywhere i can. in places i will use dynamat but not everywhere because dynamat is not cheap. i think the carpet padding will work fine if i glue it down, and use it EVERYWHERE. i even bought a $5 can of spray foam to see how well that works. pics to come.....
Old 07-08-2010, 10:55 PM   #7
NewSkewlHauler's Avatar
Engine: 8.2L Detroit N/A, Allison
I was looking at a similar product for use as a headliner for my bus. I wonder how expensive the Bondedlogic stuff is for a roll. I was quoted $155 for a 4x125 ft roll of similar stuff. I do like the backing on this better...I might have to contact the company as well. Thanks for the link!
Ben.
NewSkewlHauler is offline   Reply With Quote
Old 12-28-2014, 11:03 AM   #8
Year: 1980
Chassis: c70
Engine: 8.2l dd
has any one tried rock wool sound deading inslation it is about 2 inch thick and is fire proof
michellep is offline   Reply With Quote
Old 12-29-2014, 05:04 AM   #9
Coachwork: IC
Chassis: CE300
Rated Cap: 32
closed cell foam is going to perform the best. That's what dynamat is made of.
Look for a cheaper/generic version of that.
Old 12-29-2014, 09:35 AM   #10
I used carpet to cover the firewall and floor under the drivers seat, I also covered my stair well with a cover and that makes a big difference in for noise, wife and i can talk to each other almost in a normal voice.
Cabin Heating, Water Heating Locutus Heating, Cooling and Appliances 2 11-01-2014 04:34 PM
Solar Hot Water Panels + Bus Cabin Heater??? Benny Conversion General Discussions 9 05-21-2012 03:05 PM
cabin heater cores and framing questions the_experience03 Conversion General Discussions 5 07-31-2007 09:45 PM
Instructions for quieting a Generator Roasting8 Conversion Tutorials and How-to's 26 03-06-2007 12:08 AM
Quieting a front-engine bus Jarlaxle Conversion General Discussions 3 03-21-2006 02:08 PM
