Old 05-30-2018, 10:38 AM   #1
Spray insulation
We just finished putting the rustoleum on the floor and going to lay a grid down then plywood then flooring. We are going to do spray foam ...after we lay the grid down should we frame the walls then spray foam everything? We were just going to have a company do it so we don't want to have to have them come twice. The question is what order do we do things in order to use spray foam in the whole bus. Thanks!
toomanydogs is offline   Reply With Quote
Old 05-30-2018, 11:51 AM   #2
brokedown's Avatar
I had a company spray foam my bus. Front and back, walls and ceiling, including the pocket below the chair rail. It's not cheap and it's pretty messy, they spent way more time on prep and cleanup than they did on actually spraying foam.
I had mine fully stripped to a shell when they got there. Walls and ceiling removed, bare metal floor.
Old 05-30-2018, 11:57 AM   #3
Okay so you insulted before framing or doing anything with the floor. You framed on top of the spray foam correct
Old 05-30-2018, 12:00 PM   #4
brokedown's Avatar
I'm still framing, but yes everything will be done over the insulation. After the spray foam I am also using additional XPS in many places.
http://www.skoolie.net/forums/f11/ou...tml#post267950
Old 05-30-2018, 02:29 PM   #5
Sasquatters's Avatar
Coachwork: Thomas EF
Definitely foam before anything else. Framing would come first if you were spray foaming inner walls, but there's no point in that.
Our Blog | Facebook | Instagram
Sasquatters is offline   Reply With Quote
