Old 10-04-2010, 07:47 PM   #1
(Spray) Paint Job. Pre/Post prep.
Hey guys. I've done a lot of lookign around on the internet for finding information on the best possibly way to paint a bus. I've definatly found some good tips, but I still have some questions I was hoping could all be answered in one place.
Our bus is being converted into a mobile art platform. It will be a huge sound stange on wheels, and at the same time, a mobile piece of art. So we really want to make sure that the exterior paint job is done properly. As it stands, it is a regular school bus right from the school board. Our artist will be using high quality spray paint to paint the bus. First off, I want to make sure that the surface is prepared properly. Some places I read talk about just sanding the surface with 150 grit sand paper, then cleaning with acetone. Other places mention primer. Should we plan to apply primer to the entire bus after it is sanded before painting it? Also, the school bus is mostly metal, with parts that are fiberglass as well (the hood). Would you prepare the fiberglass areas the same as the metal ones? (Sanding, priming, sealing, etc?)
Once the bus is properly primed and painted, what do you suggest to coat the bus in to ensure that it is sealed and protected from natures harshest elements? I am brand new to the bus conversion process, and even more new to vehicle painting so I really do appreciate all your help and tips. Like I said, we want the best possibly paint job done, without having to worry about this massive piece of art peeling, or diminishing due to the fact that the final paint job wasn't protected properly. Thank you all!
Baran
-BassBus
bassbus is offline   Reply With Quote
Old 03-09-2011, 09:10 PM   #2
Coachwork: Ford B-series AmTran
Engine: Cummins 5.9 L
Re: (Spray) Paint Job. Pre/Post prep.
Bump. I'm wondering the same thing.
headin2MT is offline   Reply With Quote
Old 03-15-2011, 10:31 PM   #3
Mostly it depends on how expensive a paint job you want. I would suggest you either get something like, "How to paint your street rod" or how to paint a car book, or you can look online as well. It is no different for a bus, just takes more paint. Normally for something like a bus you will have some rust areas that need completely cleaned or sandblasted, some peeling, and the like. a cheapie paint job would just sand over the areas and maybe the whole thing a bit or even scotcbrite the good areas and shoot the thing with equipment enamel, which white usually costs me around $25.00 a gallon at the automotive paint store. You will find most employees helpful in those stores if you just tell them what you are doing. If you are doing a normal paint job on a bus, you should start off around 100 grit or so, (depending on the repairs needed) and use the DA and final wet sand around 400. If i were doing it and not using a urethane product, i would use basecoat/clearcoat finish. You could easily spend up to $1000. for paint and clear coat and hardners depending on the color, product line and clear coat thickness. Reds are getting expensive a gallon, but if you use something like Trinity paint co. which has a website and i think also sells stuff on eBay, its way cheaper, and we have painted several cars with their products.
If you are going to paint a mural or someting on it, you will need to do very good prep work, and use lots of clear coat, as people will be examing it closely... hope this helps
Old 09-09-2011, 05:47 PM   #4
bus-bro's Avatar
Engine: 3208 na boat anchor
I just painted my bus with an Industrial Acrylic Enamel paint, applied with an airless sprayer. It turned out beautiful, really. The paint costs about twice what Rustoleum does, but it's water cleanup, so no paint thinner to purchase or to dispose of.
It took a gallon and a half to paint (I had previously painted the roof white). 3 days to prep, 1/2 hour to paint.
Old 09-10-2011, 02:16 PM   #5
bus-bro's Avatar
This is what my airless applied Acrylic Enamel paint job looks like. Machinerey Green.
Old 09-10-2011, 03:00 PM   #6
bus-bro's Avatar
Me thinks it's a Wagner. It's the kind that you put a 5 gal. bucket of paint under.
Old 09-10-2011, 03:44 PM   #7
lornaschinske's Avatar
Rated Cap: 89
I painted our old Apache popup with a Wagner hand held electric airless sprayer (one of the cheapie ones) and it gave a decent paint job (Rustoleum Enamel - Hunter Green). It made for a slightly textured finish but I sprayed it on the "low" setting. I don't think I thinned the paint at all.
large pic of the Apache is here I have been having trouble viewing the site. So you might not be able to get the pics to load.
Fulltime since 2006
Old 09-10-2011, 04:13 PM   #8
bus-bro's Avatar
The problem of using oil based paint with an airless with the gun on a hose is, IMHO, the amount of solvent one would need to clean the thing. I had 50' of hose, which is nice, in that you don't have to move the pump as you paint; but more hose=more solvent. I probaby used 20 gal. plus of water for equipment cleanup. I'm sure I'd use a whole lot less thinner for cleanup.
My knowledge for use of the airless sprayer is limited to how to prime, pull the trigger, and paint. If I really knew how to spray paint, my bus' paint job would of been perfect. Such that it is, this project gets a solid B.
Don't know how durable the acrylic paint will be, but after all, it is industrial equipment paint. It should at least help me hide it in the blackberries for a few years.
Old 09-10-2011, 05:26 PM   #9
Stuff's Avatar
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
anyone have tips for painting fiberglass?
Old 09-11-2011, 10:33 AM   #10
bus-bro's Avatar
On new FRP, I used a plastic primer that comes in a spray can, purchased from the local big box store. Regular topcoat. Has worked well (for all of 3 weeks so far).
Floor prep? Bureau602 Conversion Tutorials and How-to's 5 07-30-2014 10:10 PM
jasco Prep and Primer MissJaneStrummor Short-Bus Conversion Projects 12 02-21-2014 07:33 AM
Paint prep opus Conversion General Discussions 14 07-22-2010 04:10 PM
Best spray gun for painting?? paul iossi Conversion General Discussions 2 05-15-2009 11:35 AM
can transit bus people post too? jakes and paint questions kbunnystarr Conversion General Discussions 0 11-07-2006 01:52 PM
