Old 02-15-2016, 01:49 PM   #1
Dana's Avatar
Rated Cap: 36 adults
Strange Sized Escape Hatch!
I have a 1995 International 3800 bus, Thomas body. It is a ex-Military (Navy) transport bus and not technically a "School Bus".
One of the escape hatches is missing the door.
The problem is my roof opening and the escape hatch are NOT like all the replacements I can find online. Most Transpec and Specialty escape hatches fit in a 23" x 23" opening. My opening is 23" x 21.5".
Has anyone out there run into this problem?
Dana is offline   Reply With Quote
Old 02-15-2016, 02:37 PM   #2
Engine: GMC
Rated Cap: 42
I have not run into this problem and maybe someone else can give you a source for the odd dimensions of your hatch. But, you might think about putting something else there, like an air conditioner or a vent fan or use it to put a chimney in for a wood stove.
JA Savage is offline   Reply With Quote
Old 02-15-2016, 02:43 PM   #3
Sounds simple enough to "cut to fit", but...I don't recall ever seeing a roof hatch that did not leak unless it was brand new.
Old 02-15-2016, 03:09 PM   #4
Dana's Avatar
I have looked at boat hatches but they all require a flat roof.
Cutting the hatch up to fit would not work as the door would need to be cut too. Because the opening is too narrow side-to-side I could cut that, but the opening is too long from t-to-back (over 23" actually) I would need to add about 1.5" of roof to get a good mounting surface for the screws and seal.
I can't be the ONLY bus to have these type of escape hatches.
Old 02-15-2016, 06:10 PM   #5
Dana's Avatar
http://www.skoolie.net/forums/member...ture12630.jpeg
http://www.skoolie.net/forums/member...ture12629.jpeg
My door is more square than the standard rounded escape hatch.
Old 02-15-2016, 06:46 PM   #6
Hank's P-O-S's Avatar
Coachwork: Tomas
Engine: T444e
Rated Cap: 54
Do you really need the hatch?
I would suggest removing it and covering the hole over with some 14ga sheet metal and self taping screws.
That seems to me like it would be the bust option.
"...Baler twine tie downs goin' down the road
On two bald tires and an oversize load..."
Hank's P-O-S is offline   Reply With Quote
Old 02-15-2016, 07:01 PM   #7
Dana's Avatar
Thats an option, but one of last resort. We'd rather not eliminate the hatch.
We were thinking of using a sheet of Lexan if we can't find a hatch.
Old 02-15-2016, 07:39 PM   #8
Coachwork: Tomas
Engine: T444e
Rated Cap: 54
Don't use lexan. It is not UV resistant and will go foggy and crack.
Old 02-15-2016, 08:08 PM   #9
Dana's Avatar
I contacted the manufacturer and he said:
Acrylic AKA Plexiglass we sell is completely UV stable Acrylic does NOT yellow in the sunlight.
My father-in-law has a Lexan rear window in his 1966 Dodge Coronet drag car. Even after years (9+) in the Florida sun it has not cracked.
Old 02-15-2016, 08:37 PM   #10
Coachwork: Tomas
Engine: T444e
Rated Cap: 54
Hmmm. Ya learn something new everyday!
I had assumed that you would just be using plexiglass.
You might want to look into polycarbonate. It is carbon fiber reinforced acrylic.
A guy I know has made several fairly large robots out of the stuff.
escape, escape hatch, roof
