Old 06-27-2016, 05:43 PM   #1
Chassis: Blue Bird
Question Subfloor Material
My project is coming along well, but I could use some advice on material for the subfloor. I want to use a type of plywood that will sit flat and solid on top of my rigid floor insulation and be a good anchor for studs and screws. The flooring guy at my favorite wood supplier didn't know what kind of wood would work for this application. Whatever I use needs to be able to handle more extreme humidity changes than a typical home, since the bus will be moving around a lot, and seeing a variety of climates.
If you've passed this point, what did you use? Are you happy with it? What kind of plywood works best for skoolies? Do I need to go full-on marine grade?
As always, any help is appreciated.
Thanks,
-Ike
Ikewit is offline   Reply With Quote
Old 06-28-2016, 06:01 AM   #2
superdave's Avatar
Chassis: thomas
Engine: 8.3 cummins
Rated Cap: 11 window
i used 3/4" advantech t&g and 2 1/2" self tapping screws over 1" ins.
my build pics
Old 06-28-2016, 08:38 AM   #3
Chassis: Blue Bird
Thanks, Dave. I had been told that OSB made for bad subflooring, which put me on this quest. However, this product looks to be just what I need in terms of moisture resistance. Are you confident that Advantech osb serves as a good anchor for your build up? Since the bus is often in motion, I worry about added lateral stress causing splintering/weakening at the screws. I love that it's tongue and groove installation.
Old 06-28-2016, 10:04 AM   #4
Marine ply is far and away the best choice for a wooden subfloor.
Old 07-19-2016, 05:48 PM   #5
Year: 2008
Good, so I will go with marine as the subfloor wood. What is the best typr of insulation to use subfloor though? I have a limited budget so I want the mist bang for my buck.
Pudgewomper is offline   Reply With Quote
Old 07-19-2016, 07:01 PM   #6
cheryl_ann44's Avatar
Chassis: International 3800 chassis
Engine: T444e
Not yet putting down floor but glad of info as I had same questions
Biggie for me is what to do about holes in floor
One person used pennies but that would cause unevenness right
Cheryl Ann
Blessed to be Alive!
cheryl_ann44 is offline   Reply With Quote
Old 07-19-2016, 07:44 PM   #7
Year: 2008
https://thecrabshomestead.wordpress....er-school-bus/
This was a pretty cool blog I found and they had some pretty good ideas about what to do with the holes and such.
Old 07-19-2016, 09:20 PM   #8
Engine: T444e
Thanks I had not read that one
Preciate it
Cheryl Ann
Old 07-19-2016, 09:53 PM   #9
Year: 2008
You're very welcome. I am on the demo phase myself. I have big plans for my bus and I'm really excited to get started.
Sent from my SAMSUNG-SM-G891A using Tapatalk
Old 07-19-2016, 10:28 PM   #10
Engine: T444e
Yeah me too although mostly researching right now it is just too hot and I am doing all myself and I am not young anymore
Cheryl Ann
Old 07-27-2016, 02:45 PM   #11
Smile Great Blog for tips
Awesome Blog! Step-by-step How-To
Thanks for posting the link!
Cbakes is offline   Reply With Quote
flooring, interior, material, plywood, subfloor
