Originally Posted by texasrednek
The only problem I can see with Nats idea is that if you go down a rough road and there is enough vibration or flex in the bus the skim coat could flake off. What about buying textured panels like they use in public restrooms on the stalls and paint it with a flat or matte paint? You will still see seams but you could use the same trim they do.
The panels your talking about are called FRP.
I used the stuff in the bathroom of my "Cabin build for the old timer" build.
Cabin build for Old Timer - Pirate4x4.Com : 4x4 and Off-Road Forum
I will also be using the stuff in my bus. I trim it out with oak trim. The oak trim takes away the commercial look and feel VS using the FRP trim.
I will also be using wood look vinyl plank on my walls.
Laminate should not be installed anywhere in a bus. Vinyl plank is the best product in a wet bus environment.
Nat
