Originally Posted by rhoyerboat
I have been scraping bus rubber up off of the floor for almost 10 hours now, with the claw of a hammer .. alongside seat / mid-chassis heater tearout. I think I am a little less than 40 percent done. (and very tired.)
It was way easier when it was hot outside, which makes me think heat gun would make the rubber come out better .. but I also wonder what kind of solvent I can use to deal with the rubber and glue without contributing as much to corrosion.
Best practices? 1983 GMC.
I know that this is an old post, but thought I'd share our experience for those in future who search for answers!
We had only rubber, no plywood, glued to the floor. I've never had to rip up an old plywood bus floor, but my suspicion is that rubber alone is far more difficult to remove then sheets of plywood. We started out with a hammer and crobar, tyring to peel it up, and it would have taken us a lifetime that way.
So, we borrowed a hammer drill, and bought a 4" THIN chisel. We got 220 sq ft done in 2 hours. One of us (the stronger one of us
) handled the hammer drill and the other one of us pulled up on the rubber as the chisel pushed a path forward. I figured out towards the end that if I matched my pull speed with my partner's chisel speed, that the rubber wouldnt keep ripping up in tiny pieces. Our record was a strip of about 5 feet (4 inches wide).
Back breaking, knee breaking work. But absolutely worth it. I think a wider chisel would be even better, 6-8".
Now, we are on to the next challenge, remove all that glue
