Old 11-19-2015, 10:13 PM   #41
Engine: 190hp 5.9 Cummins
I have also broken the solid stem hitches.
Most of the time, it's years of use, a small crack get's bigger, then they rip apart.
The constant pounding takes it's toll. Always inspect your stuff each time you do your walk around.
Old 01-17-2016, 05:44 PM   #42
Wow this thread took a strange turn. I would like to add a 3rd option of towing to this conversation.
What about using a trailer that holds just the front axle of the vehicle?
So now theres flat toping by dragging the vehicle behind the bus, the down side sounds like while turning is staining the front axles of the vehicle being towed.
and theres towing a dual axle trailer with the vehicle on top of it. whats the downside to this?
Pshots is offline   Reply With Quote
Old 01-17-2016, 05:56 PM   #43
2kool4skool's Avatar
Car dolly behind our BB.
Don, Mary and Spooky the cat.
Old 01-17-2016, 06:28 PM   #44
And how well does that tow 2kool4skool? Does it hide away nicely when not in use?
Old 01-17-2016, 06:41 PM   #45
As they say, never know it's there.
Not sure how to hide a 500lb dolly but here it is empty.
Old 01-17-2016, 07:23 PM   #46
if your neon is a automatic you could flat tow it, other wise you have to use the car dolly like you did. That was one of the reason's why I bought a chevy sonic, it can be towed four down with a automatic tranny.
Old 01-18-2016, 04:05 PM   #47
? Flat towing most automatics will overheat the transmission. You'd want to confirm the manufacturer OKs flat towing at highway speeds.
cbear is offline   Reply With Quote
Old 01-18-2016, 05:43 PM   #48
Some autos are capable of being flat towed. Saturns and some GM's IIRC.
Old 01-18-2016, 06:05 PM   #49
yes, check the manual , there's quite a few auto's you can flat tow, the Honda crv up to 2015 model, was preferred with most of the rv owners, but they changed and are no longer ok to flat tow, my sonic can, but if you have the turbo model it can't, there's a guide you can get on line that tells what models with a automatic can be flat towed, much easer then a dolly
