Old 07-23-2008, 10:42 PM   #1
GoneCamping's Avatar
Re: Transmission fluid issues.
I agree, sounds like a manual trans if it doesn't have a dipstick... If it is automatic, you can always crawl under and see where the tube comes out of it and goes up...or you'll see a hole where the tube goes! I'm guessing you have a manual trans though...
*Cliff*
...Your home has brake lights
1994 Jeep Grand Cherokee
Chesapeake, Virginia
GoneCamping is offline   Reply With Quote
Oil Pressure and type of Tranny Fluid?? jjonesak Conversion General Discussions 7 02-01-2019 02:27 PM
tractor hydraulic fluid, can I use it? jlhollowx13 Mechanical and Drivetrains 6 08-04-2013 09:46 AM
What is this fluid reservoir? hojjifiremaker Mechanical and Drivetrains 5 06-02-2013 05:26 PM
Whats that fluid in the heater butcher_boy Conversion General Discussions 2 05-13-2010 04:52 PM
Automatic Transmission Fluid Leaking wdbowers Conversion General Discussions 3 07-02-2008 11:17 PM
