Old 09-26-2014, 12:42 PM   #1
Year: 97
Coachwork: Me!
Chassis: BB
Rated Cap: 44
Transmission swap info
Mods, can we make this a sticky?
All, we have probably all wished for more speed and better fuel economy, especially those of us living with a AT545.
I hope we can compile information we have all found in this location on various tranny swaps. I will be swapping my 545 out as soon as I can find a replacement. Looking at an md3050 however I've recently found that an Allison 2000 maybe be a better swap.
http://www.4btswaps.com/forum/showthrea ... ide-thread
Ponyracer is offline   Reply With Quote
Old 09-29-2014, 08:47 AM   #2
Elliot Naess's Avatar
Engine: 5,9 Cummins
Re: Transmission swap info
If my Allison ever fails, I would want to swap to a manual tranny. So any information on that would be most welcome.
Elliot
Old 09-29-2014, 09:12 AM   #3
r_w
+1 on a manual swap.
As for auto swaps--the most straightforward path IMO is buying the entire engine/tranny combo. I think you are money ahead vs. piecing together all the sensors and such to get a computerized tranny working on a two-wire engine.
r_w is offline   Reply With Quote
Old 09-29-2014, 09:42 AM   #4
Year: 97
Coachwork: Me!
Chassis: BB
Rated Cap: 44
Depends, from my research so far, most of them use a self contained controller that only needs a throttle position sensor so the tranny knows what the engine is doing.
+10000000000 on the manual swap. Don't think that's possible on a flat nose FE bus? LOVE to swap in a G56 out of a newer ram. Had one in my 07 3/4 4x4 cummins ram and that tranny was a beast!
Old 09-29-2014, 10:08 AM   #5
r_w
It should be. You will need a cable operated shifter like from a cab-over truck, but that isn't too hard. I haven't checked vertical clearance yet, you may need a bump in the floor for some trannies. That would be another limit to your floorplan but could be worked around with a side aisle or center table limo bus style.
That is pretty much off the table for me because I want my wife to be able to drive. I know she will only drive it on the highways when there is no traffic or construction, but that is at least a breather for me.
I am still looking for a non-545 bus to avoid this problem from the start. But if a deal too good to pass up comes along, I will cross that bridge.
What ever happened to two-speed rear ends?
Old 09-29-2014, 01:42 PM   #6
Year: 97
Coachwork: Me!
Chassis: BB
Rated Cap: 44
Not sure, they seemed to primarily be used for super low then average road gears. I'd like to have a 9 speed road ranger but I'm not sure if they will bolt to a cummins. Gonna have to do some more research!
Old 09-29-2014, 02:36 PM   #7
r_w
Start drooling...
It can be done, isn't THAT hard. I have seen the 10 speed mini ranger, too. http://www.4btswaps.com/forum/showthrea ... peed/page4
There are lots of flywheel/clutch/bell housing options to tie them together. Again, it is the shifter and height issues that are new ground.
Old 10-04-2014, 06:28 AM   #8
Year: 97
Coachwork: Me!
Chassis: BB
Rated Cap: 44
http://www.dieseltruckresource.com/dev/ ... 66786.html
Some more good info when swapping from a 545 to a 1000-2000-2400 series Allison!
Old 11-29-2014, 05:32 PM   #9
Year: 1951
Coachwork: Wayne/ IHC
Chassis: L-163 International
Engine: SD240 / 4 sp.
Rated Cap: 39
My old 51 IHC came with a 2 sp when it was new. 8.33 & 6.66. It now has a single gear 6.16. All the truck 2 sp I've seen are geared like this. I've never seen one with an automatic.
Tbart is offline   Reply With Quote
366 carb to 427 FI swap!! jaredg GM | Chevrolet Drivetrain 13 02-18-2015 09:01 PM
GMC 6.2 swap bapos Mechanical and Drivetrains 23 11-26-2012 12:13 AM
Automatic transmission swap fordsmoker55 GM | Chevrolet Drivetrain 7 03-04-2010 06:41 PM
Engine swap... abdabbs Conversion General Discussions 1 10-31-2008 01:59 AM
Wife Swap on ABC Steve Everything Else | General Skoolie Discussions 2 02-17-2005 11:19 AM
