Old 05-30-2008, 11:53 PM   #1
Engine: 5.9l Diesel Cummins
Rated Cap: 20
Upper cabinets advice needed
Hey guys, I'm going to be installing some cabinets above the seats and the length of the bus. My question is what worked best for you material wise? It looks like the "l" brackets or angle brackets work best? How do you anchor them so they're secure?
Thanks
My 1997 Ford / Thomas shorty
5.9l Diesel Cummins w/automatic tranny
Photo's of my bus build
Billsman is offline   Reply With Quote
Old 06-01-2008, 07:44 PM   #2
Rated Cap: 20
Re: Upper cabinets advice needed
Thanks Smitty!
Old 06-02-2008, 12:19 AM   #3
phillbus914's Avatar
I screwed wood directly into the roof and walls of my bus with TEK (self drilling screws) then screwed the cabinets to the wood. They have held up well except that they're made of particle board. I've had a few of my door hinges pull out. I'd strongly recommend using real wood, at least on the face/doors of the cabinets. The cabinets seem to be able to hold a lot of weight, I've had jugs of water, cases of pop, and lots of can goods in there with no problems.
Here's a picture from when I was building them, notice the end is not yet on the rt side, and you can see the wood screwed into the ceiling.
My Old Bus :(
Old 06-02-2008, 12:58 PM   #4
Engine: 7.3 diesel
I did mine like phillbus914 did only I used plywood. I pretty much copied the design in a travel trailer but I used 2x2's instead of 1x2's.
Old 06-17-2008, 09:21 PM   #5
GoneCamping's Avatar
I used Oak 1x3's to build mine, bought the doors from an ebay seller that had great prices (paid less than $3 per door)... They went up much like the others pictured above....
*Cliff*
...Your home has brake lights
1994 Jeep Grand Cherokee
Chesapeake, Virginia
GoneCamping is offline   Reply With Quote
Old 06-18-2008, 07:52 PM   #6
When one stands only 5' 7" tall head room tends to be a minor factor!! That being said, my short ceiling bus that started out with 6' of head room now has a hair over 5' 10" and MOST people can still walk around in there without ducking! The ceiling was easy to install and lost only minimal space (1.75")...
*Cliff*
Road trip travel ADVICE NEEDED! Loubnat Titles, Insurance, Registration and Money Matters 1 09-25-2014 10:43 AM
Hey I'm new here! Advice needed! on this bus in particular JiggityJohnson Conversion General Discussions 6 08-13-2014 04:09 PM
Advice needed on flooring foggymorn Conversion General Discussions 7 09-15-2006 11:06 PM
Upper Flashing Light Lenses frey2 Conversion General Discussions 3 03-07-2005 10:18 PM
Propane Water Heaters ~ Advice Needed pixie Conversion General Discussions 5 08-21-2004 10:53 PM
