Old 02-22-2017, 12:15 AM   #1
Njsurf73's Avatar
Chassis: Bluebird
Engine: 5.9 Cummins 24v
Rated Cap: 72 pax
Waste water holding tanks
Anyone use these types of barrels for gray/black water?
Old 02-22-2017, 06:59 AM   #2
superdave's Avatar
Chassis: thomas
Engine: 8.3 cummins
Rated Cap: 11 window
ya lots of people here use them, tough tanks
my build pics
Old 02-22-2017, 07:18 AM   #3
Njsurf73's Avatar
Chassis: Bluebird
Rated Cap: 72 pax
That's great, I can source them locally for $10-30. That's quite a bit less than any holding tanks I could find.
Thanks Superdave.
Old 04-09-2017, 05:06 PM   #4
Aside from taking up inside space or wrapping with insulation, what steps do they take about keeping the contents from freezing in the winter?
Bus_Bandit is offline   Reply With Quote
Old 04-09-2017, 05:24 PM   #5
Njsurf73's Avatar
Chassis: Bluebird
Rated Cap: 72 pax
Mine will be winterized and stored. But people add heaters and insulation if they full time.
Old 04-10-2017, 10:38 AM   #6
You could use heat tape around the barrel.
Old 04-10-2017, 12:53 PM   #7
roach711's Avatar
Rated Cap: 19
Several full-timers here have run heat tape around their exterior tanks then insulated over it to keep the tank from freezing. Their water supply hoses got the same treatment using some foam pipe insulation over the tape.
The Roach Motel
Old 04-12-2017, 08:28 AM   #8
Why not just drop it through a drilled hole in the top? and skip the over insulating unless you are living in Canada etc.. To each his own.
Old 04-20-2017, 09:01 PM   #9
Chassis: Thomas
Yes, I install 2 of them. I still in the building stages on my bus. I used "Uniseal" to connect the plumbing pipes. If you look a the last picture you can barely see them.
Jcrum is offline   Reply With Quote
Old 04-20-2017, 09:26 PM   #10
Robin97396's Avatar
Looks good from here..
Robin
Nobody's Business
