Old 10-30-2016, 11:03 PM   #31
How will these paint suggestions hold up in Arizona? The unrelenting sun and searing heat kills all automotive paint here. Every car more than a few years old has peeling clearcoat and oxidized paint. Horizontal surfaces are affected much more than vertical surfaces. I've read that white paint is the most resistant to UV, so I will probably paint my entire bus white except maybe the bumpers and the side impact strips. But I'm still wondering what type of paint is best to resist the UV.
Gazolba is offline   Reply With Quote
Old 10-31-2016, 08:27 AM   #32
Acetone and Mineral Spirits are 1/2 the cost of Lowes at WaLMART.
Old 11-12-2016, 05:13 PM   #33
rjnye79's Avatar
Engine: T444e
So we are wanting to use a white Rustoleum in a sprayer. Is that feasible, and which additives/ratios do we need? Do you guys remove all the fixtures (mirrors and such) before painting?
rjnye79 is offline   Reply With Quote
Old 11-12-2016, 08:59 PM   #34
rjnye79's Avatar
Engine: T444e
Originally Posted by AlleyCat67 View Post
This is the ratio that was given a few posts back:
So, by my math, that would be 12 oz of acetone and 8 oz of hardener (the whole can, if you use what was pictured) per gallon of paint.
How much would this differ if we were wanting to spray?
Old 11-12-2016, 09:59 PM   #35
Chassis: International S3800
for arizona Id paint the roof with Bus-Kote or something similar.. its made for UV as well as has heat reflective properties too...
ive been told in any crazy sun state that lighter colors are better off for resisting UV than darker colors.. part of it may also be the temperature the paint reaches when its a darker color... paint is like anything else only so hot it can get before it begins to detiorate.. the darker colors get physically hotter in the sun.. when the ambient temperature is already 120 degrees that makes for one hot surface..
Old 11-13-2016, 07:31 AM   #36
Coachwork: IC
Chassis: CE300
Rated Cap: 32
Just follow the instructions on the can.
Roll Your Own Build Thread
Old 11-13-2016, 08:46 AM   #37
rjnye79's Avatar
Engine: T444e
Thanks EastCoastCB. Can anyone tell me a comparable product from a brand other than Majic? That one seems hard to find in my area.
Old 11-13-2016, 09:32 AM   #38
Coachwork: IC
Chassis: CE300
Rated Cap: 32
https://www.amazon.com/Valspar-4625-.../dp/B000LNY1MY
Old 11-15-2016, 09:36 AM   #39
rjnye79's Avatar
Engine: T444e
Originally Posted by Goatherder View Post
This
and this
and last (but not least) this:
Got me this:
(Hi Mom!)
I rolled the top (almond) and sprayed the green. I mixed green and silver and black to get this metallic green color. You can't roll metallic. If you want to roll it, I'd thin the paint about 10% w/ Acetone, and mix the hardener about 15:1. And use a 1/4" knap roller.
Again, you can't roll metallic. It will look swirly and blotchy and like absolute sh!t. But you can roll solid colors with a short knap roller and have it come out pretty nice, especially on vertical surfaces.
Nice work! How many coats is that?
Old 11-15-2016, 10:37 AM   #40
Coachwork: Collins
Chassis: E450 Ferd
Engine: 6.0L Diesel
Rated Cap: 20 window lickin Jeffies
Coats? I dunno. I painted it twice; first time it came out a fruity green that would get me noticed in the Pride parade. Used about 3 qts then. A day later I mixed a new (darker) batch of 6 qts and used about 5 of that...so it's got about 2 gallons of paint on it. I went around the bus until my arm wouldn't hold the spray gun up.
Goatherder is offline   Reply With Quote
