Old 03-11-2015, 06:24 AM   #1
timbrass's Avatar
Location: Henley-on-Thames, United Kingdom of Great Britain and Northern Ireland
Rated Cap: 29
What would you call this part?
Any idea what the round rubber fittings with embedded brass threads would be called. They fit into round holes in the dashboard and allow you to screw the attaching bolt to them.
On mine two of the "things" are perished and I can't re-attach the radio panel. I need to figure out what they are called in order to search for new ones!
My Build site is http://schoolbusconversion.net
timbrass is offline   Reply With Quote
Old 03-11-2015, 07:03 AM   #2
Coachwork: ward
Chassis: international
Engine: dt360a
its called a well nut
Old 03-11-2015, 07:12 AM   #3
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Rated Cap: Her, me and Molly
Rubber Nut | Inserts for Plastic | Insertsdirect.com
Old 03-11-2015, 11:53 AM   #4
Coachwork: ward
Engine: dt360a
be sure to use anti-seize or your screw wont come out after a while and most of the time, you cant drill em. they jsut spin.
Old 03-11-2015, 02:41 PM   #5
timbrass's Avatar
Rated Cap: 29
While I am asking about what things do...
What is the function of this attachment to the Air Compressor tank? (some sort of safety valve??). One reason for asking is that there is a broken wire near to it, but I can't work out whether is should be attached to this "valve" - why would a safety valve need power/wiring?
Old 03-11-2015, 02:44 PM   #6
Engine: 190hp 5.9 Cummins
Air pressure sensor?
Old 03-11-2015, 03:22 PM   #7
looks like a heated auto drain valve?
Old 03-11-2015, 05:52 PM   #8
Heated Automatic AIR Tank Drain Valve DV 2 | eBay
I'm like, LIVING on eBay these days.
taskswap is offline   Reply With Quote
Old 03-11-2015, 06:32 PM   #9
Chassis: TE2000 FE
Engine: 5.9L Cummins
Yep what taskswap said. But yours looks fubared.
Chuck
cschlessman is offline   Reply With Quote
Old 03-11-2015, 09:04 PM   #10
In case "fubared" is not in the slang on your side of the "pond," it comes from the adjective "fubar," which means f---ed up beyond all repair . . . .
