Old 04-28-2017, 10:57 AM   #1
Which comes first...
Chicken or the egg...
No, but seriously, should I lay vapor barrier first THEN frame out floor put in insulation then plywood OR frame out floor, put in insulation, THEN put down vapor barrier then plywood?
mjfreespirit is offline   Reply With Quote
Old 04-28-2017, 11:29 AM   #2
Robin97396's Avatar
This is what I've been told during building code classes. I'm sure there are varying opinions.
In housing construction the vapor barior is put nearest to the outside. If a vapor barrier is put on the inside, the warmth tends to make condensation on the vapor barior surface.
Robin
Nobody's Business
Old 04-28-2017, 06:18 PM   #3
Stu & Filo. T's Avatar
Coachwork: Crown / Pusher
I have plywood floor & this is what I did
Treated floor with 3 coats Red Guard.
Lay down vapor barrier, extend it up side 6in.
Layed down 2in styrofoam insulation.
1 1/8 in T&G subfloor
I talked it over with a contractor friend of mine & that's what he recommended .
Old 04-28-2017, 07:07 PM   #4
Robin97396's Avatar
That's the same method. Vapor barrier goes on the cold side.
Robin
Nobody's Business
Old 04-29-2017, 07:37 AM   #5
Rated Cap: 42
Absolutely, always put the vapor barrier to the outside. You def don't want to have condensation forming in your subfloor!
Sent from my MotoG3 using Tapatalk
ghodges is offline   Reply With Quote
