Old 08-23-2010, 04:54 PM   #1
Window A/C with inverter and large alternator
I have a rat rod ambulance which is like a shorty bus but with a lot more insulation and no windows except little ones in the two back doors. On ebay I can get a 3000 watt inverter. A 7000 BTU window a/c unit uses around 3000 start up (compressor kicking on) watts and about 900 watts after the compressor is on. If I get a high output alternator, why can't I go down the road with this. Why do you guys say I need a generator? Any help will be appreciated. Thanks.
rvlifenow is offline   Reply With Quote
Old 08-23-2010, 08:51 PM   #2
lornaschinske's Avatar
Rated Cap: 89
Re: Window A/C with inverter and large alternator
Don't go below 3K genset. Not much diff in $$ when buying used. I would even go so far as getting a 4K genset. Used you are looking at about $100 per 1K power (4K genset is selling for $400 or less on craigs list)... at least around here. Use www.craiglook.com to search your area.
Fulltime since 2006
Old 08-23-2010, 08:53 PM   #3
Rated Cap: 89
Don't go below 3K genset. Not much diff in $$ when buying used. I would even go so far as getting a 4K genset. Used you are looking at about $100 per 1K power (4K genset is selling for $400 or less on craigs list)... at least around here. Use http://www.craiglook.com to search your area.
Fulltime since 2006
Old 08-24-2010, 05:57 PM   #4
Stuff's Avatar
looks sweet!
Old 09-12-2010, 09:50 AM   #5
Year: 89
Chassis: Thomas
Engine: 8.2 L Diesel
Not relivant but what do I need to do to see picture gallery ?
eugene1617 is offline   Reply With Quote
inverter- alternator size gseufzer Electrical, Charging and Solar 6 04-19-2011 11:01 AM
Looking for a large converted Bus for a Non Profit bus52 Classifieds | Buy, Sell, Swap 1 01-26-2011 05:13 PM
Installing a Large Diesel Genset BigBusParts Conversion Tutorials and How-to's 2 01-07-2011 01:48 PM
large weight at the very rear of the bus icnivad Conversion General Discussions 2 02-13-2009 08:58 PM
WTB a LARGE door off of a bus. crazycal Classifieds | Buy, Sell, Swap 9 03-30-2007 11:05 AM
