Old 02-16-2018, 10:37 PM   #1
msearslive's Avatar
Window AC Unit or Rooftop Fan??
We have our short bus insulated on the top and sides throughout with 3M Thinsulate. I cannot speak for other types of insulation, but this stuff has been amazing ... in the fall/winter. My concern is when we hit the road on May 1st for a year and we are ANYWHERE in the United States BUT cold regions, haha. (We plan to quite literally follow the warm weather wherever it goes during fall/winter seasons.)
That said, we are struggling between whether we want install a rooftop fan or if we should install a small window AC unit. The unit we are shopping right now is this one:
https://www.amazon.com/dp/B06WRRZLYB...META93KV&psc=0
The fan we're leaning toward is the MaxxAir 7000K model. That link is here:
https://www.amazon.com/dp/B003ZOF09Y...META93KV&psc=0
Wondering if anyone has input or suggestions based on their own experiences. (I'll take suggestions and opinions regardless, but if you have a window unit or a rooftop fan (or both) - I'd love to hear your thoughts.
Being that we are intending to be in warmer climates as much as humanly possible unless, say, a cold front blows through or something like that - I just don't know if one is better than the other as far as keeping it cool-ish in the bus. As I stated earlier, we do have what I would like to consider a strong protective layer of insulation, but I'm not so sure that's going to keep the bus cool.
We were unfortunately forced to rip out the original AC that was built into the bus originally due to corrosion and leakage and just all-around grossness. If we install a window unit we're thinking of putting it in one of the far back windows of the bus. The concern I have with this is that 1) I think it might freeze us out while we sleep. I could be wrong. However, this unit is described as intended for up to 150SF of space and we're looking at what, maybe 90SF of space all together in the short bus? Something like that. 2) I'm not convinced that even with a smaller window unit like this that it won't drain out two 100Ah batteries overnight while we're sleeping. (We do have LiFePO4 batteries, not AGM deep cycles).
While we aren't expecting nor attempting to achieve the absolute conveniences of living our regular lives like we do now in our townhouse; we also don't want to wake up dead from the heat. (Forgive the humorous attempt at that oxymoron there.)
Thoughts and suggestions? I SUPERBLY appreciate any feedback.
msearslive is offline   Reply With Quote
Old 02-16-2018, 11:07 PM   #2
Chassis: Saf-T-Liner MVP ER
Trying to run AC on battery power usually ends up being an exercise in frustration.
The unit you linked runs around 4 amps @ 120V = 480 Watts
Multiply that by, say, 5 hours = 2400 Wh and divide by 12 for Amp Hours
= 200 Ah.
If it has a 50% duty cycle, then your batteries would be down to 50% capacity in 5 hours.
That ignores inverter losses and any other loads.
Please ... anyone, if my math is wrong, correct it.
Steve Bracken
Build Thread
Old 02-16-2018, 11:47 PM   #3
msearslive's Avatar
= 200 Ah.
I am SUPER curious as to how you did that "electrical" math! (This takes of a bit off topic, but I have to know this! I feel it's very very important as "Wilson" (our bus) will be our full time home while we're out on the road. This is also why in another post you responded to earlier today (thank you very much, btw) I was asking about alternative ways to juice up the two 100Ah LiFePO4 batteries that we purchased for the "house" portion of the short bus.
So the only thing I have come up with was as follows (and I clearly have something misunderstood - NOT surprising though).
So I was under the impression that:
Watts = Amps * Volts
Amps = Volts / Watts
Volts = Watts / Amps
Again, hahahah! I am very much likely wrong. So when I saw the 4amps on the website I actually thought, "Ah, okay. So if I run the AC all night at 6 hours (typically my normal sleep cycle and I'm well rested) than that would be 4amps * 6 hours = 24 amps. I immediately told my partner (Carolyn) that this couldn't possibly be right.
I'm actually have all of the electrical belongings that we're planning on having in the bus and I have all their amps and watts and I THOUGHT I had converted them correctly.
At any rate, I hope to nail down these formulas soon so I can properly determine what I'm really going to be using energy-wise.
With alllll that said - yeah if I'm using 200Ah to run that window AC unit for one night - that absolutely will never work. Those batteries are about $900 a piece - super not cheap IMO. I'd rather not by another one because we only have two 200watt solar panels. Even if the peak time of the sun gives me a full on 6 hours to charge the batteries, I don't think I'd be able to juice the lithium batteries to 100%.
I do know from research and conversation with the company I bought the batteries from that these batteries can be drained to practically zero and it will not hurt them. I also read they last years and years and years as opposed to regular batteries.
Maybe I should be going with the fan. Have you ever used one? If so, does it work decently in the heat? With all the insulation we've put in - do you have an opinion on whether it might be fine to just go with the MaxxAir rooftop option?
Thanks.
Old 02-17-2018, 01:42 AM   #4
Thomas1985's Avatar
Chassis: GMC G3500 Vandura
Engine: V-8 5.7L Gas
You should be able to get a 228ah six volt battery for nearly $400. You could run and energy efficient fan for a little while but not an air conditioner. I'm still using a generator for that. My solar is for lights and chargers.
Thomas1985 is offline   Reply With Quote
Old 02-17-2018, 09:33 AM   #5
Okay ... Google is your friend because it will show you worked examples, but briefly:
There are a bunch of units and terms that all take their lineage from the Ohm's Law you stated in your post.
The problem is that other terms are thrown in, like Amp Hours and Watts and Watt Hours.
So for your issue we can work out your power requirement in Watt Hours, but your battery capacity is measured in Amp Hours.
So we have this situation:
4 Amp consumption @ 120V uses 480W per Hour.
Multiply that by 5 hours giving 2400 Watt Hours. That is the total power consumed in 5 hours at 100% duty-cycle.
However, that energy was supplied at 120V and the batteries supply 12V, so to get the AmpHour consumption we divide by 12
2400 / 12 = 200 AmpHours. I assumed a 50% Duty Cycle for 100 Ah
To solve your problem you will need either to plug into shore-power, or have a much bigger battery bank.
And yes, the math does my head in too which is why I asked for any corrections, but I think it's right.
Steve Bracken
Build Thread
Old 02-17-2018, 11:05 AM   #6
Engine: TE 444
Rated Cap: 12
Think of a watt of electricity like a gallon of water, no matter what the pressure, volts, the unit stays the same so all math with electricity needs to be broken down to watts to get it right
Old 02-17-2018, 11:10 AM   #7
I have a similar ac in my shorty. Without venting the heat from the roof while using the ac, the whole place turns into a sauna. My bus has 2" of foam insulation top, bottom, sides and one end along with dual pane windows. The room ac running full blast only manages to keep the interior 10 or 12 degrees below the outside temperature. At temps over 95 degrees all bets are off. Frankly, in order to run that unit over night you would need a trailer full of batteries to do the job. Remember, no matter how large your battery bank, you still only get to use 50% of the charge before the battery needs to be recharged or the batteries will be damaged.
Old 02-17-2018, 11:11 AM   #8
Engine: TE 444
Rated Cap: 12
And to further confuse the issue, wire size is based on amps, not watts
Old 02-17-2018, 11:25 AM   #9
Engine: CAT 3208
Rated Cap: 84 pass 36200 gvw
The actual formula is P(watts)= I(amps) x E(volts). By simple algebra
amps = watts / volts and
volts = watts / amps
You have to keep in mind that you are using two different voltages in your bus. So 4 amps @ 120v = 480 watts but @ 12v that 480w is 40 amps.
snonut is offline   Reply With Quote
Old 02-17-2018, 11:27 AM   #10
msearslive's Avatar
Appreciate the info and education on the electrical math bit. I started Googling last night, and I'm back at it today trying to make sense of this all.
I need to really remember this is one step at a time with this bus conversion. My excitement level hasn't changed, but wow - this can be a bit overwhelming when you begin to realize what all goes into this. (And math is 100% absolutely NOT my forte - at all.)
I really really don't want to by "regular" batteries for the house portion of the short bus - for many reasons. One of the biggest being that you really only get 50% of what you're purchasing. I feel like if I wanted that I'd just go to the store and buy a bag of chips - 50% chips, 50% air. (If that analogy makes any sense at all.) The LiFePO4 batteries are supposedly able to be drained practically to nothing with no negative impact to their lifespan or effectiveness. That said, those batteries are not exactly cheap. I need to decide I guess what direction I should take.
I'm now mulling over options now. When I sit down and I start doing this electrical math on all the electronics I will have in the short bus - I don't now how people do it. Here's a list of all I have originally intended to bring into the bus:
-Induction Stovetop (one burner) @ 1800w
-Two Cell Phone Chargers @ 25w (combined)
-Laptop @ 65w
-Shower Head @ 2500w
-Overhead Lighting (LED) @ 18w
-Mini Fridge @ 500w (supposedly approximately total for a 24hour period - supposedly)
-Outside electric/charcoal grill @ 1500w
-MaxxAir Rooftop fan @ 12v (i looked everywhere and could not find the watts - still looking)
Soooo, a couple things. I have a spreadsheet in Excel where I have listed all the items in the bus (like listed above), their amps, their watts, and the amount of time we anticipate using them every day. Clearly we would never use an induction stove or the showerhead (for hot showers) all day long. They'd be used minimally. For instance, we're working our way at home to get down to 5 minute showers if possible. Also, the induction stovetop cooks much faster than our stove at home so we're guessing 1 hour total a day (half hour 2x a day). Some days probably wont' even use it all. We'll cook on a grill with wood chips or charcoal or something (havent' figured that part out just yet).
My point is simply that we won't be using all this stuff all day of course.
For those of you with generators - where do you put them? We have a short bus, and in my opinion having a generator inside the unit is just not going to happen. I would imagine we wouldnt' be able to think straight much less have a conversation while it's running. I'm guessing people build a rig or something to put on the back of a hitch on the end of the bus to haul it??
Just trying to figure out options at this point.
Old 02-17-2018, 11:33 AM   #11
msearslive's Avatar
Sonut - thanks for your informative post. Do you know if it's possible to convert everything over to 120v than if the amps are less? Or is that not a possibility? My ignorance is ... not blissful. BUT, if this is possible I would think that would be the fix, right? Convert everything over to 120v since it's less amps?
I do have a 10,000w inverter that I purchased not realizing how big that was at the time. (I had - at still sometimes HAVE - no idea what I was doing at the time.)
Old 02-17-2018, 12:05 PM   #12
I'd be looking to replace some of that stuff with propane or diesel fired.
The bus can be heated with a diesel heater with a minimal draw for the fan.
Cooking can be done with propane, as can water heating. The water heater can be externally vented so it doesn't add to the condensation issues.
The outside grill can be propane too.
Electricity in an RV is a perennial issue. Without a shore-power hook-up it gets very expensive, very fast. Some high-end RVs would struggle to supply what you are asking.
If you plan any time off-grid, you need to beef up your supply.
Four Trojan T105 RE batteries would cost you around $600-700. They would give you a useable 450 Amp Hours, and if you look after them they would last years. Every two you add gives you another 225 Amp Hours of reserve capacity.
To charge them you will need a large solar array or a decent generator (or hook-up). A small inverter generator can be had for $500 and it will charge those batteries just fine. You can also run it at peak times to relieve the strain on the batteries.
Steve Bracken
Build Thread
Old 02-17-2018, 12:11 PM   #13
Engine: CAT 3208
Small (2KW or 3KW) generators are pretty quiet now and cheaper than LiFePO4 batteries. I started out the same way you did planning on doing everything with electricity. Decided it was just too expensive. So now just about everything is propane. I got a 50gal propane tank at a RV recycle place and it only takes up about the same amount of room as a couple of large batteries.
The exception is refrigeration. In my van my 4 CF refer/freezer runs on a 35 ah battery with no problem for a couple of days. Of course I am rarely parked that long without being plugged in to something. So I am putting a small freezer and a small refer in the bus. My electrical system is 200w of solar, 200 ah of batteries and a small generator. I also have a small (3500w) generator that I only plan to use rarely. My A/C will only be used when we have grid power available.
I don't know what kind of shorty you have but most buses have quite a bit of room underneath that can be converted to storage. On my van I had a hitch rack that carried my propane and a 1000w gen, after a couple of trips I quit carrying the gen.
Old 02-17-2018, 01:15 PM   #14
Engine: CAT 3208
Most of my electric equipment is 120v, that being said, it doesn't decrease the load on the batteries, in fact it increases the load because of the losses in the inverter. So 4a @ 120v requires 40+ amps @ 12v. Back when people first started going of grid they used enough batteries in parallel to get 120VDC since small appliances would run on that but most modern equipment needs VAC because of transformers and other electronics.
Keep in mind that Watts are your constant across systems, so you need 10 times the AH in the battery as you would need from the grid (AH = Watts).
One reason to use 120VAC is to avoid power losses in the wiring. My inverter is within inches of the battery and so is my charger. 12VDC has significant losses unless the wire is huge.
Old 02-17-2018, 03:47 PM   #15
Engine: TE 444
Rated Cap: 12
That is the reason RV's have propane powered appliances and heaters
Old 06-02-2018, 05:15 PM   #16
Just throwing in 2 cents
I have not yet installed an a/c unit, but I would assume that using it while the sun is out, 4 amps is very doable if you have enough solar power. Im looking at installing a 5000 btu window unit, running it during the day, the solar would overcompensate at near 600 watts and Id still have full batteries at the end of the day. When night turns, I still will have a cool interior and thus can shut off the unit. I have 4 125 ah batteries so I could probably run it an hour or so even then. We will see.
RobbllaW is offline   Reply With Quote
Old 06-02-2018, 05:37 PM   #17
How big is your bus? 5k BTU may not cool a big bus effectively.
Old 06-02-2018, 06:09 PM   #18
About 100 sq ft, just a five row window. Should be enough right? Do you think going to up to even 6k btu would make a difference? Im at home depot now, debating. And Im looking at a window unit, I dont think those rooftop units go that low, i cant run much more off solar.
Old 06-02-2018, 07:10 PM   #19
Chassis: TC 2000
Rated Cap: 65?
I'd think about another fan to pull heat out/circulate air or go with a rooftop.
I have the same fan in mine. Its 33' bumper to bumper, 2" foam in ceiling and walls, 1/2" in the floor. The fan does a heck of a job. I'm planning on 13k BTU rooftop this month. Later I'll use that henry stuff on the roof. I have a small fan inside to help move air and I think that will be enough.
Stuntmanmitch is offline   Reply With Quote
