Old 03-05-2010, 11:31 AM   #1
Year: 1983
Window skinning options?
Trying to think of a way to cover some of the bus windows without removing the windows and replacing with sheet metal. Thought about tinting but not sure I'll like the look and I've heard paint wont stick well to the glass? Saw a thread on here discussing vinyl sign material? but cant find it and didn't really grasp the concept...any ideas would be greatly appreciated.
GonzoStreet is offline   Reply With Quote
Old 03-05-2010, 03:03 PM   #2
dentedvw's Avatar
Coachwork: Thomas SafTLiner
Chassis: FE
Rated Cap: 60
Re: Window skinning options?
You could go to a sign shop and have them cut you vinyl to fit the glass.
Many folks will just limo tint them if they aren't going to remove them. Your local AutoZone, walmart, etc will have rolls of window tint. Get the darkest stuff you can find, watch some youtube videos on installing it, and go to town, so to speak.
dentedvw is offline   Reply With Quote
Old 03-08-2010, 06:57 AM   #3
Seeria's Avatar
If it helps, there are some decrorative films out there. http://windowfilmworld.com/ Has a taste. Gila makes next best thing to expensive 3M (not that Gila is cheap imo). I'm guessing you want to be able to use the windows, create privacy, insulate, or even block light? There are a variety of skins out there. Might also consider just using rigid insulation boards, pop in and pop out.
Old 03-11-2010, 06:24 PM   #4
Year: 1983
Thanks for the tips! Smitty - its still an option to just remove the unwanted windows I'm just not familiar working with sheet metal and don't wanna screw it up...any advice on how to mount it and what gauge i should use?
Old 03-11-2010, 08:37 PM   #5
jkindt's Avatar
Year: 1981
Chassis: Ford B-600
Engine: Ford 370 Propane
Rated Cap: 48
I know some have used 20ga sheet metal to fill in the windows, but what about using FRP? I ran across a sample of different FRP panels and found a nice white smooth one that looks very much like the outer skin on modern RVs. I can get a full 4x8 sheet of this stuff cheaper than sheet metal. I was thinking I could cut it to fit the window opening, attach aluminum angle to the edges so I can screw it or rivit it into place and use some urethane sealant to seal them in when I install them. Basically it would be a 'window replacement' that is flat, smooth, and very dent and warp resistant.
Old 03-11-2010, 10:29 PM   #6
bus-bro's Avatar
Engine: 3208 na boat anchor
hey jkindt, where did you get the FRP?
Old 03-11-2010, 10:36 PM   #7
jkindt's Avatar
Year: 1981
Chassis: Ford B-600
Rated Cap: 48
I found the samples at Home Depot. They have some textured panels in a few colors, and a totally smooth panel in white. They are typically used in home construction in shower stalls and such. The stuff I found has no UV protection, so I am going to have to prime and paint my panels to avoid UV degradation, but that is not really a problem, it will ensure that the paint matches the rest of my bus. I am going to do some more searching tomorrow, I find that if something is available at the orange shop, it is usually a bunch cheaper from some of the wholesale building suppliers at the other end of town.
Old 03-11-2010, 10:43 PM   #8
bus-bro's Avatar
Th@nks.
Old 03-23-2010, 03:33 PM   #9
lornaschinske's Avatar
Rated Cap: 89
Both of the RV doors on my Class C are skinned in FRP (textured). The front door is an aftermarket remodel... age unknown and it is in pretty good shape. The rear door is original to the Class C (1977). It has tiny pin holes in it. I filled the tiny pinholes with caulking and painted the door. I would not use FRP to replace the windows. But then the rear door is over 30 years old. The 30 yo aluminum skin on the CLass C also has tiny pinholes... filled with paint. We are still debating on window replacement. I do know that I do not want to keep the glass as I would hate to have to tear out the wall covering (or the shower stall) in order to repair a broken window. David shot down the fiberglass coated plywood idea I had.
Fulltime since 2006
Old 03-24-2010, 11:36 PM   #10
jkindt's Avatar
Year: 1981
Chassis: Ford B-600
Rated Cap: 48
Why not use FRP? Bond it to a piece of plywood the same size as the window opening and make sure to paint the FRP. A good UV blocking paint over FRP would keep it from degrading due to UV exposure and it is strong, waterproof, and smooth. Mine have turned out great! I just need to prime them and seal them in the window holes. They will get painted when I do the whole bus. Best of all, it is a great cheap alternative, cost less than the price of an equivalent amount of 20 ga steel.
Old 06-20-2010, 03:14 PM   #11
zim
zim's Avatar
Year: 82
Chassis: TransitLiner
Engine: Cummins 5.9l
Originally Posted by jkindt
Why not use FRP?
I did. I removed the screws from the bus windows so I could lie it flat, then used some 3/4", self drilling, self tapping pan head screws to hold it to the bus. Painted it white with the rest of the bus and caulked the seams. It's been on there for two years now with no leaks.
Project Blog @ TechnoVardo.com
zim is offline   Reply With Quote
Old 06-20-2010, 06:01 PM   #12
Rated Cap: 89
We have pretty much decided to pull the glass panels out of the main window frames and keep the main frames. Use some vinyl "deck flashing" (UV stabilized) backed with foam insulation sheathing and spray can foamed the insulation in place. Then we will place our final interior layer of foam insulation over that. By keeping the original metal window frames, I can use the 24" size (window frame inside dimensions is slightly less than 24") and the vinyl will be cut to just fit inside the outer trim. And no extra metal will need to be bought. Now I just have to figure out what to do with all that glass I will have! So far this is the cheapest and best solution we have found.
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
Fulltime since 2006
Old 06-21-2010, 03:28 PM   #13
Steve's Avatar
John I thought about doing something similar but I wanted the extra insulation having the glass windows, a layer of insulation, and then the aluminum sheet.
Old 06-21-2010, 09:35 PM   #14
Rated Cap: 89
We had thought about using the aluminum but since so much of the bus is steel (different expansion rates and lengths) we decided against that. I do know that an aluminum skin over steel framed 40 ft long Eagle bus can grow up to an inch during a hot summer day and then cool back down to original size (yes we did measure our bus over a couple of really hot summer days and it really did lengthen by almost an inch... fascinating). That's a lot of expansion even on a 24"+ window so we decided to opt for the vinyl... and it's CHEAP! Our BB bus window frames are very water tight (except for the one with the broken glass) and we just thought it would be smart (and FRUGAL) to reuse the nice heavy window frames. I guess there's more than one way to skin a bus? That was bad ... time to go eat supper!
Fulltime since 2006
Old 01-19-2011, 04:14 PM   #15
Re: Window skinning options? FRP and Lexan
Originally Posted by lornaschinske
Both of the RV doors on my Class C are skinned in FRP... David shot down the fiberglass coated plywood idea I had.
As a newbie - not sure why the FRP idea would be shot down. Many FRP are used RV construction and have UV protection and high insulating values.
They come in assorted widths, colors and strengths - they are used in truck container box construction for years. They can be cleaned nicely to keep that high gloss look for years to come. As far as expansion and contraction - your original windows would have collapsed if it was any value to be concerned about. May be more of a real concern with light thin material types like skins.
Another idea I'm experimenting with is Lexan polycarbonates - they come in all types with UV protections and can be scratch abrasion resistant - used in bullet proof glass. They come in dark colors similar to various shades of automotive glass and have been used in high impact glass applications for years. You can get large pieces or place them side by side in the same window openings. They give a good clean appearance and can be used with window gaskets for a factory appearance. I'm thinking about running one complete seamless run down the bus to give clean lines and appearance. The Lexan offers security (you can’t see in - but you can see out) and easy fix for any interior build along the run. The interior partitions won't show through the glass.
Just my thoughts. Not sure why the FRP wouldn't work - it’s made for this use and design applications. Plus you can purchase them in widths (thickness) to accommodate window installs with gaskets – you can also use them in simple walls applications. Ideal for the custom shower installs or go for that custom aircraft, boat, RV interior/exterior look.
M
DaddyMac is offline   Reply With Quote
Old 01-19-2011, 04:58 PM   #16
Rated Cap: 89
Originally Posted by DaddyMac
.. As a newbie - not sure why the FRP idea would be shot down. Many FRP are used RV construction and have UV protection and high insulating values.
FRP does not have high R Value. Also while they may last for "years to come" it's not long enough. We plan on keeping the bus for as long as we possibly can. The Class C is 33 years old. We bought the RV back in 2006. It had these holes in the oh so very dull and sundamaged FRP rear door (the original door). I painted the door to extend it's life (and it looks a lot better) but here are just a few of the holes.
Fulltime since 2006
Old 01-19-2011, 05:32 PM   #17
Re: FRPs, Insulation and Polys
FRPs do have a high thermal Energy Efficiency - if your comparing skins. FRP is higher compared to metal - no comparison. The FRP thickness and insulation R factor surpasses widely all aluminum sheet alternatives. The finished product enables your trucks, vans and trailers to hold temperatures up to minus -10 degrees F. The oriented strand board outer skin on FRPs is exterior rated Exposure I by the American Plywood Association (APA). FRP panels decrease cooling and heating costs even more than their R rating would seem to indicate 'because they form a solid thermal envelope around the structure, uninterrupted by studs, sills or headers. This substantially reduces air infiltration compared with conventional construction techniques. The panel's solid core of insulation also eliminates the convection looping that can occur in the gaps and spaces typical in batt insulation.
Many of the FRPs can be purchased sandwiched with EPS. Expanded Polystyrene (EPS) foam insulation is used for all types of construction. EPS has a 35 year history of proven performance as a rigid foam insulation. EPS foam provides optimum cost value when compared to other rigid foam insulations of the same R-value design. Your freezer container trucks and building construction coolers are made of the same stuff.
Other FRPs are sandwiched with Polyiso. Polyisocyanurate is one of the nation's most widely-used and cost-effective insulation products and has been cited by the U.S. Environmental Protection Agency for its responsible impact on the environment. Polyisocyanurate is a closed-cell, rigid foam board insulation used primarily on the roofs of offices, health facilities, warehouses, retail and industrial manufacturing facilities and educational institutions.
Other brands are sandwiched with Styrofoam types. STYROFOAM insulation products feature closed cell structure and maintain their R-value over time. The extruded polystyrene insulation products offer the highest moisture resistance of any foam plastic insulation. The result is high compressive strength and unparalleled resistance to water penetration.
As for lasting – FRPs will outlast any plywood particulates – long past. Studies have shown that they outlast your standard galvanized skins as well – much longer. Many truck containers designs have changed to these FRPs for these very reasons. Many of the newer ultra lite RVs are made of FRP construction.
Not sure why yours has degraded in such a fashion. It looks like an older stippled design – maybe the thin nature of design. Some of the older FRPs had delaminating issues. But rot has generally not been an associated with them. The older FRPs were susceptible to weathering. The outdoor weathering properties of FRP are generally good. However, there is a certain susceptibility to ultraviolet rays which require that ultra-violet absorber be specified for translucent laminates. Originally, UV absorbers were not required for gel coat because the pigments and fillers act as absorbers. Today, all exposed laminates should have a 'smooth' gel coat or a glass surfacing mat specified for the exposed surfaces to prevent fiber ‘blooming’ or surface exposure of the fibers. The high gloss 'smooth' gel coats are the preferred method for this reason. I work with FRPs and Polycarbinates in the construction business.
The other alternative is LEXAN polycarbinates - you can't distroy this stuff - hurricane shutters and impact glass use them.
M
Old 01-19-2011, 07:10 PM   #18
Rated Cap: 89
But the FRP's that are used for exteriors have a UV coating to them... not to be confused with the FRP that most of us would be buying from the likes of Home Depot and Lowes. The stuff you buy from them does not have a UV coating as they are intended for interior use. And FRP's do not have any insulation value. The insulation mentioned that the FRP is glued to is the insulation not the FRP in the first place. As for using it on an RV... I read the RV forums. I read the threads that say "help my sidewalls on my RV have delaminated... what do I do". As for the rear door of my RV... I certainly didn't make that up. Believe me, I wish it didn't have the holes in it. I also know what it looked like before I painted it. It looked degraded and sun rotted.
Lowes:
6876 Sequentia Structoglass Installion Guide from http://www.cranecomposites.com/sequenti ... lation.asp
"Prolonged direct sunlight on panels may cause abnormal fading and/or rapid expansion depending upon amount of heat build up.Use caution in these areas."
Home Depot:
Stabilit/Glasteel Glasliner FRP states right on the Description "For interior use only". Reading the installation instruction (pdf download) leads me to believe this is not a good choice for a shower liner. "Caution: Failure to use moldings and sealant may cause panel deterioration. In high moisture areas or in standing water, edge swelling and moisture absorption by substrate will occur if appropriate moldings and sealant are not used."
Fulltime since 2006
Old 01-19-2011, 08:12 PM   #19
I believe you - saw the pics - looks bad, but mostly likely as I said above.
All FRPs by themselves do have a thermal value - as do all materials. It’s a question of how much by comparison. FRPs compared to metal have a higher thermal coefficient - if we are talking skin only. Not the added insulation. Plastics or fiber resin based panels hold a higher thermal value then metals do.
ON the product choice - I'm just trying to offer suggestions to applications and specifications for vehicles or in our case 'skoolies' / buses. Your 'Home Depot' or Lowes' products don't fit the applications - that's what I'm pointing out as example. For example your thread link to Sequentia® Wall, Ceiling, and Corrugated Panels are traditional products for commercial and residential use NOT vehicles. If you go their web site you'll find other more useful products made for your needs. While not Depot or Lowes available - easily selected at a local plastic dealer or 'contraction materials.
If you click your link you'll note other materials available in FRPs from the same company: (note the ones for Trucks / RV's).
Glasbord® Sanitary and Durable Wall and Ceiling Panels, Protected by Surfaseal® to provide extra protection against stains, Filon® Exterior and Interior Panels for Recreational, Vehicles High-gloss coilable fiberglass finish with a durable, advanced resin system, Kemlite® Liners and Roofs for Trailers and Truck Bodies. Noble®Exterior Sidewall Automotive Finish for RVs Industry leading sheet glass lauan-based and wood-free panels. ArmorTuf™ High-Impact Interior Liners for Trailers and Truck Bodies, Robust resin system engineered for surface hardness and durability composite solutions Wall and Floor for Truck Bodies and Delivery.
I’m just attempting to offer suggestions. FRP laminated over plywoods have had some delaminated. Others don’t. Others like EPS lams do not generaly delaminate – again match your need to your application. I’m just suggesting you use the correct materials applications – I don't suggest you use interior house materials for exterior truck applications.
Old 01-19-2011, 10:17 PM   #20
Rated Cap: 89
I've been in actively involved in construction since 1979. My father was a tile setter with over 50 years experience, so I grew up knowing tile (I also know how to lay tile, grout, cut, the whole deal). I was a Kitchen/Bath Designer (thanks to NKBA) and owned my own cabinet shop. My husband has run 2 custom cabinet shops (first one, he was still in high school). David also built teller systems for Diebold (his first system he built was so good, they used it for a model rather than put it in the bank). David built his first house at 16 (he's 56 now). David & I installed cabinets and built countertops in GA, FL, NC, SC and remodeled house for a living. So since we have a little experience with residential building and are a little experienced with some of the materials, we will stick with what we know. After all we are building a house on wheels.
And like I said, the stuff most of us have ready access to is the FRP from Lowes and Home Depot. It is NOT suitable for exterior use. Also I don't consider a material with a 0.19 R-Value as an Insulation. Single pane glass has a higher R-Value.
BTW, we've changed our minds again on what we will be skinning our window openings with... again!
Fulltime since 2006
Skinning your bus. Any regrets? crazycal Conversion General Discussions 13 10-22-2012 08:55 PM
Skinning over windows lornaschinske Conversion General Discussions 2 11-24-2010 03:30 PM
window skinning question thesaltydog24 Conversion General Discussions 6 02-03-2010 04:49 PM
Window skinning with an overhang? Diesel Dan Conversion General Discussions 8 12-04-2009 04:13 PM
WINDOW SKINNING captainkf Conversion General Discussions 2 05-04-2006 12:36 PM
