Originally Posted by Twigg
The catches wear, and the tracks get dirty making it difficult to get the windows fully up sometimes.
Broken catches can be replaced, and window tracks cleaned and lubricated. Use a dry-lube.
Thanks Twigg-The tracks are clean for sure & I checked the catches. No issue there either. Pretty sure the rubber is just old and stiff. It doesn't compress at all, making it difficult to get that last 1/8" or less to grab the top catches. I'm hoping to find some replacement rubber somewhere online. I need to search on here for ideas in regard to vendors. You know of any?
