Old 09-04-2019, 09:02 PM   #1
Liveinashortbus's Avatar
Coachwork: Ford
Chassis: E-450
Engine: 7.3 liter turbo diesel
Rated Cap: 14,500
Wiring short bus rear lights question.
Hello everyone. I just got a 2000 Ford E-450 7.3L turbo diesel short school bus 22 feet 5 window. I purchased it from someone who already gutted it and did the floors. All of the wiring that goes to the back of the bus is coiled up at the front. See photos.
My question is I am trying to connect the brake lights and turn indicators and reverse lights. Starting with the brake lights. Luckily the previous owner labeled most of the wires. I connected the two brake lights to their respective wires.
I should let you know that my bus uses 2 batteries. I only have one battery installed ( the one under the hood).
When I step on the brake ( key turned on or off) I can hear the relay switch activating but the brake lights do not turn on. I’m enclosing pictures (don’t laugh- it looks like a mess)
I am asking for any assistance or guidance on getting these lights to work. Thanks.
3C2AF790-5316-45F1-B193-3062201FF63A.jpg   1B317CE7-8557-4CB5-B6F7-CEA98B05029D.jpg   1CA4B4D6-EC1E-4E39-AF4B-6A2B23DD7CB7.jpg   D3493181-415A-413F-844F-70E54F68FD15.jpg
Liveinashortbus is offline   Reply With Quote
Old 09-04-2019, 09:08 PM   #2
Bus make/model?
Old 09-04-2019, 09:43 PM   #3
Coachwork: Ford
Chassis: E-450
Rated Cap: 14,500
Make/model
2000 Ford E-450 7.3L turbo diesel superduty Powerstroke.
Old 09-04-2019, 11:50 PM   #4
I am asking who made the bus body
Old 09-05-2019, 12:32 AM   #5
Coachwork: Ford
Chassis: E-450
Rated Cap: 14,500
Thomas Built
Thomas built
Body ID: 94441-9911960-051MS
If that helps.
Old 09-05-2019, 01:27 AM   #6
Minotour Circuit Board Schematics
http://www.skoolie.net/forums/f49/th...ics-27084.html
Thankfully Thomas labels the wires. If you look closely you will see it printed on them. The attached link contains schematics of the circuit boards for a minotour. Maybe it will help
Old 09-05-2019, 02:55 AM   #7
Coachwork: Ford
Chassis: E-450
Rated Cap: 14,500
Thank you.
I’ll look at the wires tomorrow. I found a wiring diagram for the rear lights. I think it might help as well. Tomorrow I hope to get the rear lights working.
Old 09-05-2019, 01:43 PM   #8
Hi,
Looking to buy already bought half skoolie and have trouble finding insurance in Massachusetts..called a few and know there is but was thinking if any Massachusetts adventures know a good start?
Thank You!
Mia6871 is offline   Reply With Quote
Old 09-05-2019, 11:32 PM   #9
Coachwork: Ford
Chassis: E-450
Rated Cap: 14,500
I fixed the brake lights!!
After scratching my head and getting way lost in tracing tiny wires through thick colored bundles I looked at the brake lights. There were three wires coming off of each. 2 colored wires and one white. I could light up the light directly to a battery only using the 2 colored wires. The white is basically the ground wire. So I thought what if I attach the white ground wire to the chassis and step on the brake.......
Amazing the brake lights worked. I had to ground the lights for them to work. So now I connected the turn indicators, the backup lights, license plate lights and marker lights.
Brake lights work as well as the turn indicators! The others are connected to a switch which still needs a few more connections. It just got too late. I’ll get it done tomorrow.
brake lights, short bus conversion, wiring lights
