03-03-2012, 02:40 PM
Year: 1969
Chassis: Loadstar
Engine: 345
1969 Loadstar Honaly
Purchased this bus in 2001. It was purple/blue/pink and had been named the 'Honaly" (from Puff the Magic Dragon) decades prior by traveler/owners to the Grateful Dead concert circuit. The first night it spent the night parked in the street in front of my place. Next morning it had been egged by kids. They obviously didn't like hippies.
This bus was fun to live in with its' wood stove and claw foot tub. It was skeletal inside other than the previously mentioned items + a submarine window lying on the floor. Also had an existing VW bus cut in half and placed on the roof. It was rather horrid to look at but character galore! I never had any intention to live in it. It was to be my 'hot glass studio'. I was a glass artist surviving well enough at the time. But, as circumstance would have it, I did end up moving this bus to an isolated mountain location.
After a year the bus, although cozy, warm and well-stocked, did not see me comfortably sleeping on my futon couch. I missed my king size "Judith Ames" oak curved bed which was being taken care of by my son. I decided to remedy this. I had purchased hundreds of these insulated metal panels (60"x22") for a big project that went awry. I decided they might be just the thing to facilitate a 2nd story on the bus.
The 1st engineering project I set my mind to was how to 'set' this 2nd story. I was an airframe specialist (sheetmetal fabricator) in the Air Force, worked a bit in sheetmetal shop in Alaska, knew how to build a standard house. I simply applied those skills to my latest acquired skill (bending/manipulating glass) to mold my bus the way I desired. So the 1st foundational support became the transition braces. I designed a prototype out of cardboard and took them to my local welder. I needed 18 of them but wanted to have a prototype first. The final design must have considered 1) weight 2) design 3) functionality. Each transition needed to be within a certain weight/have 12 holes pre-drilled (strategically placed) and conform perfectly to the slope of the bus roof.
Took 3 attempts before the perfect design presented itself and then it was mass produced. :0)
After transitions were bolted on, the panels went up. Windows went in (designed, built, installed by moi). Then the front was to be accomplished. I was making this up as I went along (which becomes more evident every step of the way. There was no level consistency about the exterior curves of this bus. It had that hand-built quality about it. "Well, huh..." would erupt from my mouth no less than once a day.
The most important consideration on my mind daily (still is today) is WEIGHT and WEIGHT PLACEMENT. I had no intention of falling over on the freeway or getting blown over or having the entire top collapse into the lower structure. Much more thought was given to this than overall height...which becomes funny later on!
Rollin', rollin', rollin', keep my home a rollin'! Rawhide...
03-05-2012, 12:48 AM
Engine: Detroit
Re: 1969 Loadstar Honaly
Looking forward to pictures.
03-05-2012, 07:22 AM
Chassis: AARE
Engine: 3116 Cat 250hp
Welcome, and looking forward to more of the story and pictures.
03-05-2012, 08:31 AM
Rated Cap: 1
This ought to be interesting....
03-05-2012, 09:05 AM
Welcome to the Madhouse...sounds like you will fit in just fine here! Can't wait to see more pix and what your engineering skills produce. We can certainly use someone with sheet metal fabbing experience to light the way on many people's projects. And any Vet has earned the right to do things his way. Once again, welcome!
03-05-2012, 01:07 PM
Year: 1969
Chassis: Loadstar
Engine: 345
Thank you all for your 'Welcomes'! If I could figure out this gallery thingie ma jig I would post some detailed pxts.
I didn't get the hang of keeping up with pictures too much at the beginning because I lost my camera in a bus fire. I purchased 2 buses in the same month. One bus was perfect and was going to be my knock around bus. That is the one that broke a fuel line while scaling the Gifford Pinchot forest in WA. Lost the whole bus up there while en route in the mountains, tires/paint and $50,000 worth of renovation and tools. Word from the wise...ALWAYS CARRY A FIRE EXTINGUISHER!
So if anyone wants to hold my hand who has accomplished setting up an album for this site...I'm all ears!
I don't have a photo of the bus when the VW bus was on top. Trying to run down a friend who does have one though.
Photo is after transporting it 100 miles via the freeway. Lost a few shingles, had only nailed them on w/ roofing nails. Went back and replaced nails with screws. This design inadvertently encouraged wasp building domains. Thousands of wasps were created by accessing the access behind the shingles. Sprayed organic spray, then caulked and painted every shingle. There, that should take care of that! No more wasps.
03-05-2012, 01:14 PM
Year: 1969
Chassis: Loadstar
Engine: 345
More pxts., modifications between 2002-20011
03-07-2012, 05:38 AM
Engine: Detroit
Wow! That's an impressive top level. Sweet looking too!
03-07-2012, 09:13 AM
Now THAT is a classic "Prankster-Mobile"!!! --- And I can definitely picture the VW on top. Can't wait to see how you build it out.
03-07-2012, 09:35 AM
I like the Werner work platform. So many uses.
03-07-2012, 10:06 AM
I think you need a third story...
03-07-2012, 11:01 AM
Rated Cap: 89
What is your overall height? Looks great but I suspect it wouldn't get under some of the overhead bridges/trestles on some of the back roads we travel on like the 13'-10" trestle on Old Hwy 411/US76 in Ramhurst, GA.
Low Clearance Locations
BTW, the Ramhurst trestle did not show up in the S&T POI Megafile and I know it's there... I drove that road for far too long to not know it. How many others aren't on the files? This is why we kept the bus at original height and are reluctant to put anything up on the roof. We like running the scenic primary highways too much.
03-07-2012, 02:23 PM
i didn't think that one was supposed to have anything higher than 13'6"
03-07-2012, 03:05 PM
Rated Cap: 89
Don't forget it has a nice "dip" as you go under... so the longer you are, the lower the trestle is... I've yet to see a standard semi get caught on it though.
Back before they worked on it, the overpass at I-24 Exit 152 Kimball/South Pittsburg (TN) would scrape the air conditioners off of tall RVs on a regular basis. They had overhead warning chains on the turn lane but it was impossible to change route by that time. Bad thing was the road dipped so much and so sharply that even the standard semis would barely clear it. Too long and they hit (mostly those huge fifth wheels). It's strange to watch someone scrape their roof top AC units off their RV. Apparently it's difficult to tell when it's a fifth wheel trailer. Oddly enough, Shaw carpet mills had a factory in S. Pittsburg, so lots of semis drove there. I once sat and watched a fiver scrape 3 AC units off... guess they didn't want them anymore.
03-02-2019, 03:58 PM
Not sure if you might get this. My name is Mattius. Mattiusrobvalentine@gmail.com. I sold you that bus in 2001 in Olympia wash. Crazy. I have a pic of it when it had the vw top. I’d love to see some more pics, and looks like you really continued to make it great.
