Old 10-28-2008, 04:47 PM   #121
Steve's Avatar
Re: 1972 IH Ward Conversion
Yes that is the same thing you could use it to circulate the water through but I am using it like a tankless water heater, I turn it on a minute before I want hot water and then turn it off when I am done. The one I have is also 1000 watts.
Old 10-29-2008, 09:32 AM   #122
Steve's Avatar
I put my television on of those wall brackets so now it is held much better inside the cabinet and can come out and move in any direction.
Old 10-30-2008, 12:03 AM   #123
Steve's Avatar
I got my wheel covers tonight, to attach them the frame is put in the lip of the wheel and held secure by expanding the hoop with a nut. The mounts are rubber and the security screws that hold the cover on also have rubber grommets. The rear covers are also available in a deep configuration but I didn't want to have any clearance issues. I will get a picture of the full bus with them on in the morning when there is light. They also came with nice center caps but I am choosing to not use them.
Old 10-30-2008, 01:38 AM   #124
timbuk's Avatar
Year: 1965
Coachwork: thomas
Chassis: chevy
Engine: 350
ah so the mounting secret of the wheel covers is revealed...thanks steve! so roughy how many denaros for a set of those babys? looks like its back to the canadian peso
Old 10-30-2008, 09:13 AM   #125
Steve's Avatar
Here is what they look like on the bus, if you can fit them I would still probably like the deeper rears better.
Old 10-30-2008, 09:41 PM   #126
Steve's Avatar
Got a new Winegard antenna for $7 but had to build my own mount. If this doesn't work well I'm not out much.
Old 11-10-2008, 09:24 AM   #127
Steve's Avatar
Finally got in my refurb King Dome, this is the smaller dome but still does on the go tracking. I routed the cable for the dome and the antenna through the cover that came with the dome.
Old 05-13-2009, 11:34 AM   #128
newbusser's Avatar
Year: 90
Coachwork: blue bird
Engine: Navistar Straight 6 Turbo
Love that wood work!
My wife saw it, so now I know what I will be doing inside mine when I get to that stage
“Twenty years from now you will be more disappointed by the
things that you didn't do than by the ones you did do. So throw off
the bowlines. Sail away from the safe harbor. Catch the trade winds
in your sails. Explore. Dream. Discover." Mark Twain
newbusser is offline   Reply With Quote
Old 05-13-2009, 02:05 PM   #129
lapeer20m's Avatar
i like the wheel covers! I'd like to put a set on a bus one of these days if i could find a good deal.
They look real nice!
and you have mobile satellite tv? that's pretty awesome
Old 05-17-2009, 11:21 PM   #130
I love your bus, it has a lot of character. Where did you get the water circulation heater and how well does it work? Do you think it would be suitable to heat all the water for a skoolie?
I love the shiny rim covers too, but $200 is a real kick to the wallet, do you think they are worth it over a rustoleum finish?
Keep up the good work!
Nicholas Virgil
1987 International (66 passenger) 7.3l diesel
2002 Ford Explorer
1993 Saturn SL2
1988 Chevy C1500
Kmart Mountain Bike
nickverge is offline   Reply With Quote
Old 05-17-2009, 11:22 PM   #131
Wow...ok, I don't know how I missed that someone else asked about the water heater...I'll just read that
Nicholas Virgil
2002 Ford Explorer
1993 Saturn SL2
1988 Chevy C1500
Kmart Mountain Bike
Old 05-18-2009, 09:13 AM   #132
Steve's Avatar
For me they are that much better. I park next to a lot of high dollar and well done buses at the tailgates and those wheel covers made a world of difference for the look of my bus.
Old 05-20-2009, 05:59 PM   #133
swinada's Avatar
i'm getting jelous looking at your wheel covers, antenna and such..... enjoy
Proud owner of a: 1996 Thomas Safe-T-Liner,Cummins 6CTA 8.3Lt diesel, Allison AT.
https://picasaweb.google.com/swinada/BusPictures https://www.swinada.com/bus.htm
https://lh4.ggpht.com/swinada/SL91F-b...opbussmall.jpg
swinada is offline   Reply With Quote
Old 05-21-2009, 02:18 PM   #134
Steve's Avatar
Today I took my bus over to the local IHC Scout specialists, http://www.anythingscout.com/, and had them take a look at my bus. They say the engine looks to be in great shape but they can do a few things to it that give the 345s more oil pressure, rebuild my power steering pump, and hopefully a more powerful alternator.
Old 07-02-2009, 09:53 AM   #135
Steve's Avatar
The Winegard antenna kept flying out of or breaking its mount while driving down the interstate. I decided a bold should hold it secure and then I used large zip ties to secure the wings from flapping around at interstate speeds.
Old 07-02-2009, 02:26 PM   #136
Steve's Avatar
It has been a while since I posted a wiring diagram so here is the system I am currently using. I bought an isolator for the engine battery to use in place of the switch but that would mean that the fans and other DC power in the bus would be draining my engine battery so I never installed it and instead decided to go with a regular switch.
Old 09-07-2009, 11:29 PM   #137
Hi, Nice bus can I ask you a couple of questions about your battery setup? My goal is to have a generator free setup. Might use some solar but mostly just motor charge.
If I am reading your thread right then it has ben a few years now since you put in the UPS batteries? How are they holding up and would you recommend them?
Do you happen to have a part number for them so I can try to source them?
And finally do you think your setup requires the 3 deep cycle bats as well or were these just what you had before going with the UPS?
Thanks in advance and again a great looking bus you have there!
Currently looking to purchase a schoolbus in the oklahoma area.
Thundarfoot is offline   Reply With Quote
Old 11-12-2009, 05:42 PM   #138
Steve's Avatar
Well I'm going to put the old girl up for sale. I haven't this bus longer than any other vehicle and it will be sad. Hopefully I will have some time soon to clean it out. The bus is stored in a heated garage so I just need to find time.
Anyone interested in buying it?
Old 04-29-2010, 09:28 AM   #139
Steve's Avatar
Bus is for sale: http://www.skoolie.net/forum/viewtopic.php?f=12&t=5886
1972 Crown Motobus Classifieds | Buy, Sell, Swap 1 01-26-2013 12:59 PM
1988 Ward School Bus Camper Conversion Sleeps 5 Steve Classifieds | Buy, Sell, Swap 0 05-02-2011 09:28 AM
1972 International Ward $4500 obo Steve Classifieds | Buy, Sell, Swap 21 04-20-2011 12:31 PM
1972 GMC New look for sale!! Rare!! Steve Classifieds | Buy, Sell, Swap 2 01-06-2011 05:13 PM
1972 Flxible - what would you do? Steve Everything Else | General Skoolie Discussions 3 06-28-2010 08:40 PM
