Old 06-02-2014, 11:08 AM   #61
Year: 1979
Chassis: Chevrolet
Engine: 366 Chevy Big Block
Rated Cap: 60
Re: 1979 Chevrolet Bus
I have ordered the Blue Skin Membrane that Nat suggested. I also ordered a tube of sealer the same kind of stuff only in a caulk tube. I will post pics when it gets here.
Kirk is offline   Reply With Quote
Old 06-02-2014, 07:49 PM   #62
Ditto and echo many of the above concerns. I had a bunch of bolt holes in my otherwise solid floor and I welded and ground them all to make sure nothing would come up from below. Better to take some time now and do it right. Once the whole interior is in...fixing holes in the floor is costly and a bit more of a challenge.
Old 06-02-2014, 09:44 PM   #63
I actually drilled a few 1/2" holes in and around the area where my water and grey water tanks are (they are inside the bus) and then counter sunk the hole by whacking the ball of a ball pein hammer in the hole with another hammer. I glued fiberglass screen over the holes to keep the critters out. I am hopeful that if my tanks start to leak I'll at least have a heads up from the drips of water under the bus and be able to fix things before my floor is ruined. I suppose I should be shaking in my boots over the possibility of CO poisoning from the exhaust---but I'm not.
ol trunt is online now   Reply With Quote
Old 06-06-2014, 01:10 PM   #64
Year: 1979
Chassis: Chevrolet
Rated Cap: 60
This don't look very good at all!!
Old 06-06-2014, 01:10 PM   #65
Year: 1979
Chassis: Chevrolet
Rated Cap: 60
Old 06-06-2014, 01:12 PM   #66
Year: 1979
Chassis: Chevrolet
Rated Cap: 60
Other than the wheel well rust so far the floor looks pretty good, but I have only taken up 2 sheets of plywood subfloor.
Old 06-06-2014, 01:16 PM   #67
Year: 1979
Chassis: Chevrolet
Rated Cap: 60
I am needing all the suggestions I can get about how to repair the floor rust-out behind the wheel well. Keep in mind I have an Arc Welder only, no Wire Welder. All opinions will be appreciated.
Old 06-06-2014, 07:00 PM   #68
Coachwork: Honey Badger RV Co
Chassis: tc2000
Engine: 5.9 cummins
Rated Cap: 74
Sheet metal and pop rivets. Use sealer around the edges.
wauto is offline   Reply With Quote
Old 06-07-2014, 08:01 AM   #69
Year: 1977
Coachwork: Chevy
Chassis: C/60
Engine: 350 V8
Rated Cap: 54
And that is the exact reason I didn't pull up my floor and "do it right". I'm flat out scared to know what's down there. If I can't see it the problem doesn't exist ..... right ?
Passes everything but gas stations.
bamper is offline   Reply With Quote
Old 06-07-2014, 11:31 AM   #70
Year: 1979
Chassis: Chevrolet
Rated Cap: 60
Up towards the front of the floor between the drivers seat and wheel wells I pulled up the old carpet, and the plywood is totally rotten, and wet after the 2 inches of rain we just got. I guess Im going to have to take down the ceiling skin because Im guessing there is a leak somewhere.
SKOOLIE :: Chevrolet School Bus Conversion dcobranding Classifieds | Buy, Sell, Swap 2 12-14-2014 09:38 PM
1979 Chevrolet Nascar Bus timocon Classifieds | Buy, Sell, Swap 0 04-01-2010 12:25 PM
Chevrolet/GMC ignition retarder/govenor Kirbystud Conversion General Discussions 12 07-26-2009 01:15 PM
1983 Chevrolet Bus Willie Classifieds | Buy, Sell, Swap 1 08-02-2008 08:44 PM
1962 Chevrolet School Bus Steve Classifieds | Buy, Sell, Swap 1 09-09-2004 06:57 PM
