Old 02-07-2010, 10:59 AM   #11
Seeria's Avatar
Re: 1983 International DT466
lol
Mind posting a pic of the one you used? I can't picture how a hammer removed stripped bolts sunk into rubber flooring.
Old 02-09-2010, 04:17 PM   #12
busdriver_phil's Avatar
Coachwork: AmTran RE
The back-up alarm should be wired to the reverse light circuit. Sometimes they tap near the lights (I've seen some retrofit jobs where the beeper is on the outside, 2" from the light, with the wire going under the lens), other times they run a separate wire from the front of the bus. The easiest way is to just locate the actual alarm (should be somewhere on the frame under the rear) and cut the wires (make sure you tape them off). If you can trace the positive wire and disconnect it that's even better, but I'd recommend leaving the lights alone and just disconnecting the beeper.
The conversion of Miss Euphegenia, a 1999 AmTran RE: http://www.skoolie.net/forum/viewtopic.php?f=9&t=5704
Old 02-09-2010, 04:41 PM   #13
You could do that. But it would be a huge amount of cuts to get it to conform without gaps between it and the roof.
Old 02-09-2010, 04:53 PM   #14
jkindt's Avatar
Year: 1981
Chassis: Ford B-600
Engine: Ford 370 Propane
Rated Cap: 48
What about using Reflectix or whatever that silver colored 'bubble wrap' is called? How well does that stuff work? You may be able to slide it between the two layers of metal in the roof.
Old 02-09-2010, 05:00 PM   #15
use a real sharp knife and a straight edve and either cut a series of V's or cut the whole way thru at an angle and then flip every other piece to conform with the curve and then fill the gaps with spray foam. I like to use a 10 or 12 inch chef's knife, the long thin blade seems to follow a straight line best,
Old 02-09-2010, 05:20 PM   #16
Wannabe's Avatar
Year: 89
Coachwork: Ford
Chassis: Bluebird
Engine: 370-2V
Hi, cedar is certainly a beautiful wood. My sister and brother-in-law redid their bathroom in cedar. It came out beautiful!
The dream is on!http://www.skoolie.net/gallery/v/sko...sskoolies.jpg/
Wannabe is offline   Reply With Quote
Old 02-10-2010, 10:35 PM   #17
Thought I would jump in here since we are talking about insulation....Closed cell foam can be bought wholesale by anyone with a business license. I buy mine from IR Carl Havens in Fife Washington. Comes in lengths and is priced by how dense it is, I used two pound in my business, it is about 1/2 inch thick, I also have some that is a quarter inch thick that is heat resistant that I will use around the dog house. For a big bus it might be worth finding an upholsterer to order for you, or a body shop perhaps if you know any one in those businesses.... Just a thought, it is great stuff. Leslie
Doodlebug is offline   Reply With Quote
Old 02-13-2010, 11:02 AM   #18
Are you referring to the normal home insulation? If so, you don't pack it. If you pack fiberglass insulation, it looses any insulative properties that it has.
Old 02-15-2010, 07:02 AM   #19
CAMO-MONSTER's Avatar
Year: 1974
Coachwork: CARPENTER
Chassis: GMC-6000
Engine: 454 CHEVY
Well the PNW is nice IF your on the EASTSIDE of WA or OR the westside SUCKS
Love the dry heat that we have on the EASTSIDE
hd d44 4.56, eaton ff 4.56
CAMO-MONSTER is offline   Reply With Quote
Old 02-15-2010, 07:29 AM   #20
Seeria's Avatar
BAH suck it up, boys! Love that rain, love that fog! I miss the west side. Hell, if I had a finished skoolie I'd trade you that for that lovely cabin you have there.
1997 AmTran International DT466 crazycal Skoolie Conversion Projects 158 07-21-2017 08:36 PM
1983 international DT 466 with alison auto. chev49 Classifieds | Buy, Sell, Swap 0 01-11-2012 04:32 PM
1983 International jimbojumpback Classifieds | Buy, Sell, Swap 2 11-03-2011 11:02 PM
40 Foot International School Bus 1992 Diesel DT466/Allison BigBearHostel Classifieds | Buy, Sell, Swap 5 12-06-2008 05:24 PM
FOR SALE INTERNATIONAL. DT466 TURBO DIESEL , A/C.GENERATOR all Classifieds | Buy, Sell, Swap 0 06-17-2008 04:22 PM
