Old 03-11-2012, 04:39 PM   #1
TygerCub's Avatar
Engine: Detroit
Re: 1984 Bluebird Double Decker
love the 2nd story!
Old 03-11-2012, 06:18 PM   #2
Bodacious Bird Busman! --- That's a real classic you have there. 'Course in the olden days, it would have been a BeetleBus on top though. Very cool. More pix! Show us your switches!
BTW...just how tall is that gal?
Old 03-11-2012, 09:31 PM   #3
Diesel Dan's Avatar
Engine: DT466/AT545
Yeah, that bus is pure awesomeness! More pics! Welcome!
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 03-11-2012, 10:31 PM   #4
pipopak's Avatar
I like it!
couple questions:
1 - How did you put the van on top?. Bunch of people or more scientific approach?.
2 - How high is it (at highest point)?
pipopak is offline   Reply With Quote
Old 03-11-2012, 11:17 PM   #5
bus-bro's Avatar
Engine: 3208 na boat anchor
Well, this gets me thinking. I've got a 1990 Ford Aerostar (best minivan ever, IMHO), and now I know what I'm going to do with it.
Please show more pics of the interior.
Old 03-14-2012, 08:11 PM   #6
pipopak's Avatar
[quote="thebusman"]sits at 13'6"
I wanted to make it as tall as I could on the inside, so that I may sit up in bed!
I will try and snap some interior photos tomorrow.. have some cleaning to do first
Can't wait to see what you did under the chopped van!.
Old 03-18-2012, 10:10 PM   #7
Coachwork: ElDorado
Chassis: Chevy P30
Engine: 7.4 liter 454 Chevy
Rated Cap: 24
Originally Posted by thebusman
Does anyone have experience with flexible plumbing?
I am trying to route all my plumbing to grey water... must i use pvc to run everything? Or is 3/4 hose acceptable?
Reason I ask, I plan to run pipe straight down, under floor, then 90 to the middle of the frame... but thats where i run into trouble.. I have supports in the frame that prevent me from running pvc.. not enough space and the angles...
SO
can I run the braided pvc lined hose, for the sinks to grey water??
I'll try and get pics of the frame to better understand whats going on..
Check out "PEC" tubing.
Bullwhacker007 is offline   Reply With Quote
Old 03-19-2012, 09:55 AM   #8
lornaschinske's Avatar
Rated Cap: 89
David says you are taking a chance with 3/4". Use 1" at minimum. Since there is no pressure on it, you do not need to use braided hose. Watch your"dips" as they will hold water in the low sags and can burst from freezing (use the plastic plumbing strap on hoses... less wear). The drain lines in our Apache popup was "bilge" hose (lightweight crappy plastic... rots over time and will crack). We replaced it with some rubber-type hose like used to drain washing machines. I would suggest not using the clear hose simply because green goo, etc will grow nicely in it. Smooth interior wall hose would be something to look for.
Fulltime since 2006
Old 03-19-2012, 07:48 PM   #9
pipopak's Avatar
I think that hose, with a 90 bend, could collapse and get clogged real easy at the pinch point. Better do the extra work with PVC.
Old 03-19-2012, 10:25 PM   #10
Rated Cap: 89
You can use hard plastic pipe until you go thru the floor to the 90 angle. Once you make the turn, add a short piece of hard pipe then hose clamp the flexible hose over the hard pipe.
Fulltime since 2006
DIY double decker adamanderr Conversion General Discussions 8 04-24-2016 09:50 PM
Making Our Own Double Decker bansil Conversion General Discussions 4 01-18-2013 04:08 AM
Double decker Slide out? lapeer20m Skoolie Conversion Projects 4 07-20-2012 09:31 PM
Double Decker Bus RV Conversion DragginVR Coach Conversion Projects 6 03-08-2012 12:19 PM
double decker bus jbus Classifieds | Buy, Sell, Swap 6 08-12-2010 06:22 PM
