Old 11-10-2015, 01:11 PM   #131
Coachwork: IC
Chassis: CE300
Rated Cap: 32
We don't all live in the arctic, in fact we don't all LIVE in buses. Foam board is great alternative to the thousands it costs to spray foam.
And one had better hope and pray the spray foam is properly formulated and applied.
I'm all for spray foam, but there are other ways to insulate a bus.
Not everything is set in stone, everyone has different needs, budgets, and lots of other things to consider.
Old 11-10-2015, 01:18 PM   #132
Engine: 190hp 5.9 Cummins
When you figure out the coverage, spray foam is only 10 to 15% more than Rigid Styrofoam board.
When you figure the time it takes to install Rigid Styrofoam, it becomes more costly.
More costly for a lesser performing product.
Remember, I'm a contractor. Figuring out costs of materials is part of what I do.
And we don't cut and fit rigid Styrofoam into anything. Just far too costly for labor.
This is the best product I can offer in place of the blow in insulation.
Old 11-10-2015, 04:01 PM   #133
Coachwork: International Harvester
Chassis: S1700
Engine: 6.9l IDI
Rated Cap: 27 (adults)
So people seem to have some very emotional responses to the questions I ask. Hahaha. Natster you seem to have this idea in your head that you are building the ultimate bus and that he way you are doing it is the only way to do it. You and I have very different goals. I actually live in my bus. I moved in the day I bought it. I'm not made of money like you seem to be. So far, the roof does okay. In the summer it's important to be parked in the shade but my wood stove is so powerful that it keeps me too warm if I want it too. More to the point you and I are building completely different animals. I honestly think that there is a huge disconnect occurring. I'm not building a custom rv with a raised roof etc. I'm living in a school bus, because I'm a weardo long hair in the woods, not because I want to get on tiny house nation. A little bit about me, I've been welding and using power tools since I was a little boy and I'm not "slapping together" anything, if I built it I built it well. Aesthetically, I'm choosing to keep my ceiling boohoo if it isn't as well insulated as it could be.
Famousinternetjesus is offline   Reply With Quote
Old 11-10-2015, 04:07 PM   #134
Chassis: S1700
Engine: 6.9l IDI
Originally Posted by nat_ster View Post
Yes this stuff is exactly what I want to use, that way I can insulate and and maintain the interior ceiling. See Nat, that's called being productive. Like I said blow in insulation settles and that was a concern, this stuff is great
Old 11-10-2015, 04:16 PM   #135
Chassis: S1700
Engine: 6.9l IDI
In a effort to be able to go places where no one else is and have amazing fishing, I'm thinking of building a bus into one of these.
I would remove the entire chassis, and just use the body. Floor would be removed from the chair rail down, and a new bottom built 6 inches wider on each side.
Cool idea, lots of work.
I would be after exploring the lakes here in northern Canada more than rivers. But being able to travel the rivers would take me to places beyond where the roads could.
Because all of your ideas are so reasonable Nat... I mean come on dude. Do you think you are the only person allowed to have crazy ideas? Everybody on here has cool ideas. Everybody on here is weird. We are all on the same page we are all weirdos. I say go for it, build a boat, though there are a
Million things that would make more sense and work better as a boat I say if thats what you want to do you can do it
Old 11-10-2015, 04:46 PM   #136
Coachwork: IC
Chassis: CE300
Rated Cap: 32
Old 11-10-2015, 06:03 PM   #137
We are all opinionated and feel there is the best way to do something, we also recognize that not everyone agrees with what the other is trying to do. We also all have our crazy ideas (like doing something with a school bus that isn't driving kids to and from school), some of which we agree with each other on some of which we don't.
Some of us have a good level of tact on trying to convince our skoolie brethren on a better course of action others do not. Some of us will listen to the advice of others, some will not.
Mind you this isn't limited to Skoolie.net you will find this in all places school, church, work, the club... anywhere there are more than about 10 people. My solution has always been a simple one, ignore what is being said if you know there is no damn way you will follow it or if you understand what they are saying but you really don't care about their opinion. That said it can devolve into personal squabbles, and there is the shield of distance that the internet provides which allows us to take things a bit farther than we would if we were all hanging out at the bar or some such.
As far as insulation if you could add a binding agent to the blown in insulation it should work otherwise probably won't survive driving around, injecting expanding foam brings its own set of problems (can cause rust on ill prepared surfaces like areas you can't access to prepare properly), foam board is fairly cheap and easy to find but has a problem with curves ****, fiberglass is cheap and easy to find but holds moisture and mice, rock wool is similar to fiberglass but is less cheap and fire proof. If you can't keep moisture from forming on a surface you need to make sure there is airflow to let that moisture evaporate off. That is the reason you shouldn't paint a house with elastomeric all over, it is the reason houses have roof vents and soffit vents. Lack of airflow in a bus is a common problem as it becomes hard to maintain proper airflow and temperature comfort.
I have been thinking about how can it be achieved with cheap insulation (flat iso board) and have air flow between the metal roof and insulation. You could take that floor isolation stuff to laying tiles on put that between your foam board and metal roof and then take and run a vent to where the old flashers were on the top of the bus. You would have to close them off when driving which would be annoying but do-able. Theoretically this would keep you metal at a temp that wouldn't be too different from the surroundings and therefore keep condensation down while allowing air flow to let what does form to evaporate away. You could probably achieve a similar effect by ripping thin .5"wide by .25"thick wood (or plastic) strips to act as stand offs every 6-8 inches for the foam too and then vent to the outside again.
However to do any of these you have to take down all of the inside panels. Which in your case you don't want to do.
Remember there is the Best way to do something, there are a few Right ways to do something, there are many Acceptable ways of doing something, there are many Wrong ways of doing something, a few Bad ways to do something, followed by very few Dangerous ways to do something, and one thing that is the Worst way to do something.
*** I wonder if you can spray foam the rounded sections and then use foam board to get the flat places insulated. Hmmmm
CaptainInsaneo is offline   Reply With Quote
Old 11-10-2015, 06:14 PM   #138
Coachwork: IC
Chassis: CE300
Rated Cap: 32
I've always found that the folks I argue with on forums the most are likely the kind of folks I hang out with all the time.
Hell I'd really enjoy having a GLUTEN FREE beer with Nat and watching him tear out some bus seats.AND--- I'll bet he has some super awesome Canadian joint rolling method he's pioneered that I've never seen before.
But yeah, forums are forums.
Even with the occasional arguments or bickering this is still a pretty good place to talk about buses. I've gotten a bit frustrated at times, too. But at the end of the day we all have a lot more in common than non-bus people, if you ask me.
We need to someday have a "Grand Skoolie Meetup" of sorts. A bus gathering of all the nations...
Old 11-20-2015, 03:09 PM   #139
Chassis: S1700
Engine: 6.9l IDI
Well I'm in elko Nevada I left southern Oregon yesterday at ten am. I drove sixteen hours over every terrain imaginable. I have been making goods use of my brownie box. It has increased my fuel
Economy by about a mile per gallon but more importantly I can cruise 60-63 at 2200-2300rpm, awesome. Stopped and slept at almost four am got up at ten-eleven. Got some food at Walmart. Gotta stop at an oreilly for a new turn signal bulb, one is a bit dim. So far so good.
Old 11-20-2015, 03:11 PM   #140
opus's Avatar
Chassis: All-American R/E
Good job! If your light is dim I'd be checking more on the lights ground.
That Elko Walmart is fun getting into!
6.9l, at545, auxiliary, brownie, faster highway speeds
