Old 08-10-2015, 07:29 PM   #41
Engine: 190hp 5.9 Cummins
Gear vendor units are NOT made for bus size application's.
They are made for LDT, meaning Light Duty Truck.
Any bus other that crappy little one ton cut away's are MDT, Medium Duty Trucks and rear engine buses are HDT, Heavy Duty Trucks.
This false info needs to stop. Your giving people that don't know any better false hope.
Originally Posted by Famousinternetjesus View Post
Seems like you have a lot of negative things to say crazy cal. For those of you who are interested, there are actually several divorced unit auxiliary transmission made to handle bus sized loads. One is made by gearvend
No, is is giving it to you strait up and to the point.
The repetitive dumb questions give us senior members a head ache.
Lean to press the "Search" button as often as you press the "Post" button, and all will be well.
Seriously
Old 08-10-2015, 08:08 PM   #42
Coachwork: International Harvester
Chassis: S1700
Engine: 6.9l IDI
Rated Cap: 27 (adults)
For those who are interested I ended up getting a brown-lipe 6231A which is a manual divorced auxiliary three speed, the way you select gear ranges on the fly is by hitting an appropriate shift speed, selecting neutral on your auto in my case an AT545 And while in neutral shift your brown-lipe, then put your Allison back into drive. the overdrive is only safe to use on relatively flat ground in the auto trannies top gear or third, due to the multiplied torque. The only problem here is now that you've dropped rpms the torque converter in the Allison won't lock up at too low a speed..and you can have slippage. There are solutions to that problem though.
Famousinternetjesus is offline   Reply With Quote
Old 08-10-2015, 08:11 PM   #43
Chassis: S1700
Engine: 6.9l IDI
Gear ratios in the brownie are 1.25-1 1-1. .60-1. And I'm running 5.57s in the rear
Old 08-10-2015, 08:24 PM   #44
charles_m's Avatar
Year: 1982
Chassis: International S1800
Engine: DT466 Trans: MT643
The 545 doesnt lock up!
If this works, I would love to hear how it goes.
Sounds too good to be true!
Old 08-10-2015, 08:34 PM   #45
crazycal's Avatar
What make all you guys think you're so smart. Famous has got it all ccovered.
I'm hungry!
You Gotta Let Me Fly
Old 08-10-2015, 08:56 PM   #46
Chassis: S1700
Engine: 6.9l IDI
Charles_M you're right it doesn't lock up what I mean is that at lower speeds/gears or pulling grades with the overdrive engaged will burn up torque converters. @crazycal I'm not going to trade insults on the internet, if you don't wish to discuss the mechanical aspects of this kindly keep your words to yourself, it's important to act like a person, even on the internet
Old 08-10-2015, 09:07 PM   #47
crazycal's Avatar
There was no insult. I said you've got it covered. So that means everyone trying to give you advice is wasting their time. It's that simple. If you want to insult me go ahead.
I'm hungry!
Old 08-10-2015, 09:12 PM   #48
opus's Avatar
Chassis: All-American R/E
Ooooo.... Can I....please, please... pick me! 🙌
Old 08-10-2015, 09:15 PM   #49
crazycal's Avatar
Yes, but don't you dare call me late for dinner.
I'm hungry!
Old 08-10-2015, 09:52 PM   #50
opus's Avatar
It was a smoked pork roast, you wouldnt have liked it anyways.
6.9l, at545, auxiliary, brownie, faster highway speeds
