Old 08-10-2015, 08:53 PM   #51
M1031A1's Avatar
Chassis: Saf-T-Liner ER
Engine: 3208 CAT/MT643 tranny
Rated Cap: 87
Originally Posted by crazycal View Post
Yes, but don't you dare call me late for dinner.
It was burned on, so you didn't miss anything.......
Firearms stand next in importance to the Constitution itself. They are the American peopleís liberty teeth and keystone under independence. ó George Washington
M1031A1 is offline   Reply With Quote
Old 08-11-2015, 12:02 AM   #52
Engine: 190hp 5.9 Cummins
Famousinternetjesus
Do you even know how to drive a AT 545 transmission without blowing it up?
What RPM do you need to keep the bands from slipping and burning up the trans?
When you can answer this, then you might be ready to install that browny box.
My money says you will blow that AT 545 on your first trip more than 100 miles after installing the box.
You really should have leaned how to search and listen to Good Advice beforebuying something that will do you no good at all.
If you had a standard transmission, but wanted a overdrive, the browny box may have worked. However, good luck with the AT545 in front of it.
Also the browny box you have found was never made to spin as fast as your going to spin it. They were made for MDT and HDT trucks a few decades ago when top speed was 45 to 50mh tops.
Good luck.
Old 08-11-2015, 12:52 AM   #53
Coachwork: International Harvester
Chassis: S1700
Engine: 6.9l IDI
Rated Cap: 27 (adults)
Tranmission Problem? - TheDieselGarage.com
These guys have some interesting things to say so does a guy called allisonman on an rv forum. Any way having felt thoroughly unwelcome from the outset, (didn't know I was joining a club, thought I was seeking mechanical advice, which some of you finally offered) I'll stop seeking the advice of you lot... All the guys at my local transmission/driveline shop think the project is really cool and are excited about it, I am too, I hope everyone is having fun out there. I feel most comfortable with my rpms around 2400-2800 for highway crusing even though I could push it further, hence the overdrive. I've already driven the bus almost 1000 miles with the stock power/drivetrain since I bought it. Haven't blown it yet, thank you for wishing me the best. Also, I started this as a separate thread so that people who were interested could find it and add info, you didn't have to post anything if you just wanted to try to make me feel small. Thank you, that is all
Famousinternetjesus is offline   Reply With Quote
Old 08-11-2015, 01:14 AM   #54
Your welcome.
Glad to see your leaning how to search.
I don't see any other thread you have started here. You must mean you started one elsewhere.
I never did see any pics in this thread. Just a bunch of text. So really, none of it really happened.
I will say this. That 7.3 is a better match for that At545 than the 5.9 Cummins would have been.
The 7.3 will handle the RPM. The Cummins hate that RPM. Torque curve ends at 1600rpm.
For the record, I would never own a 7.3, and just sold the last AT545 I will ever own.
Big Cummins 8.3 and MD3060 for me.
Old 08-11-2015, 09:30 AM   #55
Chassis: S1700
Engine: 6.9l IDI
Good for you. This thread , I started it as separate from anything so that people people could add to it if they had an idea of how to achieve my goal, not so closed minded could tell me how dumb I am, thanks anyway though. I didn't start it so that a bunch of strangers could
Tell me what they think only style choices with my bus either, I only want mechanical input on different methods to achieve l
Old 08-11-2015, 09:30 AM   #56
Chassis: S1700
Engine: 6.9l IDI
lower rpms/higher cruising speed
Old 08-11-2015, 09:49 AM   #57
Engine: 466DT
I'm on my phone and at work, so I'll keep this short. I'm glad you started a thread, and hope you will keep it going. I would like to see the outcome right or wrong. The biggest part of life is taking chances and learning from them... FYI my bus WILL run 80 mph. Doesn't mean u SHOULD though. Haters Goin to hate.
Hvbuzz is offline   Reply With Quote
Old 08-11-2015, 09:54 AM   #58
Coachwork: IC
Chassis: CE300
Rated Cap: 32
Old 08-11-2015, 10:41 AM   #59
Chassis: S1700
Engine: 6.9l IDI
Something like this lol.
Old 08-11-2015, 01:02 PM   #60
Same, I want to see right or wrong.
We are just being hard on you because your lack of pics, searching, and post happy ways.
Post pics and video.
That video you linked shows a mess. Like I said before, with a standard trans, you can depress the clutch to stop the input from the engine before shifting the browny box. With a auto, you can't, and therefore will always be grinding gears in the browny box.
Grinding gears will rune them in short time.
There are massive right ups on pirate 4x4 about duel transmissions. Spider started the best thread explaining his trial and error.
6.9l, at545, auxiliary, brownie, faster highway speeds
