08-23-2018, 03:44 PM
#181
Engine: 6.6 New Holland Diesel
Rated Cap: 60 kids, 10 window
4/0 wires: cut, crimped, and heat shrink. Good grief their thick.
Installing a battery shutoff next. Have to head to Grainger tomorrow to pick up some more wire and 4/0 lugs.
My son decided to chase rolly pollies around with pliers under the bus this morning...
Grounding questions:
Is it okay to run the grounds from the solar and inverter to the negative busbar and ground that to the frame?
Or
Should I buy another busbar, run the grounds to that and then attach that to the negative busbar?
Or
Do they all need to be individually geiunded to the frame?
Nick
09-09-2018, 09:38 PM
#182
Shore Power is up and running. I've been charging my batteries and running tools off the inverter. The 3000 watt aims can't handle the start up from the 15000 rooftop dometic. I've been plugging that into the house. Solar will be up and running this week. Lots of progress inside. I'll post pics tomorrow.
Nick
09-10-2018, 08:11 PM
#183
Nick
09-18-2018, 03:40 PM
#184
Got a wall up and some lights on.
Man, sometimes I feel like I made this too.complicated.
Nick
09-18-2018, 07:02 PM
#185
One wall left in the toilet room
Nick
09-18-2018, 07:09 PM
#186
Engine: DTA360
Way to go man we have been neck and neck the whole build. Almost the same floor plan as well. Looks great
09-18-2018, 08:28 PM
#187
The trick is to just keep chippin away at it. So far, so good!
09-20-2018, 06:38 PM
#188
Anyone want to come over and help replace the seals on my power steering unit?
Nick
09-22-2018, 03:24 PM
#189
Soooo... The solar is working! I'll hook up the victim monitor tomorrow and the aims monitor as well
Nick
09-22-2018, 04:01 PM
#190
Rated Cap: 35
Originally Posted by Ninjakitty
like the ceiling material. what are the dimensions of it, cost, purchase location? still debating what is going in for my build. thanks. nice progress btw.
09-22-2018, 04:05 PM
#191
Soooo... The solar is working! I'll hook up the victim monitor tomorrow and the aims monitor as well Attachment 25951
What are you doing with your solar power that you need a "victim monitor" ?
Solar electric chair?
Or maybe you have been the victim of auto-correct
Perhaps it's a Victron monitor?
09-22-2018, 04:39 PM
#192
Lol. Autocorrect. A victim monitor would be cool though
Nick
09-22-2018, 04:41 PM
#193
It's 5 1/2" x 12' by 3/4" thick. Pre-primed. Home depot. I'll take a Pic of the label if I can find a piece with it
Nick
10-06-2018, 09:40 AM
#194
Nick
10-07-2018, 05:56 PM
#195
Nick
10-08-2018, 10:05 AM
#196
Sorry if I missed it previously. What size television is that? I want to do something similar and would like a larger tv ( 65"ish) I've considered projector and screen as well which might be easier.
10-08-2018, 10:54 AM
#197
Just did some research on safe viewing distances for TV's. Seems from 8' a 42" is the largest acceptable size. Granted we area only 7.5' wide, but I think bigger won't be any better. Also the pixel count is important depending on viewing distance. If moving closer you want to shy away from a 1080p to something in 4k range. Unless you're viewing down the aisle 65" might be a tad big.
10-08-2018, 02:40 PM
#198
viewing distances are a lot a Farse.. for the longest time I ran a 3200 Lumen DLP projecter in my living room at 1920 x 1080 and a diagonal screen size of 105". it was fantastic.. only issue was it wasnt bright enough to have the shades open in broad daylight.. when I replaced all my windows with larger ones in the house. and blinds that didnt block all the light then it was dim so I went to a 55" LCD 1080P TV in that room and sitting 10 feet away it seems too small.. and i'l likely upgrade to at least 65 soon.. I thinkl in a long skinny room like a buss bigger is better when it comes to TV.. although in a bus i might be much more inclined to have a pull down screen from the ceiling and use a projector since it folds away nicely when you dont need it..
then again that is one awesome GPS / Traffic / Weather / Multimedia music, etc screen right above the windshield for driving!!
10-08-2018, 03:01 PM
#199
I'm sitting 7 feet away from a 65" "monitor" and when our beloved Glasgow Celtic play I'm always wishing for a bigger screen!
10-08-2018, 03:55 PM
#200
Yeah, at 65" 4k now, but, had 720p 120' projection screen at 12' distance with no issue. To each their own. Mostly curious on the mounting strategy used.
