Old 10-08-2018, 04:01 PM   #201
Yeah, my tv serves as the monitor for my media server / AppleTv display ( Netflix, Amazon, HULU plus movies / music stuff stored on my computer, PS4 games etc... Last year I went from 60-65" and immediately wished it was bigger lol.
Chadci is offline   Reply With Quote
Old 10-08-2018, 04:26 PM   #202
Ninjakitty's Avatar
Engine: 6.6 New Holland Diesel
Rated Cap: 60 kids, 10 window
Originally Posted by Chadci View Post
Sorry if I missed it previously. What size television is that? I want to do something similar and would like a larger tv ( 65"ish) I've considered projector and screen as well which might be easier.
No, you didn’t miss it. My thread has been quick and sparse lately between trying to get done and not having a phone.
To answer your question, it’s a 43” screen. It’s ceiling mounted on a motorized drop down mount.
Mount: https://www.amazon.com/gp/aw/d/B01GG...op_mb_pd_title
TV: https://www.amazon.com/gp/aw/d/B01N2...op_mb_pd_title
Nick
Old 10-08-2018, 04:28 PM   #203
Ninjakitty's Avatar
As of now it’s lag screwed into the 3/4” ceiling. I will be putting some eye hooks to either side and strapping it for travel if I feel uncomfortable on my drive in the next couple days. Have to go out to get the counter tops templated.
Nick
Old 10-08-2018, 04:31 PM   #204
Ninjakitty's Avatar
Just did some research on safe viewing distances for TV's. Seems from 8' a 42" is the largest acceptable size. Granted we area only 7.5' wide, but I think bigger won't be any better. Also the pixel count is important depending on viewing distance. If moving closer you want to shy away from a 1080p to something in 4k range. Unless you're viewing down the aisle 65" might be a tad big.
It’s 4K. Haven’t seen anything in 4K on it yet as I’ve only watched antenna so far. But I’m getting about 20-30 channels. I like that I can have it stop at any point so we can watch it from any position Click image for larger version
Nick
Old 10-08-2018, 04:33 PM   #205
Ninjakitty's Avatar
1990 Ford Bluebird Conversion (No Name Yet)
then again that is one awesome GPS / Traffic / Weather / Multimedia music, etc screen right above the windshield for driving!!
That is true! I believe the head unit I have will allow for video output as well as audio input!
Nick
Old 10-08-2018, 04:34 PM   #206
Thank you for posting the links. I'd been looking at similar mounts on Monoprice. I hope you'll post a "review" after you've driven on some washboard roads ;)
Old 10-08-2018, 04:35 PM   #207
Ninjakitty's Avatar
I'm sitting 7 feet away from a 65" "monitor" and when our beloved Glasgow Celtic play I'm always wishing for a bigger screen!
I almost went bigger but I’m glad I didn’t just for the amount of room it takes up. I had a 50” in the house but it weighed a ton. This tv is super light. I bought it before I measured anything. I was going to just mount it to the front above windshield but it hung down to far into the windshield
Nick
Old 10-08-2018, 04:37 PM   #208
Ninjakitty's Avatar
Your welcome!
Yeah, I’ll probably strap it up for that. I may go back and some toggle bolts as well.
Nick
Old 10-08-2018, 05:09 PM   #209
Your welcome!
I believe I would as well! I may ultimately end up with another projection system just for simplicity, but, I would also need a "daytime" television / computer monitor etc. I remember my projector setup didn't work out too well in a lit room even with a higher gain screen.
Old 10-11-2018, 07:16 PM   #210
Ninjakitty's Avatar
Well, bought a bunch of lumber and then we went to pick out material for.thw couch cushions. That took about all day with 2 little kids.
I did manage to get the new door closer installed! The other one had bent too.much and wasn't as strong.Click image for larger version
ID:	26424the old one Click image for larger version
ID:	26426 the new one
Nick
Old 10-12-2018, 09:10 AM   #211
Ninjakitty's Avatar
Quick electrical update:
Added a 20 amp marine inlet for the rooftop a/c. It runs to its own 20 amp breaker and that runs to the rooftop unit.
The 30 amp twist lock inlet runs to its own 30 amp breaker before heading to the inverter/charger. The AIMS inverter/charger called for a 45 amp breaker there but I couldn't find a single pole 45 amp breaker. I figure with a 30 amp plug I can play it safe with a 30 amp breaker.
I will install a 25 amp breaker between the inverter and the load center for the 110volt which is what Aims specifies.Click image for larger version
ID:	26434Click image for larger version
ID:	26435Click image for larger version
ID:	26436Click image for larger version
ID:	26437Click image for larger version
ID:	26438Click image for larger version
ID:	26439Click image for larger version
ID:	26440Click image for larger version
Nick
Old 10-12-2018, 02:09 PM   #212
Ninjakitty's Avatar
I made a box!Click image for larger version
Nick
Old 10-12-2018, 02:14 PM   #213
Ninjakitty's Avatar
On another note, I forgot to label my 110 wires as I pulled them through the conduit. I have just one wire that needs to go to a 20 amp breaker. Can I use a 12 volt light connected to one of the lines to check which wire it is? I have three runs in the conduit, so I figure I'll attach a light to the that is sticking out and take a 9 volt battery to see which one it is? Would that work?
Nick
Old 10-12-2018, 03:21 PM   #214
Mountain Gnome's Avatar
Chassis: TC1000 HandyBus
Rated Cap: 26 foot
Yep.
Or use a multimeter with an ohm gauge, but then you would need a long lead on the ohmmeter to reach each end of the wire. Your way is easiest.
Old 10-12-2018, 03:45 PM   #215
Ninjakitty's Avatar
Thanks Gnome! I don't have my 110 run into the load center yet. Thanks for that affirmation
Originally Posted by Mountain Gnome View Post
Yep.
Nick
Old 10-12-2018, 06:34 PM   #216
Yep.
Using the ohmeter you just ground each wire at one end, then check each wire to ground at the other end. No need for long wire in between.
Old 10-16-2018, 08:13 PM   #217
Ninjakitty's Avatar
Couch almost doneClick image for larger version
ID:	26595Click image for larger version
ID:	26596Click image for larger version
Nick
Old 10-19-2018, 10:47 AM   #218
Ninjakitty's Avatar
I'll start a new post about this in the electrical section and add pictures, but:
Pretty sure my bus is all mechanical. I'm pretty sure I've narrowed down which relay is for the blinkers. Now, except for hooking up a hazard flasher relay are there any relays I should keep?
Nick
Old 10-19-2018, 10:50 AM   #219
Your bus is all mechanical.
Old 10-19-2018, 10:55 AM   #220
Ninjakitty's Avatar
So if I understand that correctly, I can probably remove all this garbage?
The second photo runs to a ground and them this solenoid (third pic)
Fourth pic runs to this relay (fifth pic)Click image for larger version
ID:	26669Click image for larger version
ID:	26670Click image for larger version
ID:	26671Click image for larger version
ID:	26672Click image for larger version
Nick
