Old 10-12-2018, 09:10 AM   #211
Ninjakitty's Avatar
Engine: 6.6 New Holland Dies
Rated Cap: 60 kids, 10 window
Quick electrical update:
Added a 20 amp marine inlet for the rooftop a/c. It runs to its own 20 amp breaker and that runs to the rooftop unit.
The 30 amp twist lock inlet runs to its own 30 amp breaker before heading to the inverter/charger. The AIMS inverter/charger called for a 45 amp breaker there but I couldn't find a single pole 45 amp breaker. I figure with a 30 amp plug I can play it safe with a 30 amp breaker.
I will install a 25 amp breaker between the inverter and the load center for the 110volt which is what Aims specifies.IMG_20181012_100147.jpegIMG_20181012_100156.jpegIMG_20181012_100215.jpegIMG_20181012_100249.jpegIMG_20181012_100253.jpegIMG_20181012_100301.jpegIMG_20181012_100257.jpegIMG_20181012_100314.jpeg
Nick
Old 10-12-2018, 02:09 PM   #212
Ninjakitty's Avatar
Nick
Old 10-12-2018, 02:14 PM   #213
Ninjakitty's Avatar
On another note, I forgot to label my 110 wires as I pulled them through the conduit. I have just one wire that needs to go to a 20 amp breaker. Can I use a 12 volt light connected to one of the lines to check which wire it is? I have three runs in the conduit, so I figure I'll attach a light to the that is sticking out and take a 9 volt battery to see which one it is? Would that work?
Nick
Old 10-12-2018, 03:21 PM   #214
Mountain Gnome's Avatar
Chassis: TC1000 HandyBus
Rated Cap: 26 foot
Yep.
Or use a multimeter with an ohm gauge, but then you would need a long lead on the ohmmeter to reach each end of the wire. Your way is easiest.
Old 10-12-2018, 03:45 PM   #215
Ninjakitty's Avatar
Thanks Gnome! I don't have my 110 run into the load center yet. Thanks for that affirmation
Originally Posted by Mountain Gnome View Post
Yep.
Nick
Old 10-12-2018, 06:34 PM   #216
Yep.
Using the ohmeter you just ground each wire at one end, then check each wire to ground at the other end. No need for long wire in between.
Old 10-16-2018, 08:13 PM   #217
Ninjakitty's Avatar
Couch almost doneIMG_20181016_211010_01.jpegIMG_20181016_211013_01.jpegIMG_20181016_211016_01.jpeg
Nick
Old 10-19-2018, 10:47 AM   #218
Ninjakitty's Avatar
I'll start a new post about this in the electrical section and add pictures, but:
Pretty sure my bus is all mechanical. I'm pretty sure I've narrowed down which relay is for the blinkers. Now, except for hooking up a hazard flasher relay are there any relays I should keep?
Nick
Old 10-19-2018, 10:50 AM   #219
Your bus is all mechanical.
Roll Your Own Build Thread
Old 10-19-2018, 10:55 AM   #220
Ninjakitty's Avatar
So if I understand that correctly, I can probably remove all this garbage?
The second photo runs to a ground and them this solenoid (third pic)
Fourth pic runs to this relay (fifth pic)1539964316941.jpeg1539964336520.jpeg1539964434869.jpeg1539964461848.jpeg1539964507378.jpeg
Nick
