Old 12-10-2010, 08:20 PM   #1
reddog's Avatar
Year: 90
Chassis: Transitliner
1990 Thomas Transitliner- "Thomas" Hormone Derange
Hello to all,
I used to lurk on this site some and then life and my project go in the way. I just purchased another 1990 Bluebird and came back for some info. Thought it fair to show off the first project before I start asking questions about the second. Here are a few particulars:
1990 Thomas Transitliner, 37', 8.3L Cummins/Allison
22.5 tires on alloys all around
Propane injection
3) 8D bus batts/4) 6V golf cart house batts
5KWHonda Genset/3500W Xantrex inverter/charger
175W solar panel
blah, blah, blah
here is a link to some pics:
http://ImageEvent.com/reddog/1990thomasbuiltbusdogbus
Hopefully I can learn and share a few ideas here. Best to all, Doug@8000'
"What!?! You bought ANOTHER bus!!!"
reddog is offline   Reply With Quote
Old 12-11-2010, 09:45 AM   #2
yankeflyer's Avatar
Chassis: Safe T Liner
Engine: 3208 turbo
Re: 1990 Thomas Transitliner- "Thomas" Hormone Derange
Propane injection
whats that all about ?
yankeflyer is offline   Reply With Quote
Old 12-11-2010, 02:57 PM   #3
Stuff's Avatar
propane is to diesel as nos is to gas engines.
Old 12-11-2010, 03:29 PM   #4
yankeflyer's Avatar
Engine: 3208 turbo
Way cool - never heard of that set up - sure would like to see it close up.
Old 12-11-2010, 05:55 PM   #5
Engine: DTA360
Rated Cap: 16
Very slick...
I love the fab work you did with the square tubing...
A lot of the inside of my bus will be done with tubing and angle...
How did you attach everything to the bus??? Screws or did you weld it in place???
dirtygoat is offline   Reply With Quote
Old 12-11-2010, 07:02 PM   #6
yankeflyer's Avatar
Engine: 3208 turbo
These projects just get better and more sophisticated as they show up.
Old 12-12-2010, 08:35 AM   #7
reddog's Avatar
Year: 90
Thanks for the compliments. The steel work is mostly fastened with screws. I did use riv-nuts on many spots where I thought more strength was called for. It has worked well so far, virtually no squeeks or rattles.
The propane injection setup was really simple, especially since I already had propane onboard. It is similar to NOS in that you get increased HP with little mechanical alteration. However, in a NOS system, you usually inject additional gasoline that can be burned due to the NOS in the air/fuel mixture. Propane, as it is used on my bus, just allows you to burn unburned fuel that would normally pass out the tail pipe as black smoke. When the bus starts to "overfuel", like while climbing a grade, I can turn the propane on, the smoke disappears and I start to accelerate again. From everything I have read, as long as you do not exceed reasonable HP limits for the engine, propane won't hurt anything. I think it is in the situations where propane is added to an engine that already has been "chipped" or even has "stacked chips" that the additional HP creates a problem. Doug@8000'
Old 12-14-2010, 12:13 PM   #8
Stuff's Avatar
Originally Posted by Smitty
Welcome Doug! Sweet bus!
Does that also include the melt-downs?
Smitty
lol i think the diesel would be more catastrophic... but im not sure how the injection works. could be for cold starting, could be for passing, could be for when you need more power like on a steep grade.
Old 12-16-2010, 09:22 AM   #9
reddog's Avatar
Year: 90
John, My Cummins is all mechanical, so I don't know how it might affect your system. I do know several other guys around here that run it on electronic injection systems with no problem. As far as I can tell, no increase in EGT (possibly a slight reduction, less burning fuel passing thru the turbo) and no engine temp increase. I try not to flog the beast too bad, and using the propane seems to make pulling the grades easier on the rig overall. Doug@8000'
1990 International - "Moby Dick" npeace Skoolie Conversion Projects 8 09-11-2016 05:46 PM
"Terrapin" the 1989 Thomas Skip Skoolie Conversion Projects 29 01-14-2014 01:28 PM
1986 Intl/Thomas Conventional, DT466 5speed, "Big Blue Bus" thrash Skoolie Conversion Projects 8 08-25-2013 11:57 AM
1982 Thomas Safe-T-Liner "Illusion" Les Lampman Skoolie Conversion Projects 89 02-28-2007 07:41 AM
"Seeker" - 1989 Thomas Pusher - www.vonslatt.com vonslatt Skoolie Conversion Projects 46 05-22-2006 07:14 PM
