Old 05-19-2012, 11:48 PM   #1
Chassis: Carpenter
Engine: Diesel
1991 Thomas School Bus ~ Wiring Diagram needed.
We need some help.
We have a 1991 Thomas School bus, diesel.
It ran when we bought it and drove it the 50 miles to our house. We have ran it several times in the past 3 months while parked in our driveway during our conversion.
My husband desperately needs a wiring diagram as he has somehow inadvertently done something to the wiring and now the bus will not start.
We are attempting to wire up a 12volt water pump to the existing electrical system.
Any help would be greatly appreciated.
Thanks
https://www.TheRoadFamily.com
roadfamily6now is offline   Reply With Quote
Old 05-21-2012, 12:43 PM   #2
Chassis: Carpenter
Engine: Diesel
Re: 1991 Thomas School Bus ~ Wiring Diagram needed.
thanks a million! I'll look them up right now!
Old 05-21-2012, 12:55 PM   #3
problem is probably some wire your disconnected, there should be a panel wiring diagram on the side panel where the sign, etc is. there are a number of things that will make it not start. everytime you mess with the wiring in the bus - except for headlight stuff, you should check to see if it will start. so you gotta remember what you do, and maybe write it down so you can re asemble the wiring as it was in the first place.
i havent done this, but one could bypass all that extra wiring, and just run a wire to the switch to the fuel soliniod. i have done that on excavators more than once, as the big ones occasionally get broken wires from all the vibration...
you can always start at the last thing you did, put those wires back in the correct order, and go from there.
also, if you disconnect some of the wires from things like the side door if you have one, one has to be grounded, and the other two have to be hooked together...
Just Right Bus: 1991 Ford Thomas School Bus Conversion kellyetross Skoolie Conversion Projects 12 02-15-2017 10:51 AM
Help: Need a wiring diagram bhays Alternative Fuels | Electric, Propane, Wood & Biofuels 8 03-09-2012 08:21 AM
Wiring Diagram El Mastodonte Conversion General Discussions 0 07-25-2010 12:45 PM
Wiring Diagram 1981 IH school bus jerhutch Conversion General Discussions 4 08-20-2008 09:45 AM
Needed wiring diagram for '68 Bluebird (Ford B-500) shorty KaptnKAOS Classifieds | Buy, Sell, Swap 0 03-21-2007 01:09 PM
