Old 07-23-2019, 09:02 PM   #121
Thanks folks, the air space for the mattress is not something I had thought about.
Old 07-23-2019, 11:06 PM   #122
HazMatt's Avatar
Chassis: IH 3800, 8 window
Like less savory shtuff, water rolls downhill.
Even if it's a marginal quantity like perspiration, it accretes with no easy egress.
Old 07-23-2019, 11:16 PM   #123
Yup......
And the result is near toxic waste...
Old 07-29-2019, 11:01 PM   #124
Coachwork: Thomas Built Buses
Chassis: FS-65
Rated Cap: 66/44
More work happened this weekend. It's starting to come togetherClick image for larger version
ID:	36064Click image for larger version
ID:	36065Click image for larger version
Ab01ns is offline   Reply With Quote
Old 08-10-2019, 09:54 AM   #125
Chassis: FS-65
Rated Cap: 66/44
ProgressClick image for larger version
Old 08-10-2019, 11:26 AM   #126
Very cool, enjoy that double OD!
Old 08-10-2019, 11:29 AM   #127
Chassis: FS-65
Rated Cap: 66/44
Oh I sure will. Did the unlock through PCM performance and I couldn't recommend them enough. Great service
Old 08-10-2019, 11:45 AM   #128
What's in the rear diff and what's your tire size?
Old 08-10-2019, 11:53 AM   #129
Chassis: FS-65
Rated Cap: 66/44
5.57 10r22.5
Old 08-10-2019, 12:26 PM   #130
Originally Posted by Ab01ns View Post
5.57 10r22.5
Well I can think of one upgrade for you down the road.
With your variety of gearing I'd be inclined to try some 11R's if you ever need a new set of tires.
Would get you a few less rpm's at speed and they're cheaper and easier to find than 10R's.
Old 08-11-2019, 12:30 AM   #131
Okay, now I am jealous! Congratulations!
Old 08-11-2019, 09:55 AM   #132
Chassis: FS-65
Rated Cap: 66/44
That is a planned upgrade. A friend has a pile of 10r's that I'm using up first.
However a 11r upgrade isn't as simple as it sounds, you need new rims too as 11s use a rim that is 3/4" wider than 10s
When the bus is done I will get a set of Aloca rims for it sized for 11rs and polish them up to be like a mirror, but that is a future project
Old 08-11-2019, 10:04 AM   #133
However a 11r upgrade isn't as simple as it sounds, you need new rims too as 11s use a rim that is 3/7" wider than 10s
11R's will work on the wheels for your 10R's. They'll go down as low as a 7.5" wheel most of the time. I've got 10R's and the tire shop has already told me 11R's will work just fine. You don't want them touching, but mine and all the buses I've had have had plenty of spacing in the rear.
The 11R's are good for a couple more mph. I'd run em on mine but I'm already geared super high and don't want any more reduction in rpm's.
I'd take advantage of a free pile of 10R's too, though!! Good score, man!
Old 08-11-2019, 10:25 AM   #134
Chassis: FS-65
Rated Cap: 66/44
That would go against what my tire man had said as well as manufacturer literature that I've read
Old 08-11-2019, 11:00 AM   #135
Not here to argue, but 11r's are perfectly fine on 7.5" wheels, man.
TIRE SIZE APPROVED RIM WIDTH MINIMUM
DUAL SPACING*
TUBE-TYPE
11.00R24 8.5, 8.50VM, 8.0, 7.5 13.2
12.00R24 9.0, 8.5, 8.50VM, 8.0 14.1
TUBELESS
9R17.5HC 6.75HC 10.3
215/75R17.5 6.00HC, 6.75HC 9.3
245/70R17.5 6.75, 7.50 10.6
8R19.5 5.25, 6.00, 6.00RW, 6.75, 6.75RW 9.1
9R22.5 6.00, 6.75, 7.50 10.3
10R22.5 6.75, 7.50, 8.25 11.4
11R22.5 7.50, 8.25 12.5
12R22.5 8.25, 9.00 13.5
225/70R19.5 6.00, 6.00RW, 6.75, 6.75RW 10.0
245/70R19.5 6.75, 6.75RW, 7.50, 7.50RW 11.0
265/70R19.5 7.50, 7.50RW, 8.25, 8.25RW 11.6
285/70R19.5 7.50, 8.25, 9.00 12.5
305/70R19.5 9.00, 8.25, 8.25RW 13.5
445/65R19.5 1
https://www.doublecointires.com/wp-c...-InfoSheet.pdf
https://www.hdpsales.com/matchingtires.htm
https://www.michelintruck.com/assets...ok_Jan2007.pdf
Old 08-11-2019, 12:00 PM   #136
Chassis: FS-65
Rated Cap: 66/44
Awesome. That is good info to have thanks for it.
Always here to learn more not to argue lol
Old 08-11-2019, 12:24 PM   #137
Got a full set of rims and tires for sale for $1k, off an 97 BB, ready to mount. 11 x 22.5
Old 08-11-2019, 01:43 PM   #138
Chassis: FS-65
Rated Cap: 66/44
Not interested. A friend has more alocas than he knows what to do with, when I want to make the upgrade I will just do that
Old 08-11-2019, 09:39 PM   #139
How far is this friend from FL and can I get some Alcoas??
Old 08-11-2019, 11:01 PM   #140
Chassis: FS-65
Rated Cap: 66/44
[emoji1787]
Toronto area. No idea if he'd want to part with them
