Old 06-20-2012, 05:26 PM   #201
TygerCub's Avatar
Engine: Detroit
Re: 2012... The Year of Renewal
Originally Posted by crazycal
You are doing a great job on the bus. Are you trying to show off your feet?
Unfortunate accident.
I added the last wall to the tank and dragged the thing under the bus for a test fit. Good thing too since I will have to cut an inch off the side. It's a PITA to maneuver up into the space too. Looks like I'll have to switch the bolts on the tailpipe from pointing up, to down to avoid scratching along the bottom.
Well... back to it.
Old 06-20-2012, 06:19 PM   #202
browncrown's Avatar
Rated Cap: 79 at Birth
I'm sure we can all relate to that...skoolies were never built to have holding tanks
BC
Old 06-20-2012, 09:12 PM   #203
TygerCub's Avatar
Engine: Detroit
WOO HOO! Phase One of creating a custom tank is finished:
Now to test fit it ONE MORE TIME (tomorrow) and then start planning my fiberglass attack!
Old 06-20-2012, 09:28 PM   #204
crazycal's Avatar
are you raising the bus to fit the tank?
I'm hungry!
You Gotta Let Me Fly
Old 06-20-2012, 09:45 PM   #205
pipopak's Avatar
Looking forward. You can see how much space the pipe takes. What's strange is it's lower here than at the exit. I would think this would make it trap condensation at the low end and cause a rust spot in that area. Whatever.
Stupid question: is there a valid reason to have the exhaust pipe taking all that space instead of running paralell to the chassis?. It is a lot easier and cheaper to reroute it than going around it with everything else.
pipopak is offline   Reply With Quote
Old 06-20-2012, 10:14 PM   #206
TygerCub's Avatar
Engine: Detroit
Not a stupid question.
I actually want to re-route the tailpipe. But right this minute, I'm kinda tight on time. I do not personally have the tools or the skills to change the pipe out, and the guys I know that can do it are busy now that summer is here and/or have other obligations at the race track.
So, I'm stuck being innovative. I would rather have moved the tailpipe and installed a normal square tank. But as it stands, I get to learn a new skill (fiberglass) and have the satisfaction of slamming my head repeatedly against the bolt that sticks out of the counterweight
Old 06-21-2012, 04:48 AM   #207
Go to auto parts store and buy a foot or two of rubber hose,cut two pcs an inch longer than the two c-channels split them in half length wise(1 slice)open them up and slide onto metal...instant bumper and then slide 2 pcs over the thread 1/2 longer and the bolts won't hurt as much
Old 06-21-2012, 06:10 PM   #208
TygerCub's Avatar
Engine: Detroit
Awesome idea! Thank you!
Well... some bad news/good news.
Bad news... One of the guys at work that works fiberglass all the time (makes boats and surfboards) said that while the tank was cool and congrats on the unique solution to a difficult problem... it won't work for fiberglass. He said the edges are too sharp for the glass to handle. I'll need to round the edges over somehow, or just make it out of metal.
Good news... I have several sheets of 2" foam left. I can make another tank form out of it and easily round over every curve and edge with ease. It will be a mess, but easier than welding that much sheet metal in this heat.
So that's what I'll be doing this weekend instead of glassing. Minor setback, but the way this build has been going, it's not really unexpected
Old 06-22-2012, 09:18 AM   #209
so i assume the guy who works with fiberglass is concerned about the stress loading... that is what reinforcing during the construction is for.
Old 06-22-2012, 10:12 AM   #210
lornaschinske's Avatar
Rated Cap: 89
Fiberglass on Plywood Tanks
by George Myers
Fulltime since 2006
What year is your bus? Skunky Bus Conversion General Discussions 25 05-22-2015 12:14 AM
what year is my bus??! please help!! emo Conversion General Discussions 11 09-02-2013 04:31 PM
Happy New Year travelinwithus Everything Else | General Skoolie Discussions 5 01-01-2013 11:45 AM
1996 GMC BlueBird w/ 6.4 L .....bus to TELLURIDE 2012 telluriders Skoolie Conversion Projects 63 07-06-2012 09:15 AM
Time of year to buy? vonslatt Everything Else | General Skoolie Discussions 4 11-10-2004 09:45 PM
