08-18-2017, 04:53 PM
#141
Colossus...8th wonder of the world! Awesome!
Don, Mary and Spooky the cat.
08-19-2017, 12:24 AM
#142
Engine: gasser probably
Man, after you are done with that bus. Please make a complete walkthrough video. That bus is going to look amazing!
Sent from my Life One X using Tapatalk
08-19-2017, 11:11 AM
#143
Coachwork: Eldorado National
Chassis: ESCORT RE
Engine: Cummins B5.9
Rated Cap: 32
WOW! that thing is awesome!
Trust in the Lord with all thine heart; and lean not unto thine own understanding. Proverbs 3:5
In all thy ways acknowledge him, and he shall direct thy paths. Proverbs 3:6
08-20-2017, 09:33 PM
#144
Chassis: Thomas Saf T Line
Engine: 8.3L Cummins
thank you guys.
08-21-2017, 12:43 AM
#145
so these were from this spring.
08-21-2017, 10:08 AM
#146
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
Originally Posted by zoomy
thank you guys.
Your fab skills are off the hook. Looks like a Motorcoach frame. Wonderful space.
Where is it on the scales now? What is your manufacturer max GVWR?
How bad is it in a crosswind? Can you feel semis move you?
Thanks for sharing the videos.
08-22-2017, 10:40 PM
#147
thank you. i like making things with any media possible.
i have only driven it about 3 mile and I still have not taken it to dmv to get it registered as an RV so don't know any of that stuff yet. but it drove nice for those 3 miles.
07-24-2018, 10:55 AM
#148
This is such a cool build. Definitely following... would love to see an update on the project!
07-24-2018, 11:38 AM
#149
What gauge is the new skin?
07-24-2018, 12:01 PM
#150
I noticed that also, should have used something thicker.
07-24-2018, 12:06 PM
#151
I'm using 16 gauge and steel. Also only doing a 15" raise which gives me a span of about 42"-43" if including the ~ 1 1/2" overlap top and bottom.
07-24-2018, 12:16 PM
#152
I'm not understanding what you mean here?
07-24-2018, 12:21 PM
#153
My roof line is only going up 15" from where it sits now but I'm removing the 24" that are the OEM windows. That's 39". To that, I've have (hopefully) and 1 1/2" overlap under the eyebrows at the top and about 2 - 2 1/2" overlap under the rub rail. That means the sheet metal needs to be cut down from 48" to ~43". I've not cut any of it until I get the first piece up just to see how much I can force on the overlaps. The more the better in my opinion. At a minimum I need enough to drill holes and re-rivet.
07-24-2018, 12:24 PM
#154
Gotcha. 2-2-1/2" overlap is aggressive
07-24-2018, 12:28 PM
#155
No way in hell I'll get that at the top without removing both rows of rivets. The rub rail however is 5+ (???) inches wide. I don't remember what it measures but it's a fair bit more than 4". I think the rivets for the rub rails are close to 4" on center. So, getting it to tuck under the rub rail by 2 1/2" would be easy peezy. Removing them entirely and putting them back wouldn't be too big of a PITA. That upper row of rivets tho. That would be a huge PITA.
10-06-2020, 12:15 AM
#156
So i guess its been about 3 years sense i have been on here..... still not finished but we have been living in it full time for several years. I started up a company so that, being a dad, and taking care of the farm have kept me pretty busy. Oh and I drove for the local school district for a year or 2....till covid kicked off
10-06-2020, 08:32 AM
#157
That looks awesome, I've been thinking about a bit of climbing-wall stuff for my bus, but on the outside.
