Old 06-18-2017, 11:16 PM   #11
david.dgeorge07's Avatar
Chassis: Thomas
Engine: CAT 3126
Between the floor and wall there is some kind of tar like sealer. When you get your wire brush in it, it just smears everywhere. Any tips on how to navigate this when preping/painting?
Sent from my SM-N900P using Tapatalk
My Build Thread:
http://www.skoolie.net/forums/f11/4-...ner-18205.html
Old 06-19-2017, 12:56 AM   #12
Robin97396's Avatar
Chassis: TC 1000
Engine: 5.9
Send a message via Yahoo to Robin97396
That kind of looks like butyl. It's going to be burried by time you put the floor in, so rather than remove the butyl and then reseal the area why not just leave it there.
If you do want to remove it a putty knife is about the only way. It's sticky and gets on everything, but it's good stuff. It's been there for about 20 years.
Old 06-19-2017, 09:08 AM   #13
Chassis: Thomas
Engine: CAT 3126
Originally Posted by CaptSquid View Post
They left the "Silent Witness" in my beastie, too. Even left the tape in the recorder. Got out the Sawzall and removed the device, which opened up a lot of dash space. The camera was easy -- only 3 screws and a pair of diagonal cutters and 'poof', they were GONE!
Ah, makes sense! Thanks for the info!
My Build Thread:
Old 06-19-2017, 09:10 AM   #14
Chassis: Thomas
Engine: CAT 3126
Yes, I'm not worried about how it looks. Just seems like a mess to deal with. Oil based primer might act like a solvent, but I don't want to stay completely away from it because I need to get the metal all around it. I guess I'll try to keep it organized and paint up to it but not slather over it.
My Build Thread:
Old 06-19-2017, 11:14 AM   #15
Robin97396's Avatar
Chassis: TC 1000
Engine: 5.9
You could make a little test area where you've already disturbed the butyl to see if there's any reaction. Butyl is a very old sealant and I'm sure people have painted over it before, although I'm no expert on the subject.
Old 06-19-2017, 11:27 AM   #16
Chassis: Thomas
Engine: CAT 3126
Just about ready to prime the floor.
My Build Thread:
Old 06-19-2017, 01:22 PM   #17
Robin97396's Avatar
Chassis: TC 1000
Engine: 5.9
You're making pretty good time. Are you pulling the ceiling and wall panels?
Old 06-19-2017, 03:51 PM   #18
Chassis: Thomas
Engine: CAT 3126
Well, that was easy compared to all the prep! Yes, I am planning to pull walls and ceiling for insulation. Very thankful to have screws instead of rivets.
My Build Thread:
Old 06-19-2017, 03:56 PM   #19
Robin97396's Avatar
Chassis: TC 1000
Engine: 5.9
I've never had the luck to get a bus with screwed ceiling panels. I have a strong aversion to rivets.
If you're having your insulation sprayed in by a contractor, don't accept foundation grade foam. It's like sawing wood during the trim process.
Old 06-19-2017, 04:04 PM   #20
Chassis: Thomas
Engine: CAT 3126
That's a good tip! Is there a name for what you do want?
My Build Thread:
