Old 06-19-2017, 03:49 PM   #21
Robin97396's Avatar
I was told that mine was a 3 pound closed cell foam normally sprayed on the exterior of new foundations. I don't know enough about foam to tell you what to get or not get. This guy sprayed my bus for the cost of a larger 800 sf do-it-yourself spray foam kit. If I were to do the insulation again I'd buy the kit and do it myself. The contractor spray guy didn't really give a carp about doing a good job on my bus. If I were to use spray foam again I'd get the kit and do it myself. Nobody will do the quality of work that you'll do on your own bus. That's my best tip.
Robin
Nobody's Business
Old 06-19-2017, 10:33 PM   #22
david.dgeorge07's Avatar
Chassis: Thomas
Engine: CAT 3126
I have found that to be totally true with hiring someone to work on your house, so it makes sense that it would be true in this case.
Sent from my SM-N900P using Tapatalk
My Build Thread:
http://www.skoolie.net/forums/f11/4-...ner-18205.html
Old 06-25-2017, 09:46 AM   #23
Good looking bus! Good luck on the build!
superduty_59 is offline   Reply With Quote
Old 06-25-2017, 08:57 PM   #24
Chassis: Thomas
Engine: CAT 3126
Thanks! It's coming along!
My Build Thread:
Old 06-25-2017, 08:58 PM   #25
Chassis: Thomas
Engine: CAT 3126
Patching the holes with flashing tape.
My Build Thread:
Old 06-25-2017, 09:02 PM   #26
Chassis: Thomas
Engine: CAT 3126
Finally finished getting the coolant loop out of the rear passenger compartment. It wasn't much fun, but got easier when I found an access panel with four screws. It allowed me to get right at what I needed to!
My Build Thread:
Old 06-25-2017, 09:08 PM   #27
Chassis: Thomas
Engine: CAT 3126
Getting the floor insulated.
My Build Thread:
Old 06-25-2017, 09:35 PM   #28
remember if you completely remove the heater loop that goes from the back to the front in a rear engine bus without replacing it.. you will not have any heating or defrosting capabilities for the windshield or while on the road...
Old 06-25-2017, 11:58 PM   #29
Chassis: Thomas
Engine: CAT 3126
Yep, project for a later date. Plan to route lines underneath.
My Build Thread:
Old 06-26-2017, 09:35 AM   #30
Chassis: Thomas
Engine: CAT 3126
Does anyone know what the wire is that runs along with the coolant lines from the back of the bus to the front? It is kind of strange.
Two coolant lines and a seemingly random wire all the way from the back to the front. Looked like it was grounded out to part of the plumbing in the back in disappears into the dash in the front.
Any light you can shed is appreciated.
My Build Thread:
