07-09-2017, 07:05 PM
#61
Chassis: Thomas
Engine: CAT 3126
Hmm. It has no tablets...
Sent from my SM-N900P using Tapatalk
07-09-2017, 07:17 PM
#62
it says it does in the description.. though they may not rattle.. its the filter I use on my other bus that has a DT-360 and green coolant..
07-09-2017, 09:59 PM
#63
Chassis: Thomas
Engine: CAT 3126
You're right. I asked for the one without pellets and when this didn't rattle I assumed that it was right. It isnt.
07-09-2017, 10:15 PM
#64
Chassis: Thomas
Engine: CAT 3126
Looks like the 4070 should do the job. I'll exchange tomorrow.
07-10-2017, 10:46 AM
#65
Chassis: Thomas
Engine: CAT 3126
Third time is the charm.
07-10-2017, 08:38 PM
#66
Chassis: Thomas
Engine: CAT 3126
Got the flush and fill finally done! Only tricky part was getting the old filter off. Chain vice grip finally did the trick.
07-10-2017, 08:41 PM
#67
people always WAY overtighten any kind of filters it seems...
07-11-2017, 05:59 AM
#68
Engine: 5.9 Cummins 12v & 24v
I agree filters seem to always be a pain to remove especially if some 1 else installed them, sometimes over tightens or they dont lube the gasket before installation. worst case scenario is punch a thick screwdriver right thru filter and turn if a strap type cant do the job.
its true the 4071 is a SCA filter and should be used on engines with wet-sleeves. as long as people test they coolant for freeze protection and adequate SCAs, i would think they could use any coolant/filter combination thats compatible with each other. we have always used regular green antifreeze with SCA filter changes every 400 hours for decades with no problems,
We had a farm tractor (IH 1066) powered by IH DT-414 and the previous owner didnt change coolant filter it can cause electrolysis which will more or less be very expensive and cause engine tear down.
07-11-2017, 07:11 AM
#69
you should not be using an SCA filter though if you are using an ELC coolant.. the later versions of most of these engines werre built to handle ELC coolants.. Nasvistar for sure posted a set serial number break for the use of an ELC coolant in the 444E, ford did similar (7.3) based on the recommendation of navistar..
not all ELC coolants are alike!. generally synthetic coolans like the AMSoil stuff is designed to work across the board..
its not only wet sleeve engines.. cavitation issues plagued the 6.9 and 7.3 IDI engines early on.
07-11-2017, 09:06 AM
#70
Chassis: Thomas
Engine: CAT 3126
Even after some initial missteps I feel confident in the work I've done with the coolant change. The documentation from PEAK's website (the writeup of the attributes and application) the Thomas manual for the bus, and finally getting the right filter. Flushing the system, running it up to temperature on garden hose water, flushing it again and flushing it with distilled water, changing the (finally correct) filter, and finally filling and bleeding with the Final Charge. Thanks for all the guidance along the way @cadillackid and @LectricLance!
07-20-2017, 06:30 PM
#71
Chassis: Thomas
Engine: CAT 3126
I've come to a fork in the road: whether or not to raise the roof. I've read a lot about it and am leaning towards doing it, but I'm worried that it will scare away insurers. Advice? Oh...and I'm not talking about adding a Vanagon or anything like that! Talking about a 6-12" raise that would keep a pretty standard look.
07-25-2017, 06:26 PM
#72
Coachwork: Crown / Pusher
Don't tell unless they ask, Only questions I was asked was
Has the suspension been altered in anyway
Is it on a van chassie
How many miles a yr do you think you'll put on it.
07-26-2017, 07:25 AM
#73
Chassis: Thomas
Engine: CAT 3126
I've already got insurance up til when I have completed the conversion. They asked for pictures before so they will see any changes if they take the trouble to compare.
07-29-2017, 10:35 PM
#74
Chassis: Thomas
Engine: CAT 3126
Well I have decided not to do a roof raise. I am the tallest member of the family and I can stand up, so it seems like a lot of time and energy for a modest benefit.
07-29-2017, 10:37 PM
#75
Chassis: Thomas
Engine: CAT 3126
07-29-2017, 10:38 PM
#76
Chassis: Thomas
Engine: CAT 3126
In other news after removing a million screws the ceiling panels are down!
08-12-2017, 01:09 PM
#77
Chassis: Thomas
Engine: CAT 3126
Slow Progress
Work has kept me from making much progress but I have got the the thing water tight finally! Marker lights, roof hatches, removed signs etc. were all letting in lots of water.
Also, got the thing out on the interstate and it drove very nicely! Anyone know what is a healthy RPM range for a CAT 3126b? I'm working with the local Allison rep to unlock 6th gear, but until then I'm wondering what is safe to run the thing at. I can get up to 65, but pushing 2400RPM.
08-12-2017, 01:16 PM
#78
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
Yeah, it'd be nice to get the RPM's down/ top speed higher. New rear-end gears may be in order.
My Allison shop quoted $300 to flash.
08-12-2017, 01:28 PM
#79
Chassis: Thomas
Engine: CAT 3126
Mine quoted $150 which seems reasonable. With 6th gear unlocked it seems like the rear end should be ok as long as I don't want to do more than 65 or so - but that's just a guess until I have a better idea of what the ideal RPM is.
08-12-2017, 02:15 PM
#80
Traveling
Rated Cap: '00
Shoot, dawg. Jump on that.
look for this sticker for your exact configurations max rippem's
