Old 08-12-2017, 03:26 PM   #81
david.dgeorge07's Avatar
Chassis: Thomas
Engine: CAT 3126
Good call! Max RPM is 2400. Some other forums suggest 2000 is a good cruising RPM. Not sure what ratio 6th is but seems likely it has been engineered to a good final cruising ratio.
My Build Thread:
http://www.skoolie.net/forums/f11/4-...ner-18205.html
Old 08-12-2017, 03:52 PM   #82
Chassis: International S3800
if you have allison MD-3060 your ratio will be .65 in 6th (.75 in 5th).
2000 - .74 in 5th and .60 in 6th
1000 - .71 in 5th and .60 in 6th
Old 08-12-2017, 08:02 PM   #83
Chassis: Thomas
Engine: CAT 3126
Thanks Christopher! I did some math at it looks like the bus is designed to max out at about 70mph in 6th gear, and to cruise most fuel efficiently around 55-60mph in 6th gear. Wouldn't mind getting a little more top end, but I'm sure it will save a lot of fuel if I keep it slower anyway. Not planning on driving it to win any races!
My Build Thread:
Old 08-12-2017, 09:55 PM   #84
I havent taken a trip at the slower speed in my redbyrd yet.. with the recent trans upgrade from the old AT545 to the 6 speed allison 1000 I netted huge gains.. however i also found out that running the engine at too LOW and RPM can cost MPG..
my bus was originally geared with the AT545 (1.00 ratio) to max out at 2700 RPM at around 72-74 MPH... running at 65 I would var y(no lock converter) between 2300 and 2600 RPM.. and got 7.5 - 9.. running it at 60 my RPMs varied between 2100 - 2400 or so and I got 10 - 11 MPG. (various trips of 500 - 1100 miles)
running in 6th gear(0.60) on the new trans at 65 in 6th gear (tach 1450-1500 RPM) I netted 11 - 11.5 MPG. (3 legs. 700 miles, 450 miles and 750 miles)
running in 5th gear (0.71) at 65 on the new trans (tach 1650 - 1700) I netted 12 - 12.5 MPG.. (1070 miles)
I havent tried a trip at 55-60 yet.
the trip legs i measured here were on up and down terrain.. 650 - 2500 feet or so with mostly light or some headwinds.. on the middle trip (6th gear) I had a tailwind for awhile.. on the last trip (5th gear)winds were generally light though I had a couple thunderstorms, lots of rain.. on the middle trip(6th gear) I had only a little rain..
both trips on the new trans were run with nearly constant A/C usage.)
my earlier trips on the old trans were a mix of A/C and non A/C.. some of those were in dead winter... all the travelling on the new trans has been in the last couple months..
my engine is a T-444E with 157,000 miles on it. the bus is a shorty blue-bird (GVWR 17500).. all stock (no conversion.. stock seats and interior).
I have a couple short (250 miles round trip) trips coming up and ill run them at 60 to see how the MPGs are
Old 08-13-2017, 06:09 PM   #85
Chassis: Thomas
Engine: CAT 3126
Took her out for a spin! Nice day for it!
My Build Thread:
Old 08-13-2017, 06:10 PM   #86
Chassis: Thomas
Engine: CAT 3126
My Build Thread:
Old 08-13-2017, 06:12 PM   #87
Chassis: Thomas
Engine: CAT 3126
I also got the rest of the interior wall panels taken out today. The fiberglass insulation that is shoved down in the bottom quarter of the wall is pretty hard to get out. Do you guys have any awesome tips for how to best insulate that space? It seems like the two-part closed cell foam would be the easiest to fill in all the voids down there. But I was thinking of using the 2 inch rigid foam on the rest of the bus.
My Build Thread:
Old 08-15-2017, 09:55 PM   #88
Chassis: Thomas
Engine: CAT 3126
Update on transmission upgrade to unlock 6th gear. Got as far as realizing that I do need a letter from Thomas. Called today and they said it would take a couple of weeks to get the authorization letter. Nice people.
My Build Thread:
