Old 04-04-2018, 05:29 AM   #981
Chassis: 3800 Carpenter
Engine: DT360 / AT545
Rated Cap: 65 passenger
That looks awesome! I'm really loving your build.
If it's the dual fuel version, I just bought that same generator.
oredigger is offline   Reply With Quote
Old 04-04-2018, 08:22 AM   #982
weboughtabus's Avatar
Coachwork: Corbeil
Engine: Ford PowerStroke Diesel 6.0
Rated Cap: GVWR 11,500
Originally Posted by david.dgeorge07 View Post
OK so some fun progress to report:
The next sequence of pictures shows the assembly of the sled and frame that I made and doing a test install of everything into the bus.
Next thing will be pull everything back out, paint everything, and put it back in with heavier duty hardware. Overall I’m pretty encouraged by the way it turned out and think it’s going to work well!
I’ll have a rocker switch inside the bus that I can use to open and close the drawer.
I'm thinking of getting a Champion Dual Fuel generator for my rig. How do you like yours? What's the running volume like?
weboughtabus is offline   Reply With Quote
Old 04-04-2018, 10:52 AM   #983
david.dgeorge07's Avatar
Chassis: Thomas
Engine: CAT 3126
Mine is not the dual fuel version. I just about purchases that one but two things cause me to change my mind. First I researched the relative cost of running on gasoline versus propane and propane is significantly more expensive. The other reason is that I found this model with a remote start option which seems like it would be really nice at times. Overall they’re very similar generators and I think the dual fuel one is really nice I just decided not to get it essentially because I didn’t think I would use the propane options unless I really had to.
My Build Thread:
https://www.skoolie.net/forums/f11/4-...ner-18205.html
Old 04-04-2018, 10:57 AM   #984
Chassis: Thomas
Engine: CAT 3126
Mine is the gas only version, but I think they’re more or less the same generator just with a different intake design.
As far as volume if you’ve ever used a standard put put type generator I find those to be super annoyingly loud to the point that it’s not worth running them if you have to be close by them and what you’re running them for is a matter of comfort.
With this one you’re not going to forget that it’s running (because you’ll hear it) but it’s more of a background noise than it is something up in your face like a chainsaw engine.
If I remember correctly the specification for noise on this one is somewhere in the 50s for dB.
My Build Thread:
Old 04-04-2018, 10:57 AM   #985
I've only used it once, to light our backyard wedding reception, and I was in no condition to pay attention to the generator. Maybe David has some more experience with it. We got ours at Costco. Here's the link https://www.championpowerequipment.c...fuel-inverter/
Old 04-04-2018, 11:02 AM   #986
Chassis: Thomas
Engine: CAT 3126
My wife got into the bus building action last night by taking some of the foam that came from the original bus seats and trimmed them and glued them together to make a mattress.
They’ll be covered with a mattress topper but they’re pretty comfy already and cost basically nothing!
My Build Thread:
Old 04-04-2018, 11:55 AM   #987
Chassis: Thomas
Engine: CAT 3126
That’s a relief! My shower pan came in and it appears to fit!
My Build Thread:
Old 04-05-2018, 09:54 AM   #988
What sort of glue can you use for that? Since you have, or at least have had LOTS of those seats, why not double up the thickness for a cushier mattress?
dbhost is offline   Reply With Quote
Old 04-05-2018, 09:57 AM   #989
Finally circling back to the kitchen.
Not bad for a freehand router cut! Never tried something like this before and was nerve racking!
With roundover bit.
With faucet added.
Nice work. How are you going to protect the wood from the water on those exposed edges though?
Old 04-05-2018, 10:59 AM   #990
Chassis: Thomas
Engine: CAT 3126
Planning a polymer sealer.
My Build Thread:
Old 04-05-2018, 11:01 AM   #991
Chassis: Thomas
Engine: CAT 3126
I do have LOTS! My wife is the one that did the research but I think she found some sort of a write up online about how to do this or something similar using spray mount gorilla glue.
My Build Thread:
Old 04-05-2018, 12:44 PM   #992
Chassis: Saf-T-Liner MVP ER
There are spray glues specifically for foam ... and upholstery supplier or foam supplier will have them. They do not let go.
Steve Bracken
Build Thread
Old 04-06-2018, 10:04 AM   #993
I use 3M Super 77 spray glue to glue foam.
https://www.amazon.com/3M-21210-Supe...00df3164f66755
ben2go is offline   Reply With Quote
Old 04-08-2018, 10:46 PM   #994
Chassis: Thomas
Engine: CAT 3126
I was out of town for a few days, but got home this morning after riding a bus all night.
I made some progress on the genny drawer.
1. I made guides to help it stay in place when hitting bumps or hard braking etc.
2. I fabbed up the front, making it possible to attach the old skirt panel.
3. I adjusted the support frame to square it up with the frame rails and skirt.
4. Replaced all the self drillers with grade 8 bolts and nuts.
5. Took it all apart ant primed/painted it.
Still need to:
Wire up servo motor. Run power cord for service. Install exhaust vent. Make drawer floor. Final fit and finish.
My Build Thread:
Old 04-09-2018, 11:22 AM   #995
I work in the aircraft industry, and I will give a second thumbs up to the 3M 77 spray adhesive, really great stuff. Used as trim adhesive in aircraft.
Of course, I just go get a can from the tool crib, and don't pay Amazon's price!
Dave in Tucson is offline   Reply With Quote
Old 04-09-2018, 01:17 PM   #996
I think I got my last few cans of 3M Super 77 at Harbor Freight. That stuff is awesome for bonding fabrics to metal or wood! However it gets everywhere, and in your arm hair as you work with it. I would HIGHLY recommend wearing a painters suit and respirator when working with it.
I never would have thought to use it for bonding foam to foam... Probably make for a bomb proof bond.
Old 04-09-2018, 01:18 PM   #997
Still need to:
Attachment 20569
Attachment 20570
Attachment 20571
Attachment 20572
Attachment 20573
Attachment 20574
Attachment 20575
I am officially jealous of your metalworking skills. I REALLY need to learn metalworking....
Old 04-09-2018, 03:35 PM   #998
Chassis: Thomas
Engine: CAT 3126
Thanks! But to be honestly I’m sure you would do fine. If you have an angle grinder, a drill with sharp bits, and access to a MIG welder you would be able to do everything I have done.
MIG welding with 1/8” or thicker stock is very forgiving. With practice you can make pretty welds, but most can make strong welds quickly after starting.
My Build Thread:
Old 04-09-2018, 04:10 PM   #999
Funny you should mention those items...
I do have a MIG, I have never used it but I picked up a used Chicago Electric Mig welder like this one here.... (neighbor had it and was upgrading, wanted to get rid of it and sold it to me cheap...).
https://www.harborfreight.com/170-amp-dc-240-volt-migflux-cored-welder-68885.html
The angle grinder is a B&D from about 20 years ago that I have used to clean up someone else's nasty welds, and trimming some metals that were in places they didn't need to be for me to install winches etc... Pile o junk that gets the job done...
Drill, bits, got those aplenty. Tend toward the TiN coated bits for longevity. What I need is a center punch. Mine grew feet and walked off...
Old 04-09-2018, 04:24 PM   #1000
Chassis: Thomas
Engine: CAT 3126
Good tip! I think that may have been what I used when I replaced the headliner in my jeep a couple years ago. (Came in a lot) It hasn’t come down!
My Build Thread:
