Old 06-17-2017, 03:39 PM   #1
david.dgeorge07's Avatar
Chassis: Thomas
Engine: CAT 3126
4 Curious Georges' 2001 Saf-T-Liner
Okay, We've been working for a couple of weeks and I figured it was finally time to start a thread! The bus is a 2001 Thomas Saf-T-Liner. It is 36' long bumper to bumper and has a rear engine layout. It has conventional springs but rides nicely, I think due in part to the rear engine design. It has the CAT 3126 (which is either the worst engine ever or the best of the early electronic engines, I feel like after researching that it is a decent engine unless until you have to have major work done by CAT, in which case it can be pricey to service), paired with the MD3060 transmission (which most people say is a great unit).
The general progress so far has been to
  1. Remove and recycle the seats
  2. Remove the cabin heater and lines
  3. Remove the rubber floor to discover no plywood only metal
  4. Discover that it is very hard to get the flooring cement off of the metal
  5. And finally, use a sandpaper flap brush on an angle grinder to get the cement off.
I've learned a few things so far:
  1. No matter what, this is just a lot of physical work.
  2. If something seems impossibly hard, you probably aren't approaching it the best way.
  3. Most of the things I've worried about haven't happened.
Finally, here are a list of things I really worried about when trying to decide to do the project/buy this bus:
  1. It would be difficult to drive a bus = not true.
  2. It would be difficult to get it registered = not true.
  3. It would be difficult to get insured = not true
  4. My neighbors would be upset and make me move it = not true
  5. It would not make it the 5 hr. drive home without a breakdown = not true
  6. The CAT engine would be a big mistake = jury is out.
  7. It would be quite difficult to do it on a minimal budget = almost certainly true.
If you are thinking of buying a bus please don't assume you will have the same experience, but thought it might be helpful to share mine.
So far the project has been a great way to collaborate with my daughters and wife in the design and work. It is fun to get to teach them how to use hand tools, and to see our combined effort result in such tangible progress.
Thanks for reading and I look forward to any comments and advice that you may have!
File Type: jpg Screen Shot 2017-06-17 at 3.16.14 PM.jpg (185.0 KB, 366 views)
File Type: jpg Screen Shot 2017-06-17 at 3.19.41 PM.jpg (169.8 KB, 356 views)
File Type: jpg Screen Shot 2017-06-17 at 3.20.40 PM.jpg (263.4 KB, 412 views)
Old 06-17-2017, 04:27 PM   #2
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
Welcome to our collective nightmare! I've a 2003 HDX and am quite pleased with the room as well as the construction.
Old 06-17-2017, 05:01 PM   #3
Robin97396's Avatar
Welcome
You guys with your long buses, hogging all the parking spots.
Robin
Nobody's Business
Old 06-17-2017, 05:17 PM   #4
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
You're just jealous!
Old 06-17-2017, 05:35 PM   #5
Robin97396's Avatar
Sure I'd like to have the space of a long bus, not to mention the basement, but it wouldn't make it down my driveway. Besides, that would have been about 40% more work during the build process.
Robin
Nobody's Business
Old 06-17-2017, 11:01 PM   #6
Chassis: Thomas
Engine: CAT 3126
Does anyone know what these were for? They terminated under the first seat behind the driver in a chassis that looked like it was designed to hold a piece of electronics that might be about the size of a small car battery. It had been held in with a key lock mechanism but is long gone. Not sure what to do with the vestigial wiring harness in the picture.
Sent from my SM-N900P using Tapatalk
My Build Thread:
http://www.skoolie.net/forums/f11/4-...ner-18205.html
Old 06-18-2017, 12:26 AM   #7
Robin97396's Avatar
Pretty sure those were for the bus video system. Sometimes the leave the recorder in the bus. Mine just had the cameras remaining.
Robin
Nobody's Business
Old 06-18-2017, 02:12 PM   #8
Chassis: Thomas
Engine: CAT 3126
Ah, makes sense. Sounds like I just need to follow the lines and get rid of it safely without leaving any open power circuits.
My Build Thread:
Old 06-18-2017, 03:48 PM   #9
Chassis: Thomas
Engine: CAT 3126
Finally got the cockpit cleared and ready to clean the floor!
My Build Thread:
Old 06-18-2017, 04:04 PM   #10
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
They left the "Silent Witness" in my beastie, too. Even left the tape in the recorder. Got out the Sawzall and removed the device, which opened up a lot of dash space. The camera was easy -- only 3 screws and a pair of diagonal cutters and 'poof', they were GONE!
Old 06-18-2017, 11:16 PM   #11
Chassis: Thomas
Engine: CAT 3126
Between the floor and wall there is some kind of tar like sealer. When you get your wire brush in it, it just smears everywhere. Any tips on how to navigate this when preping/painting?
My Build Thread:
Old 06-19-2017, 12:56 AM   #12
Robin97396's Avatar
That kind of looks like butyl. It's going to be burried by time you put the floor in, so rather than remove the butyl and then reseal the area why not just leave it there.
If you do want to remove it a putty knife is about the only way. It's sticky and gets on everything, but it's good stuff. It's been there for about 20 years.
Robin
Nobody's Business
Old 06-19-2017, 09:08 AM   #13
Chassis: Thomas
Engine: CAT 3126
Ah, makes sense! Thanks for the info!
My Build Thread:
Old 06-19-2017, 09:10 AM   #14
Chassis: Thomas
Engine: CAT 3126
Yes, I'm not worried about how it looks. Just seems like a mess to deal with. Oil based primer might act like a solvent, but I don't want to stay completely away from it because I need to get the metal all around it. I guess I'll try to keep it organized and paint up to it but not slather over it.
My Build Thread:
Old 06-19-2017, 11:14 AM   #15
Robin97396's Avatar
You could make a little test area where you've already disturbed the butyl to see if there's any reaction. Butyl is a very old sealant and I'm sure people have painted over it before, although I'm no expert on the subject.
Robin
Nobody's Business
Old 06-19-2017, 11:27 AM   #16
Chassis: Thomas
Engine: CAT 3126
Just about ready to prime the floor.
My Build Thread:
Old 06-19-2017, 01:22 PM   #17
Robin97396's Avatar
You're making pretty good time. Are you pulling the ceiling and wall panels?
Robin
Nobody's Business
Old 06-19-2017, 03:51 PM   #18
Chassis: Thomas
Engine: CAT 3126
Well, that was easy compared to all the prep! Yes, I am planning to pull walls and ceiling for insulation. Very thankful to have screws instead of rivets.
My Build Thread:
Old 06-19-2017, 03:56 PM   #19
Robin97396's Avatar
I've never had the luck to get a bus with screwed ceiling panels. I have a strong aversion to rivets.
If you're having your insulation sprayed in by a contractor, don't accept foundation grade foam. It's like sawing wood during the trim process.
Robin
Nobody's Business
Old 06-19-2017, 04:04 PM   #20
Chassis: Thomas
Engine: CAT 3126
That's a good tip! Is there a name for what you do want?
My Build Thread:
