05-26-2013, 11:48 PM
#321
Year: 87
Chassis: International s1700
Engine: 6.9 internatiional
Re: 87 Wayne Lifeguard international S1700 CXXVI
i just tested the night vision. it works and you can see within a circle created by the infrared leds that circle the lens, causing distortion around the edges. not too bad. i wonder how well it will work when the buses reverse light come on
05-27-2013, 09:09 PM
#322
Year: 87
closer shot of the screen, and the camera looking at my postal jeep
06-02-2013, 12:50 AM
#323
Year: 87
06-02-2013, 09:33 AM
#324
Looks nice, having the rear cam is really nice I love mine and have it on most of the time, but I still use the mirrors all the time, don't want to depend on the camera, it will be nice when towing. your bus is looking great keep it up.
06-03-2013, 09:37 AM
#325
Year: 87
i agree, i feel much more comfortable using mirrors, but this should help me as i don't have the interior mirror of most of my rear windows.
06-03-2013, 12:50 PM
#326
Chassis: Wayne Lifeguard
Engine: GMC 6.2lt
Rated Cap: 40
I love how your wayne is coming together How you did finally decided to do your cable run? Up in the roof skins or on the sides?
06-03-2013, 10:57 PM
#327
Year: 87
thanks Sam,
i think im going to run the ac in a conduit im gong to mount under the seat rails. DC will go through the cable race in the roof skins. I almost have everything i need to start it.
06-04-2013, 09:19 AM
#328
That's pretty much how I did mine. DC runs in the raceway behind the angled roof panels, and then AC, my charge cables from my alternator to my coach batteries, and a couple misc. things are run under the chair rail.
Brutus
06-05-2013, 04:41 PM
#329
Engine: GMC 6.2lt
Rated Cap: 40
Good stuff guys. those do seem like the two best options
gotta love our waynes
06-06-2013, 10:02 AM
#330
Yup! I'm pretty impressed with mine. I know they all have their strengths and weaknesses, but there were a few key things that seemed to make the project easier. That chair rail being one of them. It seemed like a nuisance at first, and I almost cut it off, until I realized that it made a PERFECT channel to run cabling, etc... through. Also very nice to anchor structural things to.
Brutus
06-06-2013, 11:02 PM
#331
Year: 87
i agree, so far i have used mine to attach my counter to the wall.
06-16-2013, 11:45 PM
#332
Year: 87
06-23-2013, 01:27 AM
#333
Year: 87
06-23-2013, 07:22 AM
#334
Coachwork: Eldorado
Chassis: E350
Engine: Ford 7.5 liter Gas
Rated Cap: 29
Looks great, I love the removable handles and tethers, it finishes it off nicely. Great job!
06-23-2013, 10:12 AM
#335
Year: 87
thanks Ferenzy,
i hope it holds together. i plan to add a metal bar to each side that will be held in place with the locking pins(handles) which will then be able to swing down either direction and be locked in place to angle the panels. ill add some wing nuts and screws for traveling as, im paranoid about the locking pins eventually finding a way-out of the panel due to movement.
06-23-2013, 11:17 AM
#336
Year: 1979
Engine: 8 cyl gas
Rated Cap: 60
I want!
My question on looking at it. What about wind factor while driving. I would think a faring in front of the front one would deflect some air from going underneath. (paranoid me setting in thinking).
Linda Kay
trans·mog·ri·fy Verb: Transform, esp. in a surprising or magical manner.
06-23-2013, 11:30 AM
#337
Year: 87
Originally Posted by Shadoll
I want!
i agree, air will get under the panels, but like you said i hope the vent cover in front of the panels will help break up the flowing air, plus the leading panel is angeled down just a touch to the front. the front panel should help break up the air for the second one(at least this is my hope)
06-23-2013, 02:05 PM
#338
Rated Cap: 79 at Birth
Very nice setup on the solar proconsul Mine have been on the roof in similar fashinon without any problems so far, so I think you'll be fine. Just check the screws from time to time because the flexing of the roof and the panels will sometimes make them loosen up.
06-23-2013, 04:55 PM
#339
Year: 87
thanks BC, ill keep my eyes on the screws in the panels and the roof. here is a photo of my controller. i just re ran the wires and put everything back together.
06-24-2013, 08:00 AM
#340
I would keep an eye out on the holes that the quick release pins use in the solar panel
Those panels probably are using 6063 Angle and maybe .063 thick and it is fairly soft, the "beating" of the air may wallor the holes out causing the pins to fall out or stress cracks to happen (it tears fairly easily)
