06-24-2013, 09:36 AM
#341
Year: 87
Chassis: International s1700
Engine: 6.9 internatiional
Re: 87 Wayne Lifeguard international S1700 CXXVI
Originally Posted by bansil
I would keep an eye out on the holes that the quick release pins use in the solar panel
Those panels probably are using 6063 Angle and maybe .063 thick and it is fairly soft, the "beating" of the air may wallor the holes out causing the pins to fall out or stress cracks to happen (it tears fairly easily)
you have a good point, i am kind of worried about holes expanding over time making the pins useless. i think im going to add in screws and wing nuts to be used when traveling. at least for some of the holes. it took a long time to drill the hole out,but it is still just aluminum.
06-24-2013, 02:07 PM
#342
Engine: 3126
Hey proconsul100,
Do you have your panels setup to be removed, so you can use them when parked in the shade?
I was trying to decide if I should have a connector on the roof to plug them into when mounted. Then a longer cable and connector on the side of the bus to move them into the sun when parked in the shade.
06-24-2013, 08:20 PM
#343
Year: 87
Originally Posted by wmkbailey
Hey proconsul100,
wmkbailey,
this is a good idea, i might add a Y to the cables so that i will have the ability to do this as well. my panels are held in by the quick release pins and can be removed as well. i originally used the pins so it would be easy to angle them to the front or back of the bus depending which side will be facing south in the winter. thanks for the idea
Eric
07-06-2013, 09:11 PM
#344
Year: 87
07-07-2013, 01:24 AM
#345
Year: 87
07-11-2013, 09:49 PM
#346
Year: 87
AC hotel light fixture test with 12V DC LED Edison base bulbs
attached to an old Motorola radio connector on the bus:
you cant tell from the photo but its pretty darn bright
07-12-2013, 07:33 AM
#347
sweet I need to check out those bulbs
07-14-2013, 10:19 PM
#348
Year: 87
07-21-2013, 05:13 PM
#349
Year: 87
insulated with foam behind the rear end cap and re assembled it. im going to have to open it again when i put in the ac, but i wanted to make sure the light fixtures fit ok.
07-21-2013, 07:14 PM
#350
Engine: 3126
Wow, that looks really nice. I thought this was a school bus, not a high end apartment.
07-22-2013, 10:01 PM
#351
Year: 87
i picked up a flexsteel jackknife sofa today, i hit it with the upholstery shampooer. it has a piece that hangs down to cover the legs as well
it has these strange legs sticking out a few extra inches in the back. the front legs are 11 inches and lo and behold the seat rail in the bus is 11 inches. im going to hack the ends off in the back and bolt the rear legs right to the seat rail
i also picked up this rv range vent that has power, Grey, black and fresh tank monitors built into it. im going to clean it up and see if i can make the monitor functions work:
07-22-2013, 10:52 PM
#352
Before you go hacking off those braces, you may want to check how it sits in flat position. I think you will find those account for the back when laid flat. Just a suggestion though.
07-22-2013, 11:03 PM
#353
Year: 87
you have a good point. i checked the rear braces with it lying flat in the bed position, and they stick a few inches out when flat. perhaps there was something behind the sofa when this was in its previous home. i will measure the hell out of it before i hack them off, if i hack them off
07-22-2013, 11:16 PM
#354
I have owned a couple of futons over the years and it seems every one of them requires a bit of space you haven't accounted for when laid flat. I just figured that yours would be the same.....and even more likely to be an issue if you had hacked them off first....That Murphy guy seems to get around!!
07-23-2013, 09:57 PM
#355
Year: 87
07-25-2013, 11:07 PM
#356
Year: 87
07-25-2013, 11:48 PM
#357
Looks good, and the fit looks perfect!!
07-26-2013, 12:15 AM
#358
Engine: DT466/AT545
It's great to have one of those couches. I love mine. I just need to re-cover it. Not sure about the size of yours (it looks about the same size as mine), but I've found that mine is unfortunately a bit too small to comfortably sleep two adults. My wife sits on the front-most section so she can be the navigator and talk to me when I'm driving.
07-26-2013, 08:08 AM
#359
Engine: 3126
I plan to have a jack-knife sofe in my bus as a second sleeping area. Or for when I'm to lazy to walk all the way to the back to sleep. Durango says we will have to negotiate this. If I sleep on the couch, he gets the bed.
I havent thouhg about mounting it to the chair rail, good idea.
07-26-2013, 09:37 AM
#360
Year: 87
i left the chair rail on there just in case i wanted to mount stuff to it in the future,and im glad i did. im happy the chair rail and the front sofa legs are the same height
