Old 07-27-2013, 10:50 PM   #361
Year: 87
Chassis: International s1700
Engine: 6.9 internatiional
Re: 87 Wayne Lifeguard international S1700 CXXVI
made a wall out of a door. this was a pain. my template for the curve wasnt right so i ended trimming little bits off at a time with wire cutters until it fit, and it still isn't right at the top. i may use this door as a template for a piece of plywood in the future.
proconsul100 is offline   Reply With Quote
Old 07-29-2013, 05:22 PM   #362
Shadoll's Avatar
Year: 1979
Engine: 8 cyl gas
Rated Cap: 60
You find the greatest stuff!! Love the bed. And the bedroom lamps.
Linda Kay
trans·mog·ri·fy Verb: Transform, esp. in a surprising or magical manner.
Shadoll is offline   Reply With Quote
Old 07-29-2013, 11:29 PM   #363
Year: 87
thanks, the lights are hotel room lights i paid $7.50 each for them at the habitat for humanity re -store. i always check there to see what shows up.
Old 07-30-2013, 11:08 AM   #364
Shadoll's Avatar
Year: 1979
Engine: 8 cyl gas
Rated Cap: 60
Our restore has a lot of pressboard and metal furniture and old doors. I bought a sink there but now I'm thinking I don't even like that. Haven't really found much I like there other than small things like door handles. Need to make some trips to the big city I think.
I was thinking after seeing yours that I want to build the existing coach lights that work into the underside of my upper cabinets so I'll have some running lights left. Took off a v-shaped panel across the top of the windows and gained about 3" and there is only one wire running behind it. Conduit that into the back side of my cabinets and it will be out of the way and functional.
Linda Kay
Old 07-30-2013, 11:41 AM   #365
Accordion's Avatar
Year: 1973
Engine: CAT 1160 V-8 Diesel
You can use self adhesive foam rubber strips(one inch wide) to trim out the top of that wall where it meets the ceiling.
Old 07-30-2013, 11:45 PM   #366
Year: 87
i was thinking about doing the same thing with my coach lights. its good to keep them.
Old 07-30-2013, 11:46 PM   #367
Year: 87
thanks Accordion, i was going to check into that flexible molding, but the foam rubber sounds less expensive
Old 08-05-2013, 01:25 AM   #368
Year: 87
not too much done this weekend. i moved the counter down and aligned it to the new wall, and cleaned the hell out of the sofa. this also puts the stove directly into one former window frame for attachment of the range hood.
Old 08-05-2013, 08:48 AM   #369
wmkbailey's Avatar
Engine: 3126
Wow, it is looking quite homey inside your bus. I do like the idea of using a solid wood door for a wall too.
William
https://thejourneyvisvi.com/
My Conversion Thread:
viewtopic.php?f=9&t=464989
Old 08-08-2013, 09:58 PM   #370
Shadoll's Avatar
Year: 1979
Engine: 8 cyl gas
Rated Cap: 60
Looking good!! Cozy.
Linda Kay
Old 08-12-2013, 08:15 PM   #371
D&ACaple's Avatar
Chassis: Ford B-700
Engine: Cummins 5.9l Turbo Diesel
Rated Cap: 28
diggin' your bus, love the ideas.... great eye
Yes..... it IS a bus, and no you can't have it!
D&ACaple is offline   Reply With Quote
Old 08-24-2013, 10:48 PM   #372
Year: 87
i have been busy at work, so i havent had as much time with the bus as i would like. i did pick up a window AC that will fit into the space above the windows in the back once i cut a hole. i have been modifying extension cords to run to my wall outlets and i have started my first hole in the steel for my first outlet that will be for the TV. i have also started taking apart my progressive dynamics converter to rewire it with 30 and 20 amp Computer power cords.
Old 08-25-2013, 04:01 PM   #373
Year: 87
outlet installed today:
Old 08-31-2013, 10:32 PM   #374
Year: 87
i got my RV mounted and working with the DVD player.
music disks show up like this
Old 09-01-2013, 05:03 AM   #375
Cool
Old 09-01-2013, 07:38 PM   #376
Year: 87
after tidying up the cables and RF converter:
Old 09-01-2013, 10:18 PM   #377
Engine: 190hp 5.9 Cummins
Nice clean install!
Old 09-02-2013, 08:11 PM   #378
Year: 87
i bought 2 awnings 1 small, and one 14 ft with all the hardware for $60. i have been cleaning it.
Old 09-03-2013, 06:04 AM   #379
awesome score!!
Old 09-03-2013, 09:59 AM   #380
Year: 87
thanks Bansil, now i have to figure out where to put the small one. any ideas where it might work?
1984 International s1700 Fully Converted britnich84 Classifieds | Buy, Sell, Swap 6 12-08-2013 01:05 AM
service manual for 1987 Wayne Lifeguard proconsul100 Conversion General Discussions 2 07-10-2012 11:58 AM
CXXVI 87 Wayne lifestar International s1700 6.9 proconsul100 Skoolie Conversion Projects 1 07-10-2012 09:45 AM
1982 International "War-Hog" S1700 Sojakai Short-Bus Conversion Projects 22 05-28-2010 12:19 PM
International S1700 6.9 Diesel Info Needed Please woodyking Conversion Tutorials and How-to's 7 03-31-2008 02:31 PM
