09-17-2013, 11:58 AM
#421
Moderator
Engine: DT408, AT545
Rated Cap: 23 500 gvw
Re: 87 Wayne Lifeguard international S1700 CXXVI
Originally Posted by wmkbailey
What does this have to do with placing batteries on the ground to watch them discharge, oh sorry we hijacked your thread.
Exactly why I bowed out of that particular soon-to-be-argument, but some insist on making it a federal case...
What I can vouch for is the fact that when I worked at AutoZone, we had a special on DuraLast top-post batteries of a certain size group. They were stacked on the concrete floor as a display. EVERY SINGLE ONE of the batteries on the bottom row (that sat on the CONCRETE) had problems. None of the others did. Can anyone EXPLAIN that? Call it what you want. Agree to disagree. Back to the OP's build... What's new?
The batteries must have been laid out in an east west direction. That will definitely do that. If you want the batteries topped off, they must be in a north sound direction. Sorry, had to put in my 1 1/2 cents.
Bus is looking great by the way.
09-18-2013, 09:55 AM
#422
Year: 87
Chassis: International s1700
Engine: 6.9 internatiional
Thanks Cal, my progress is slow, but i try to finish at least 1 item a week.
09-21-2013, 08:05 AM
#423
Originally Posted by proconsul100
Originally Posted by bansil
nice,what model is it?
they say it is RV/Marine, but neither the box, instructions, nor anyone on line mentions using it on an RV. Lots of people using them on their boats.
we do have land yachts'
Thanks
10-05-2013, 10:48 PM
#424
Year: 1979
Engine: 8 cyl gas
Rated Cap: 60
Cute. Gives it a bit of alien mystery. Looks like it works good.
Actually, the front of the bus looks like a dogs face with nose and ears and with a top knot on his head.
Linda Kay
trans·mog·ri·fy Verb: Transform, esp. in a surprising or magical manner.
10-05-2013, 10:56 PM
#425
Year: 87
i had a mishap today. was cutting down large branches in order to move the bus forward a couple of feet so i can finish installing the awning. when i got down from the roof i noticed this:
one of the large branches must have bounced up and broke one of the windshield panes. i wonder if anyone knows where i can go for bus windshield glass.
10-06-2013, 05:18 AM
#426
Traveling
Year: None
Coachwork: None
Chassis: None
Engine: None
Rated Cap: None
10-06-2013, 02:38 PM
#427
Year: 1979
Engine: 8 cyl gas
Rated Cap: 60
I had a small crack in mine and the weather has made it travel all over the place so I will have to replace mine eventually as well.
Linda Kay
10-06-2013, 11:11 PM
#428
Year: 87
10-21-2013, 10:17 PM
#429
Year: 87
i finished routing the coax cable and power to the antenna amplifier, cut a hole and installed the amp into the bulkhead next to the TV.
12-29-2013, 06:57 PM
#430
Year: 87
01-01-2014, 06:49 PM
#431
Year: 87
01-02-2014, 05:10 AM
#432
Year: 1973
Engine: CAT 1160 V-8 Diesel
I love those catalytic heaters. I have three of them.
01-02-2014, 09:24 AM
#433
Year: 87
im thinking about getting a smaller wave 3 for the back of the bus. how do you bring in oxygen?
01-02-2014, 05:05 PM
#434
Year: 1973
I have three Wave 3000 BTU models. Bring in Oxygen?
Let me assure you that my bus is NOT air tight. If it was, I would leave a window open a half inch. As it is, I have enough air coming in from my front door.
Presently, I also use Electric oil filled heaters, therefore, I only use one of my catalytic heaters. My electric blanket keeps me toasty at night.
I sleep with my coveralls, wool hat, socks, and if it is cold enough, I get in my sleeping bag.
As I am writing, it is 47 degrees in the bus. Yes, it is cold.
01-02-2014, 10:10 PM
#435
Chassis: Ward
Engine: 6.6L Brazilian Ford
Rated Cap: 1
Gotta love those Olimpian heaters; they are the best!!! I'm gonna have one when I grow up
01-03-2014, 09:45 AM
#436
Year: 87
thanks Accordion, im pretty sure my bus is not air tight either, when ever they give a warning like that about adequate oxygen it worries me, but i dont want to be leaving windows open. 47 degrees is pretty cold to hang out in Accordion, try to stay warm where you are at, its hard to type at those temps.
01-05-2014, 06:40 PM
#437
Year: 87
01-05-2014, 08:34 PM
#438
Chassis: Ward
Rated Cap: 1
Nice job man
01-05-2014, 09:00 PM
#439
Thats the way it 'otta be--nice work!
01-07-2014, 09:31 AM
#440
Year: 87
Thanks Guys, i need to get another flare T so that i can run another line back to where the water heater will be. i also need to do the soap test on all the fittings.
