Old 11-18-2012, 12:51 PM   #221
Year: 87
Chassis: International s1700
Engine: 6.9 internatiional
Re: 87 Wayne Lifeguard international S1700 CXXVI
i installed the media center in the bus:
proconsul100 is offline   Reply With Quote
Old 11-18-2012, 01:01 PM   #222
browncrown's Avatar
Rated Cap: 79 at Birth
Nice install on the Media Center. I like the wood trim you put around it.
BC
Old 11-18-2012, 02:55 PM   #223
Year: 87
thanks, the trim serves a practical purpose, and the cavity i cut in the metal isn't deep enough to accommodate the media center. so i bolted the 2x2`s into the metal then screwed the media center into the wood. The wood needs a couple more coats of shellac, i also intend to carpet tile the unused area around the wood.
Old 11-22-2012, 10:31 AM   #224
Year: 87
Originally Posted by NoBusYet
Your work with wood is really nice, but I especially like your use of the carpet as wall covering. I like the idea of the carpet rather then trying to get another coat of paint to stick to the interior of the bus (especially if the paint was in good condition to start with.) As a bonus, you can replace it by the square if it gets stained/cut/etc. How much does it help the echo while driving down the road?
thanks,
i driven the bus since i bought it home, so i don't know about road noise and if the carpet helps. but it has removed the echo when im doing work inside the bus. it also seems to keep the bus warmer as there is less steel in contact with the inside of the bus. i have a lot more carpet to glue down.
Old 11-22-2012, 10:31 AM   #225
Year: 87
thanks,
i haven't driven the bus since i bought it home, so i don't know about road noise and if the carpet helps. but it has removed the echo when im doing work inside the bus. it also seems to keep the bus warmer as there is less steel in contact with the inside of the bus. i have a lot more carpet to glue down.
Old 12-02-2012, 10:49 PM   #226
Year: 87
added some more walls over the windows, and carpeted them, plus i blocked off the roof vent with a piece of felt underlayment, and insulated all around the vent hole as there was at least a foot of space in between the inner and outer skins of the bus with no insulation around the vent hole.i also finished carpeting the front area above the windshield
Old 12-09-2012, 09:30 PM   #227
Year: 87
i carpeted below the seat rails, only one part of the back bedroom remains
Old 12-09-2012, 11:13 PM   #228
thommassey's Avatar
Chassis: All American RE
Engine: 3208TA Cat 250HP
That came out nice, well done! ... Good to keep access door "accessible" on floor.
TUMBLEWEED (AKA Rufus) build:
viewtopic.php?f=9&t=11121
PICTURES : http://s1338.beta.photobucket.com/user/ ... M-HP/Rufus
thommassey is offline   Reply With Quote
Old 12-10-2012, 03:01 PM   #229
Shadoll's Avatar
Year: 1979
Engine: 8 cyl gas
Rated Cap: 60
Looks really nice. Wow. And you left the seat rails in as a nice border and finished nicely. I hate them but don't see where I can do much different unless I brought the walls in to their level or somehow hammered them down/up against the walls. Makes for a nice break though.
Linda Kay
trans·mog·ri·fy Verb: Transform, esp. in a surprising or magical manner.
Shadoll is offline   Reply With Quote
Old 12-10-2012, 07:47 PM   #230
They do make a great electrical/hydrulic chase when closed below the rail.
1984 International s1700 Fully Converted britnich84 Classifieds | Buy, Sell, Swap 6 12-08-2013 01:05 AM
service manual for 1987 Wayne Lifeguard proconsul100 Conversion General Discussions 2 07-10-2012 11:58 AM
CXXVI 87 Wayne lifestar International s1700 6.9 proconsul100 Skoolie Conversion Projects 1 07-10-2012 09:45 AM
1982 International "War-Hog" S1700 Sojakai Short-Bus Conversion Projects 22 05-28-2010 12:19 PM
International S1700 6.9 Diesel Info Needed Please woodyking Conversion Tutorials and How-to's 7 03-31-2008 02:31 PM
