01-27-2014, 09:42 AM
#461
Year: 87
Chassis: International s1700
Engine: 6.9 internatiional
Re: 87 Wayne Lifeguard international S1700 CXXVI
Originally Posted by ol trunt
Great luck on the fit of the grey tank. I'd suggest a couple of 1/8" by 3/4" straps under the belly of the tank to help support the weight of the waste. While these tanks are very long lived, they are subject to splitting if they are not well supported. The straps should follow the contour of the tank and mount (with 1/4" bolts) to the flange of the frame--cheap insurance
thanks Trunt, i will use some stapping
01-27-2014, 09:44 AM
#462
Year: 87
thanks for the tank calculations guys, once i find out for sure i will let everyone know
my second tank im going to use for a for black shows as being 59.5x12x10. when i calculate that one on the on-line calculator from Nat_ster it give me around 140 gallons, and i know that isn't correct. I'm going to try some aquarium calculators.
01-29-2014, 03:52 PM
#463
59.5 x 12 x 10 = 7140 cu in divide by 1728 (1 cu ft) = 4.1319 cu ft x 7.48 (gal per cu ft) = 30.9 gallons = Roger Nat
01-29-2014, 09:57 PM
#464
Year: 87
thanks guys, 30 gallons should be fine for a black tank. thats a lot of poop.
01-30-2014, 07:14 AM
#465
Chassis: Ward
Engine: 6.6L Brazilian Ford
Rated Cap: 1
Depends on how full of it you are
Sorry Pro; you walked into that one
01-30-2014, 09:37 AM
#466
Year: 87
well, i have been told that i am full of it from time to time, perhaps even 30 gallons worth
01-30-2014, 10:56 AM
#467
Chassis: Ward
Rated Cap: 1
My, this conversation is spiraling downwards quickly!!
01-30-2014, 06:21 PM
#468
Year: 87
just reading all these replies have gotten me flushed, I'm completely pooped after reading them all. but my time was not wasted.
02-01-2014, 07:51 PM
#469
Year: 87
02-02-2014, 05:35 AM
#470
Turned out great, I have always wondered...every time I see that wall....what are you doing for back splash?
Every time I open the thread, I can't wait to see....it's still not done
02-02-2014, 07:24 AM
#471
nice clean job. looks great
02-02-2014, 10:43 AM
#472
Year: 87
Thanks bansil,
I'm thinking some kind of linoleum or vinyl tile, i just haven't gotten there yet. I want something that can be glued to both the range black splash and the side wall that is Farly light and can be wiped down easily. i have been keeping my eyes open when i visit the re store. i am always open to suggestions
02-02-2014, 12:45 PM
#473
After our first trip and having to clean all counter tops from,grease and spills etc, as well as crumbs in between wood
I had a bunch of sheets of lexan 1/4 in and made covers for the counters.
When not being used or in transit they get tucked away between wall and cabinet
I am maybe thinking 2 part epoxy this spring, like bar tables...easy clean,smooth and would look good(just have to seal underside gaps)
For Me the material was cheap (free)
02-05-2014, 09:48 AM
#474
Year: 87
thanks Bansil,
i wonder if i could make a back splash out of the vinyl used in making shower walls? it would be easy to clean. i tried to using 2 part bar top epoxy to try and repair a solar panel it never cured properly and i had to remove it.it could be i had the proportions off, didn't mix it enough or i had bought poor epoxy, because it have seen some cool tables done with it.
02-05-2014, 10:02 AM
#475
looks like you have plenty of space from flame to wall, so heat shouldn't be an issue
I would take it all the way up the wall so anything pulled by fan can be cleaned
02-05-2014, 11:33 AM
#476
Okay. So... I'm glad your hands aren't all hairy and weird like former Teen Wolf here:
I GET that some of it is dirt and grime, but there is a LOT of knuckle hair there. A LOT.
02-05-2014, 09:50 PM
#477
Year: 87
yes i do have quite hairy fingers
02-10-2014, 05:53 AM
#478
turned out good
02-10-2014, 05:20 PM
#479
Rated Cap: 79 at Birth
Looking very nice with the backsplash
02-11-2014, 09:35 AM
#480
Year: 87
Thanks BC
