07-28-2012, 11:30 PM
#61
Year: 87
Chassis: International s1700
Engine: 6.9 internatiional
Re: 87 Wayne Lifeguard international S1700 CXXVI
07-29-2012, 01:39 AM
#62
Moderator
Engine: DT408, AT545
Rated Cap: 23 500 gvw
Originally Posted by proconsul100
Those tanks are 4 feet tall. No way you have enough clearance. Try a 55 gallon poly drum on it's side. Those are strong as hell and cheap, like free or $5-10.
07-29-2012, 10:11 AM
#63
Year: 87
thanks, you are right, there are a couple people locally that have plastic 55 gallon drums. i wonder if they make fittings that screw into the existing bungs?
07-29-2012, 10:53 AM
#64
they are being sold because they are using the new plastic tanks that have a plastic enclosure for support..
i have some of the tanks as pictured also, but am not using them.
they could be made into grey or whatever tanks, but they would have to be cut down, and a new top made.
for hauling stuff in a trailer, if you remove the plastic tank, they make really good boxes by using the metal exterior as the box.
besides the 55 gal food grade barrels, they also make 30 gal ones that are used for stuff like syrup at the pepsi bottleing plant close to here.
07-29-2012, 11:09 AM
#65
Moderator
One of the holes is coarse thread and the other is fine. PVC threaded fittings work on the coarse I think. It's been so long I don't remember.
07-29-2012, 06:29 PM
#66
i think the large holes are 2 inch and the small ones 3/4 if i remember right..fwiw
07-29-2012, 07:25 PM
#67
Moderator
I think that's correct but the 2" have different threads. Not sure why. Probably means getting one fitting at Home Depot and the other from a specialty supplier.
07-29-2012, 08:27 PM
#68
Year: 87
thanks guys, i will pick up a few of these barrels. one for fresh, one for Grey and one for black. i imagine i will have to cut extra holes for the black tank and glue the fittings in. for that.
07-30-2012, 09:27 PM
#69
Year: 87
07-31-2012, 09:45 AM
#70
Rated Cap: 79 at Birth
Light covers turned out good, and the counter installation fits really well. Good job
07-31-2012, 08:52 PM
#71
Year: 87
07-31-2012, 10:27 PM
#72
Year: 1973
Engine: CAT 1160 V-8 Diesel
I think that the light covers look great. Awesome job of cutting those circles with a dremel. You certainly have a steady hand.
07-31-2012, 10:57 PM
#73
Year: 87
Thanks Accordion, it took me a long time, i was covered with lots of grit when i was done too
08-01-2012, 07:11 AM
#74
Chassis: AARE
Engine: 3116 Cat 250hp
My hat's off to you, I have never found a good use for those little wheels, if I had tried to do that I would have about 5,000,000 broken wheels and not one circle cut out.
08-01-2012, 10:38 AM
#75
Year: 87
well, i did go through quite a few of the grinding wheels, luckily i have a lot of them
08-01-2012, 02:28 PM
#76
Nice job on the light covers....... luv the pink sink!!!!
GreyEagle
Roll - On...
08-02-2012, 09:16 AM
#77
Year: 87
thanks GreyEagle, i was hoping it was more of a peach color, but i think you are right...its pink
08-02-2012, 09:40 AM
#78
Well........ Let's just call it peach......... sounds good to me!
But it sure looks pink in the picz.
For the price we can live with it, you can always change it later when you get the bus finished/ or almost finished, we are never done.
GreyEagle
Roll - On...
08-02-2012, 09:47 AM
#79
Works for me to call it Peach, but either way, it looks good in the installation
we are never done.
Truer words were never spoken...there is always something to fiddle around with and change as time goes by
08-02-2012, 11:17 AM
#80
Year: 87
we are never done.
thanks Guys, im picking up a couple of fresh water tanks, a power box and a stove today as well. i will keep you all posted
